Part Number: LAUNCHXL-CC2650
Other Parts Discussed in Thread: SYSBIOS, CC2650, CC2640R2F
I am using LAUNCHXL-CC2650
BLE SDK 2_02_07_06
CCS7.4
Compiler TI Ver.5.2.6.
XDC tool version 3.32.0.06_core
TI RTOS version 2.21.1.08
I am using Simple BLE peripheral as base project.mem
Build configuration is OAD_Ext_Flash since we need OAD.
OAD feature works fine.
To reduce the Internal flash memory consumption I have enabled STACK in ROM feature by adding
/* use the kernel in the ROM */
var ROM = xdc.useModule('ti.sysbios.rom.ROM');
ROM.romName = ROM.CC2650;
But I am getting error "DEFAULT memory range overlaps existing memory range IMAGE_HEADER"
Error message is as shown below,
"configPkg/linker.cmd", line 596: warning #10096-D: specified address lies outside memory map error #10264: DEFAULT memory range overlaps existing memory range IMAGE_HEADER error #10264: DEFAULT memory range overlaps existing memory range FLASH error #10264: DEFAULT memory range overlaps existing memory range SRAM error #10010: errors encountered during linking; "SUT750A3.out" not built
I have also attached the map file of project as below
TI ARM Linker PC v5.2.6
>> Linked Thu Feb 16 19:55:43 2023
OUTPUT FILE NAME: <SUT750A3.out>
ENTRY POINT SYMBOL: "ResetISR" address: 00007e29
MEMORY CONFIGURATION
name origin length used unused attr fill
IMAGE_HEADER 00001000 00000010 00000010 00000000 R X
FLASH 00001010 0000d010 0000c352 00000cbe R X
SRAM 20000000 00004318 00002872 00001aa6 RW X
SEGMENT ALLOCATION MAP
run origin load origin length init length attrs members
00000100 00000100 00000544 00000544 r--
00000100 00000100 0000003c 0000003c r-- .const:ti_sysbios_knl_Task_Object__PARAMS__C
0000013c 0000013c 00000034 00000034 r-- .const:ti_sysbios_knl_Mailbox_Object__PARAMS__C
00000170 00000170 00000030 00000030 r-- .const:ti_sysbios_family_arm_m3_Hwi_Object__PARAMS__C
000001a0 000001a0 0000002c 0000002c r-- .const:ti_sysbios_hal_Hwi_Object__PARAMS__C
000001cc 000001cc 00000028 00000028 r-- .const:ti_sysbios_heaps_HeapMem_Module__FXNS__C
000001f4 000001f4 00000028 00000028 r-- .const:ti_sysbios_knl_Swi_Object__PARAMS__C
0000021c 0000021c 00000024 00000024 r-- .const:ti_sysbios_gates_GateHwi_Module__FXNS__C
00000240 00000240 00000024 00000024 r-- .const:ti_sysbios_gates_GateMutex_Module__FXNS__C
00000264 00000264 00000024 00000024 r-- .const:ti_sysbios_heaps_HeapMem_Object__PARAMS__C
00000288 00000288 00000024 00000024 r-- .const:ti_sysbios_knl_Clock_Object__PARAMS__C
000002ac 000002ac 00000024 00000024 r-- .const:ti_sysbios_knl_Semaphore_Object__PARAMS__C
000002d0 000002d0 00000020 00000020 r-- .const:ti_sysbios_family_arm_m3_Hwi_Object__DESC__C
000002f0 000002f0 00000020 00000020 r-- .const:ti_sysbios_gates_GateHwi_Object__DESC__C
00000310 00000310 00000020 00000020 r-- .const:ti_sysbios_gates_GateMutex_Object__DESC__C
00000330 00000330 00000020 00000020 r-- .const:ti_sysbios_hal_Hwi_Object__DESC__C
00000350 00000350 00000020 00000020 r-- .const:ti_sysbios_heaps_HeapMem_Object__DESC__C
00000370 00000370 00000020 00000020 r-- .const:ti_sysbios_knl_Clock_Object__DESC__C
00000390 00000390 00000020 00000020 r-- .const:ti_sysbios_knl_Mailbox_Object__DESC__C
000003b0 000003b0 00000020 00000020 r-- .const:ti_sysbios_knl_Queue_Object__DESC__C
000003d0 000003d0 00000020 00000020 r-- .const:ti_sysbios_knl_Semaphore_Object__DESC__C
000003f0 000003f0 00000020 00000020 r-- .const:ti_sysbios_knl_Swi_Object__DESC__C
