Part Number: F28M36H33B2
My post on this issue was locked but never resolved. Please see the previous thread:
I still have this problem. I can not get the debugger to connect to my device when using the cloud tools, specifically the Gui Composer. Please help. Log file attached again.
2017-10-30T09:27:19.607Z: Staring directory : C:\Users\asmit\TICLOU~1\src
2017-10-30T09:27:19.609Z: Starting Agent!
2017-10-30T09:27:19.618Z: Module( Agent )->Web socket server started!
2017-10-30T09:27:22.241Z: Overridden Proxy =
2017-10-30T09:27:22.314Z: Discovered Module : DeviceDetector
2017-10-30T09:27:22.365Z: Discovered Module : DS
2017-10-30T09:27:22.379Z: Discovered Module : EventBroker
2017-10-30T09:27:22.398Z: Discovered Module : File
2017-10-30T09:27:22.405Z: Discovered Module : Flash
2017-10-30T09:27:22.410Z: rov_server_redirect: looking in: C:\Users\eclipse\dropins
2017-10-30T09:27:22.412Z: rov_server_redirect: looking in: C:\Users\eclipse\plugins
2017-10-30T09:27:22.414Z: rov_server_redirect: looking in: C:\Users\eclipse\Eclipse.app\Contents\Eclipse\dropins
2017-10-30T09:27:22.415Z: rov_server_redirect: looking in: C:\Users\eclipse\Eclipse.app\Contents\Eclipse\plugins
2017-10-30T09:27:22.417Z: Failed to load module : rov_server_redirect.js : TypeError: Arguments to path.join must be strings
at f (path.js:204:15)
at Object.filter (native)
at Object.exports.join (path.js:209:40)
at Object.<anonymous> (C:\Users\asmit\TICLOU~1\src\modules\rov_server_redirect.js:65:22)
at Module._compile (module.js:456:26)
at Object.Module._extensions..js (module.js:474:10)
at Module.load (module.js:356:32)
at Function.Module._load (module.js:312:12)
at Module.require (module.js:364:17)
at require (module.js:380:17)
2017-10-30T09:27:23.114Z: Discovered Module : Serial
2017-10-30T09:27:23.120Z: Discovered Module : TargetSupport
2017-10-30T09:27:23.121Z: Agent main module running on port 64155
2017-10-30T09:27:23.123Z: len=
2017-10-30T09:27:23.124Z:
2017-10-30T09:27:23.125Z: buf=
2017-10-30T09:27:23.126Z: {"port":64155,"version":"4.2"}
2017-10-30T09:27:23.160Z: Module( Agent )->{"command":"listCommands","id":1,"data":[]}
2017-10-30T09:27:23.162Z: Module( Agent )->{"data":{"commands":["listSubModules","createSubModule","listCommands","addConfigProperty","registerModuleWebSocket","registerModuleByPath"]},"response":1}
2017-10-30T09:27:23.170Z: Module( Agent )->Socket closed