00000410 00000410 00000020 00000020 r-- .const:ti_sysbios_knl_Task_Object__DESC__C
00000430 00000430 00000018 00000018 r-- .const:ti_sysbios_gates_GateHwi_Object__PARAMS__C
00000448 00000448 00000018 00000018 r-- .const:ti_sysbios_gates_GateMutex_Object__PARAMS__C
00000460 00000460 00000018 00000018 r-- .const:ti_sysbios_knl_Queue_Object__PARAMS__C
00000478 00000478 00000008 00000008 r-- .const:ti_sysbios_knl_Idle_funcList__C
00000484 00000484 00000004 00000004 r-- .const:ti_sysbios_family_arm_cc26xx_Timer_startupNeeded__C
00000488 00000488 00000004 00000004 r-- .const:ti_sysbios_family_arm_m3_Hwi_E_alreadyDefined__C
0000048c 0000048c 00000004 00000004 r-- .const:ti_sysbios_family_arm_m3_Hwi_E_hwiLimitExceeded__C
00000490 00000490 00000004 00000004 r-- .const:ti_sysbios_family_arm_m3_Hwi_NUM_INTERRUPTS__C
00000494 00000494 00000004 00000004 r-- .const:ti_sysbios_family_arm_m3_Hwi_Object__count__C
00000498 00000498 00000004 00000004 r-- .const:ti_sysbios_family_arm_m3_Hwi_Object__table__C
0000049c 0000049c 00000004 00000004 r-- .const:ti_sysbios_family_arm_m3_Hwi_ccr__C
000004a0 000004a0 00000004 00000004 r-- .const:ti_sysbios_family_arm_m3_Hwi_excHandlerFunc__C
000004a4 000004a4 00000004 00000004 r-- .const:ti_sysbios_family_arm_m3_Hwi_nullIsrFunc__C
000004a8 000004a8 00000004 00000004 r-- .const:ti_sysbios_family_arm_m3_Hwi_numSparseInterrupts__C
000004ac 000004ac 00000004 00000004 r-- .const:ti_sysbios_family_arm_m3_Hwi_priGroup__C
000004b0 000004b0 00000004 00000004 r-- .const:ti_sysbios_family_arm_m3_TaskSupport_stackAlignment__C
000004b4 000004b4 00000004 00000004 r-- .const:ti_sysbios_heaps_HeapMem_E_memory__C
000004b8 000004b8 00000004 00000004 r-- .const:ti_sysbios_heaps_HeapMem_Module__gateObj__C
000004bc 000004bc 00000004 00000004 r-- .const:ti_sysbios_heaps_HeapMem_Object__count__C
000004c0 000004c0 00000004 00000004 r-- .const:ti_sysbios_heaps_HeapMem_Object__table__C
000004c4 000004c4 00000004 00000004 r-- .const:ti_sysbios_heaps_HeapMem_reqAlign__C
000004c8 000004c8 00000004 00000004 r-- .const:ti_sysbios_knl_Clock_serviceMargin__C
000004cc 000004cc 00000004 00000004 r-- .const:ti_sysbios_knl_Mailbox_Object__count__C
000004d0 000004d0 00000004 00000004 r-- .const:ti_sysbios_knl_Mailbox_Object__table__C
000004d4 000004d4 00000004 00000004 r-- .const:ti_sysbios_knl_Queue_Object__count__C
000004d8 000004d8 00000004 00000004 r-- .const:ti_sysbios_knl_Queue_Object__table__C
000004dc 000004dc 00000004 00000004 r-- .const:ti_sysbios_knl_Swi_Object__count__C
000004e0 000004e0 00000004 00000004 r-- .const:ti_sysbios_knl_Swi_Object__table__C
000004e4 000004e4 00000004 00000004 r-- .const:ti_sysbios_knl_Swi_numPriorities__C
000004e8 000004e8 00000004 00000004 r-- .const:ti_sysbios_knl_Task_Object__count__C
000004ec 000004ec 00000004 00000004 r-- .const:ti_sysbios_knl_Task_Object__table__C
000004f0 000004f0 00000004 00000004 r-- .const:ti_sysbios_knl_Task_allBlockedFunc__C
000004f4 000004f4 00000004 00000004 r-- .const:ti_sysbios_knl_Task_defaultStackHeap__C
000004f8 000004f8 00000004 00000004 r-- .const:ti_sysbios_knl_Task_defaultStackSize__C
000004fc 000004fc 00000004 00000004 r-- .const:ti_sysbios_knl_Task_numConstructedTasks__C
00000502 00000502 00000002 00000002 r-- .const:ti_sysbios_family_arm_cc26xx_Timer_Module__id__C
00000504 00000504 00000002 00000002 r-- .const:ti_sysbios_family_arm_cc26xx_TimestampProvider_useClockTimer__C
00000506 00000506 00000002 00000002 r-- .const:ti_sysbios_family_arm_m3_Hwi_Module__id__C
00000508 00000508 00000002 00000002 r-- .const:ti_sysbios_gates_GateHwi_Module__id__C
0000050a 0000050a 00000002 00000002 r-- .const:ti_sysbios_gates_GateMutex_Module__id__C
0000050c 0000050c 00000002 00000002 r-- .const:ti_sysbios_heaps_HeapMem_Module__id__C
0000050e 0000050e 00000002 00000002 r-- .const:ti_sysbios_knl_Task_initStackFlag__C
00000510 00000510 00000001 00000001 r-- .const:ti_sysbios_knl_Clock_tickMode__C
00000514 00000514 00000008 00000008 r-- .const:xdc_runtime_Startup_firstFxns__C
0000051c 0000051c 00000008 00000008 r-- .const:xdc_runtime_Startup_lastFxns__C
00000524 00000524 00000004 00000004 r-- .const:xdc_runtime_Assert_E_assertFailed__C
00000528 00000528 00000004 00000004 r-- .const:xdc_runtime_Error_E_memory__C
0000052c 0000052c 00000004 00000004 r-- .const:xdc_runtime_Error_policyFxn__C
00000530 00000530 00000004 00000004 r-- .const:xdc_runtime_IGateProvider_Interface__BASE__C
00000534 00000534 00000004 00000004 r-- .const:xdc_runtime_IHeap_Interface__BASE__C
00000538 00000538 00000004 00000004 r-- .const:xdc_runtime_IModule_Interface__BASE__C
0000053c 0000053c 00000004 00000004 r-- .const:xdc_runtime_Main_Module__diagsEnabled__C
00000540 00000540 00000004 00000004 r-- .const:xdc_runtime_Main_Module__diagsIncluded__C
00000544 00000544 00000004 00000004 r-- .const:xdc_runtime_Main_Module__diagsMask__C
00000548 00000548 00000004 00000004 r-- .const:xdc_runtime_Memory_defaultHeapInstance__C
0000054c 0000054c 00000004 00000004 r-- .const:xdc_runtime_Startup_execImpl__C
00000550 00000550 00000004 00000004 r-- .const:xdc_runtime_Startup_maxPasses__C
00000554 00000554 00000004 00000004 r-- .const:xdc_runtime_Startup_sfxnRts__C
00000558 00000558 00000004 00000004 r-- .const:xdc_runtime_Startup_sfxnTab__C
0000055c 0000055c 00000004 00000004 r-- .const:xdc_runtime_Startup_startModsFxn__C
00000560 00000560 00000004 00000004 r-- .const:xdc_runtime_SysCallback_abortFxn__C
00000564 00000564 00000004 00000004 r-- .const:xdc_runtime_SysCallback_exitFxn__C
00000568 00000568 00000004 00000004 r-- .const:xdc_runtime_System_abortFxn__C
0000056c 0000056c 00000004 00000004 r-- .const:xdc_runtime_System_exitFxn__C
00000570 00000570 00000004 00000004 r-- .const:xdc_runtime_System_maxAtexitHandlers__C
00000574 00000574 00000004 00000004 r-- .const:xdc_runtime_Text_charTab__C
00000578 00000578 00000004 00000004 r-- .const:xdc_runtime_Text_nameEmpty__C
0000057c 0000057c 00000004 00000004 r-- .const:xdc_runtime_Text_nameStatic__C
00000580 00000580 00000004 00000004 r-- .const:xdc_runtime_Text_nameUnknown__C
00000584 00000584 00000002 00000002 r-- .const:xdc_runtime_Main_Module__id__C
00000586 00000586 00000002 00000002 r-- .const:xdc_runtime_Memory_Module__id__C
00000588 00000588 00000002 00000002 r-- .const:xdc_runtime_Text_charCnt__C
0000058a 0000058a 00000002 00000002 r-- .const:xdc_runtime_Text_isLoaded__C
0000058c 0000058c 00000001 00000001 r-- .const:xdc_runtime_Error_policy__C
00000590 00000590 00000004 00000004 r-- .const:ti_sysbios_rom_ROM_AONRTCChannelEnable
00000594 00000594 00000004 00000004 r-- .const:ti_sysbios_rom_ROM_AONRTCCompareValueSet
00000598 00000598 00000004 00000004 r-- .const:ti_sysbios_rom_ROM_AONRTCCurrentCompareValueGet
0000059c 0000059c 00000004 00000004 r-- .const:ti_sysbios_rom_ROM_AONRTCEventClear
000005a0 000005a0 00000004 00000004 r-- .const:ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_getCount64__E
000005a4 000005a4 00000004 00000004 r-- .const:ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_getCurrentTick__E
000005a8 000005a8 00000004 00000004 r-- .const:ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_getMaxTicks__E
000005ac 000005ac 00000004 00000004 r-- .const:ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_initDevice__I
000005b0 000005b0 00000004 00000004 r-- .const:ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_setNextTick__E
000005b4 000005b4 00000004 00000004 r-- .const:ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_setThreshold__I
000005b8 000005b8 00000004 00000004 r-- .const:ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_start__E
000005bc 000005bc 00000004 00000004 r-- .const:ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_TimestampProvider_get32__E
000005c0 000005c0 00000004 00000004 r-- .const:ti_sysbios_rom_ROM_xdc_runtime_Startup_getState__I
000005c4 000005c4 00000004 00000004 r-- .const:ti_sysbios_rom_ROM_xdc_runtime_System_SupportProxy_abort__E
000005c8 000005c8 00000004 00000004 r-- .const:ti_sysbios_rom_ROM_xdc_runtime_System_SupportProxy_exit__E
000005cc 000005cc 00000004 00000004 r-- .const:ti_sysbios_gates_GateMutex_Instance_State_sem__O
000005d0 000005d0 00000004 00000004 r-- .const:ti_sysbios_knl_Clock_Module_State_clockQ__O
000005d4 000005d4 00000004 00000004 r-- .const:ti_sysbios_knl_Mailbox_Instance_State_dataQue__O
000005d8 000005d8 00000004 00000004 r-- .const:ti_sysbios_knl_Mailbox_Instance_State_dataSem__O
000005dc 000005dc 00000004 00000004 r-- .const:ti_sysbios_knl_Mailbox_Instance_State_freeQue__O
000005e0 000005e0 00000004 00000004 r-- .const:ti_sysbios_knl_Mailbox_Instance_State_freeSem__O
000005e4 000005e4 00000004 00000004 r-- .const:ti_sysbios_knl_Semaphore_Instance_State_pendQ__O
000005e8 000005e8 00000004 00000004 r-- .const:ti_sysbios_knl_Task_Module_State_inactiveQ__O
000005ec 000005ec 00000058 00000058 r-- .ccfg
00001000 00001000 0000004c 0000004c r--
00001000 00001000 00000010 00000010 r-- .imgHdr
00001010 00001010 0000003c 0000003c r-- .resetVecs
00001010 00001010 0000c358 0000c358 r-x
00001010 00001010 00009e6c 00009e6c r-x .text
0000ae7c 0000ae7c 00001dc6 00001dc6 r-- .const
0000cc48 0000cc48 00000720 00000720 r-- .cinit
20000100 20000100 00000078 00000000 rw-
20000100 20000100 00000044 00000000 rw- .data:ti_sysbios_knl_Task_Module__state__V
20000144 20000144 00000034 00000000 rw- .data:ti_sysbios_family_arm_m3_Hwi_Module__state__V
20000148 20000148 00001709 00000000 rw-
20000148 20000148 00001709 00000000 rw- .data
20000178 20000178 0000008c 00000000 rw-
20000178 20000178 0000002c 00000000 rw- .data:ti_sysbios_knl_Clock_Module__state__V
200001a4 200001a4 00000024 00000000 rw- .data:ti_sysbios_BIOS_Module__state__V
200001c8 200001c8 0000001c 00000000 rw- .data:ti_sysbios_knl_Swi_Module__state__V
200001e4 200001e4 00000008 00000000 rw- .data:ti_sysbios_family_arm_cc26xx_Timer_Module__state__V
200001ec 200001ec 00000004 00000000 rw- .data:ti_sysbios_family_arm_cc26xx_TimestampProvider_Module__state__V
200001f0 200001f0 00000008 00000000 rw- .data:xdc_runtime_Startup_Module__state__V
200001f8 200001f8 00000008 00000000 rw- .data:xdc_runtime_System_Module__state__V
20000200 20000200 00000004 00000000 rw- .data:xdc_runtime_Memory_Module__state__V
20000430 20000430 00000010 00000000 rw-
20000430 20000430 00000010 00000000 rw- .TI.bound:dmaSpi0RxControlTableEntry$11
20000440 20000440 00000010 00000000 rw-
20000440 20000440 00000010 00000000 rw- .TI.bound:dmaSpi0TxControlTableEntry$11
20000500 20000500 00000010 00000000 rw-
20000500 20000500 00000010 00000000 rw- .TI.bound:dmaSpi1RxControlTableEntry$11
20000510 20000510 00000010 00000000 rw-
20000510 20000510 00000010 00000000 rw- .TI.bound:dmaSpi1TxControlTableEntry$11
20001858 20001858 00000c56 00000000 rw-
20001858 20001858 00000c56 00000000 rw- .bss
20003f18 20003f18 00000400 00000000 rw-
20003f18 20003f18 00000400 00000000 rw- .stack
SECTION ALLOCATION MAP
output attributes/
section page origin length input sections
.imgHdr 0 00001000 00000010
00001000 00000010 oad_target_external_flash.obj (.imgHdr:retain)
.text 0 00001010 00009e6c
00001010 00000408 SPICC26XXDMA.obj (.text:SPICC26XXDMA_open)
00001418 00000338 rom_sysbios.aem3 : rom_sysbios.obj (.text:xdc_runtime_System_doPrint__I)
00001750 000002ec peripheral.obj (.text:gapRole_processGAPMsg$25)
00001a3c 00000290 RFCC26XX_singleMode.obj (.text:fsmActiveState$9)
00001ccc 0000023c peripheral.obj (.text:GAPRole_SetParameter)
00001f08 00000228 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:Power_sleep)
00002130 00000204 driverlib.lib : sys_ctrl.obj (.text:NOROM_SysCtrlSetRechargeBeforePowerDown)
00002334 000001f8 SPICC26XXDMA.obj (.text:SPICC26XXDMA_configDMA$11)
0000252c 000001f8 simple_peripheral.obj (.text:SimpleBLEPeripheral_init$2)
00002724 000001f4 rtsv7M3_T_le_eabi.lib : ull_div_t2.obj (.text)
00002918 000001e4 SPICC26XXDMA.obj (.text:SPICC26XXDMA_hwiFxn$11)
00002afc 000001e4 SPICC26XXDMA.obj (.text:SPICC26XXDMA_transfer)
00002ce0 000001d0 drivers_cc26xxware.aem3 : PowerCC26XX_calibrateRCOSC.oem3 (.text:calibrateRcoscHf1)
00002eb0 000001b4 SPICC26XXDMA.obj (.text:SPICC26XXDMA_swiFxn$11)
00003064 000001b0 PINCC26XX.obj (.text:PIN_init)
00003214 0000019c RFCC26XX_singleMode.obj (.text:RF_postCmd)
000033b0 00000184 drivers_cc26xxware.aem3 : PowerCC26XX_calibrateRCOSC.oem3 (.text:PowerCC26XX_doCalibrate)
00003534 0000017c SPICC26XXDMA.obj (.text:SPICC26XXDMA_transferCancel)
000036b0 0000017c RFCC26XX_singleMode.obj (.text:abortCmd$9)
0000382c 00000174 RFCC26XX_singleMode.obj (.text:fsmSetupState$9)
000039a0 00000158 SPICC26XXDMA.obj (.text:SPICC26XXDMA_initIO$11)
00003af8 00000158 uart_logs.obj (.text:uartLog_doPrint$1)
00003c50 00000154 simple_gatt_profile.obj (.text:simpleProfile_WriteAttrCB$26)
00003da4 00000130 driverlib.lib : setup_rom.obj (.text:NOROM_SetupAfterColdResetWakeupFromShutDownCfg3)
00003ed4 00000120 peripheral.obj (.text:GAPRole_GetParameter)
00003ff4 0000011c drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:Power_init)
00004110 00000110 RFCC26XX_singleMode.obj (.text:hwiFxnCpe0Active$9)
00004220 00000104 RFCC26XX_singleMode.obj (.text:fsmPowerUpState$9)
00004324 000000fc peripheral.obj (.text:gapRole_taskFxn$25)
00004420 000000fc rtsv7M3_T_le_eabi.lib : fd_mul_t2.obj (.text)
0000451c 000000f8 app_ble_pem3.oem3 (.text:xdc_runtime_System_printfExtend__I)
00004614 000000ec icall.obj (.text:ICall_primWaitMatch$15)
00004700 000000ec RFCC26XX_singleMode.obj (.text:rf_init$9)
000047ec 000000e4 driverlib.lib : setup_rom.obj (.text:NOROM_SetupAfterColdResetWakeupFromShutDownCfg2)
000048d0 000000e0 SPICC26XXDMA.obj (.text:SPICC26XXDMA_initHw$11)
000049b0 000000e0 RFCC26XX_singleMode.obj (.text:radioOpDoneCb$9)
00004a90 000000dc PINCC26XX.obj (.text:PINCC26XX_setIoCfg$8)
00004b6c 000000dc SPICC26XXDMA.obj (.text:SPICC26XXDMA_control)
00004c48 000000d4 power_cc26xx_tirtos.aem3 : PowerCC26XX_tirtos.oem3 (.text:PowerCC26XX_standbyPolicy)
00004d1c 000000d4 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:Power_releaseDependency)
00004df0 000000d0 : PowerCC26XX.oem3 (.text:Power_setDependency)
00004ec0 000000cc simple_peripheral.obj (.text:SimpleBLEPeripheral_taskFxn$2)
00004f8c 000000c8 RFCC26XX_singleMode.obj (.text:RF_open)
00005054 000000c0 SPICC26XXDMA.obj (.text:SPICC26XXDMA_close)
00005114 000000bc driverlib.lib : setup.obj (.text:TrimAfterColdResetWakeupFromShutDown)
000051d0 000000b4 simple_peripheral.obj (.text:SimpleBLEPeripheral_processStateChangeEvt$2)
00005284 000000b0 devinfoservice.obj (.text:devInfo_ReadAttrCB$20)
00005334 000000ac oad.obj (.text:OAD_imgBlockWrite)
000053e0 000000ac oad.obj (.text:oadWriteAttrCB$23)
0000548c 000000a8 driverlib.lib : setup.obj (.text:NOROM_SetupTrimDevice)
00005534 000000a0 auto_init.aem3 : auto_init.oem3 (.text)
000055d4 000000a0 peripheral.obj (.text:gapRole_init$25)
00005674 0000009c oad.obj (.text:OAD_imgIdentifyWrite)
00005710 0000009c rtsv7M3_T_le_eabi.lib : memcpy_t2.obj (.text)
000057ac 0000009a rom_sysbios.aem3 : rom_sysbios.obj (.text:xdc_runtime_Text_putSite__E)
00005846 00000002 ble_user_config.obj (.text:DefaultAssertCback)
00005848 00000098 PINCC26XX.obj (.text:PIN_open)
000058e0 00000098 RFCC26XX_singleMode.obj (.text:fsmPowerDownState$9)
00005978 00000098 rom_sysbios.aem3 : rom_sysbios.obj (.text:ti_sysbios_knl_Clock_workFuncDynamic__E)
00005a10 00000094 disp750a.obj (.text:EPD_7IN5_V2_Init)
00005aa4 00000094 SPICC26XXDMA.obj (.text:SPICC26XXDMA_transferCallback$11)
00005b38 00000094 rom_sysbios.aem3 : rom_sysbios.obj (.text:xdc_runtime_Text_putMod__E)
00005bcc 00000090 oad.obj (.text:crcCalcDL$23)
00005c5c 00000090 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:switchXOSCHFclockFunc)
00005cec 0000008c driverlib.lib : osc.obj (.text:NOROM_OSCHF_GetStartupTime)
00005d78 00000084 icall.obj (.text:ICall_heapMalloc)
00005dfc 00000084 icall.obj (.text:ICall_primSetTimer$15)
00005e80 00000084 RFCC26XX_singleMode.obj (.text:RF_pendCmd)
00005f04 00000084 TRNGCC26XX.obj (.text:TRNGCC26XX_getNumber)
00005f88 00000084 RFCC26XX_singleMode.obj (.text:swiFxnHw$9)
0000600c 00000080 uart_logs.obj (.text:uartLog_outputFxn)
0000608c 0000007c icall.obj (.text:ICall_createRemoteTasks)
00006108 0000007c drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:disableLFClockQualifiers)
00006184 0000007a rtsv7M3_T_le_eabi.lib : memset_t2.obj (.text)
000061fe 00000002 driverlib.lib : rfc.obj (.text:NOROM_RFCAdi3VcoLdoVoltageMode)
00006200 00000078 : setup_rom.obj (.text:NOROM_SetupAfterColdResetWakeupFromShutDownCfg1)
00006278 00000078 oad.obj (.text:OAD_rejectImage$23)
000062f0 00000078 UDMACC26XX.obj (.text:UDMACC26XX_hwiIntFxn)
00006368 00000074 gattservapp_util.obj (.text:GATTServApp_ProcessCharCfg)
000063dc 00000074 icall_cc2650.obj (.text:ICallPlatform_pwrUpdActivityCounter)
00006450 00000074 icall.obj (.text:ICall_primSend$15)
000064c4 00000074 drivers_cc26xxware.aem3 : PowerCC26XX_calibrateRCOSC.oem3 (.text:PowerCC26XX_auxISR)
00006538 00000074 : PowerCC26XX_calibrateRCOSC.oem3 (.text:calibrateRcoscHf2)
000065ac 00000074 peripheral.obj (.text:gapRole_startConnUpdate$25)
00006620 00000070 driverlib.lib : chipinfo.obj (.text:NOROM_ChipInfo_GetHwRevision)
00006690 0000006e ExtFlash.obj (.text:ExtFlash_write)
000066fe 00000002 driverlib.lib : rfc.obj (.text:NOROM_RFCRTrim)
00006700 0000006d rom_sysbios.aem3 : rom_sysbios.obj (.text:xdc_runtime_System_formatNum__I)
0000676d 00000001 --HOLE-- [fill = 0]
0000676e 00000002 SPICC26XXDMA.obj (.text:SPICC26XXDMA_serviceISR$11)
00006770 0000006c icall.obj (.text:ICall_heapInit)
000067dc 0000006c driverlib.lib : setup_rom.obj (.text:NOROM_SetupGetTrimForAmpcompCtrl)
00006848 0000006c drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:PowerCC26XX_calibrate)
000068b4 0000006c main.obj (.text:main)
00006920 0000006a gattservapp_util.obj (.text:gattServApp_SendNotiInd$22)
0000698a 0000006a rtsv7M3_T_le_eabi.lib : copy_decompress_rle.obj (.text)
000069f4 00000068 driverlib.lib : setup_rom.obj (.text:NOROM_SetupGetTrimForAnabypassValue1)
00006a5c 00000068 : sys_ctrl.obj (.text:NOROM_SysCtrl_DCDC_VoltageConditionalControl)
00006ac4 00000068 oad_target_external_flash.obj (.text:OADTarget_getCurrentImageHeader)
00006b2c 00000068 RFCC26XX_singleMode.obj (.text:decActiveClientCnt$9)
00006b94 00000068 uart_logs.obj (.text:uartLog_flush)
00006bfc 00000064 PINCC26XX.obj (.text:PIN_add)
00006c60 00000064 rom_sysbios.aem3 : rom_sysbios.obj (.text:ti_sysbios_family_arm_cc26xx_Timer_start__E)
00006cc4 00000060 icall.obj (.text:ICall_primEnroll$15)
00006d24 00000060 oad.obj (.text:OAD_sendStatus$23)
00006d84 00000060 drivers_cc26xxware.aem3 : PowerCC26XX_calibrateRCOSC.oem3 (.text:PowerCC26XX_RCOSC_clockFunc)
00006de4 00000060 RFCC26XX_singleMode.obj (.text:RF_getCurrentTime)
00006e44 00000060 drivers_cc26xxware.aem3 : PowerCC26XX_calibrateRCOSC.oem3 (.text:updateSubSecInc)
00006ea4 0000005c ExtFlash.obj (.text:ExtFlash_erase)
00006f00 0000005c icall.obj (.text:ICall_primThreadServes$15)
00006f5c 0000005c driverlib.lib : osc.obj (.text:NOROM_OSCHF_AttemptToSwitchToXosc)
00006fb8 0000005c : sys_ctrl.obj (.text:NOROM_SysCtrlAdjustRechargeAfterPowerDown)
00007014 0000005c oad_target_external_flash.obj (.text:OADTarget_validateNewImage)
00007070 0000005c oad.obj (.text:OAD_getNextBlockReq$23)
000070cc 0000005c UDMACC26XX.obj (.text:UDMACC26XX_open)
00007128 0000005c RFCC26XX_singleMode.obj (.text:applyRfCorePatch$9)
00007184 0000005c RFCC26XX_singleMode.obj (.text:fsmXOSCState$9)
000071e0 0000005c simple_gatt_profile.obj (.text:simpleProfile_ReadAttrCB$26)
0000723c 0000005c app_ble_pem3.oem3 (.text:xdc_runtime_Startup_getState__I)
00007298 0000005b rom_sysbios.aem3 : rom_sysbios.obj (.text:xdc_runtime_Text_putLab__E)
000072f3 00000001 --HOLE-- [fill = 0]
000072f4 00000058 oad.obj (.text:OAD_addService)
0000734c 00000058 PINCC26XX.obj (.text:PIN_remove)
000073a4 00000058 drivers_cc26xxware.aem3 : PowerCC26XX_calibrateRCOSC.oem3 (.text:PowerCC26XX_initiateCalibration)
000073fc 00000058 simple_gatt_profile.obj (.text:SimpleProfile_SetParameter)
00007454 00000056 gattservapp_util.obj (.text:GATTServApp_ProcessCCCWriteReq)
000074aa 00000002 RFCC26XX_singleMode.obj (.text:defaultErrCb$9)
000074ac 00000054 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:configureXOSCHF)
00007500 00000054 RFCC26XX_singleMode.obj (.text:hwiFxnHw$9)
00007554 00000054 RFCC26XX_singleMode.obj (.text:ratChanFree$9)
000075a8 00000052 icall.obj (.text:ICall_primWait$15)
000075fa 00000002 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:emptyClockFunc)
000075fc 00000050 disp750a.obj (.text:DEV_SPI_WriteByte)
0000764c 00000050 icall_api.obj (.text:GAP_DeviceInit)
0000769c 00000050 icall_api.obj (.text:GAP_UpdateAdvertisingData)
000076ec 00000050 icall.obj (.text:ICall_primRegisterApp$15)
0000773c 00000050 driverlib.lib : setup_rom.obj (.text:NOROM_SetupSetCacheModeAccordingToCcfgSetting)
0000778c 00000050 RFCC26XX_singleMode.obj (.text:RF_getInfo)
000077dc 00000050 oad.obj (.text:checkDL$23)
0000782c 00000050 RFCC26XX_singleMode.obj (.text:syncCb$9)
0000787c 0000004c ExtFlash.obj (.text:ExtFlash_waitReady$19)
000078c8 0000004c icall_cc2650.obj (.text:ICallPlatform_pwrRegisterNotify)
00007914 0000004c icall.obj (.text:ICall_newTask$15)
00007960 0000004c icall.obj (.text:ICall_primGetEntityId$15)
000079ac 0000004c driverlib.lib : osc.obj (.text:NOROM_OSCClockSourceSet)
000079f8 0000004c peripheral.obj (.text:gapRole_processStackMsg$25)
00007a44 0000004c rtsv7M3_T_le_eabi.lib : cpy_tbl.obj (.text)
00007a90 0000004c rom_sysbios.aem3 : rom_sysbios.obj (.text:xdc_runtime_Text_visitRope2__I)
00007adc 00000048 driverlib.lib : chipinfo.obj (.text:NOROM_ChipInfo_GetChipFamily)
00007b24 00000048 : ddi.obj (.text:NOROM_DDI16BitfieldWrite)
00007b6c 00000048 simple_peripheral.obj (.text:SimpleBLEPeripheral_processOadWriteCB)
00007bb4 00000048 util.obj (.text:Util_constructClock)
00007bfc 00000048 icall_api.obj (.text:gattIndNoti$18)
00007c44 00000048 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:notify)
00007c8c 00000048 rtsv7M3_T_le_eabi.lib : fd_toi_t2.obj (.text)
00007cd4 00000044 main.obj (.text:AssertHandler)
00007d18 00000044 disp750a.obj (.text:EPD_4IN2_Reset)
00007d5c 00000044 icall_api.obj (.text:GAP_TerminateLinkReq)
00007da0 00000044 PINCC26XX.obj (.text:PIN_swi$8)
00007de4 00000044 simple_gatt_profile.obj (.text:SimpleProfile_GetParameter)
00007e28 00000044 boot.aem3 : boot.oem3 (.text)
00007e6c 00000044 icall_api.obj (.text:gapSendParamAndPtrCmd$18)
00007eb0 00000044 rtsv7M3_T_le_eabi.lib : exit.obj (.text)
00007ef4 00000044 rom_sysbios.aem3 : rom_sysbios.obj (.text:xdc_runtime_LoggerCallback_write8__E)
00007f38 00000044 : rom_sysbios.obj (.text:xdc_runtime_Text_xprintf__I)
00007f7c 00000042 icall.obj (.text:ICall_primCreateTask$15)
00007fbe 00000002 rtsv7M3_T_le_eabi.lib : i_div0.obj (.text)
00007fc0 00000040 ExtFlash.obj (.text:ExtFlash_open)
00008000 00000040 ExtFlash.obj (.text:ExtFlash_read)
00008040 00000040 peripheral.obj (.text:GAPRole_SendUpdateParam)
00008080 00000040 peripheral.obj (.text:GAPRole_createTask)
000080c0 00000040 icall_api.obj (.text:GATT_SendRsp)
00008100 00000040 driverlib.lib : ddi.obj (.text:NOROM_DDI16BitfieldRead)
00008140 00000040 oad_target_external_flash.obj (.text:OADTarget_storeImageHeader)
00008180 00000040 RFCC26XX_singleMode.obj (.text:RF_getRssi)
000081c0 00000040 ExtFlash.obj (.text:extFlashVerifyPart$19)
00008200 00000040 rtsv7M3_T_le_eabi.lib : u_divt2.obj (.text)
00008240 00000040 rom_sysbios.aem3 : rom_sysbios.obj (.text:xdc_runtime_LoggerCallback_Module_startup__E)
00008280 0000003e icall_api.obj (.text:hciSendParamsCmd$18)
000082be 00000002 rom_sysbios.aem3 : rom_sysbios.obj (.text:ti_sysbios_BIOS_linkedWithIncorrectBootLibrary__E)
000082c0 0000003c ExtFlash.obj (.text:ExtFlash_readInfo$19)
000082fc 0000003c icall_api.obj (.text:GAP_GetParamValue)
00008338 0000003c icall_api.obj (.text:GATTServApp_RegisterService)
00008374 0000003c icall_cc2650.obj (.text:ICallPlatform_pwrConfigACAction)
000083b0 0000003c driverlib.lib : osc.obj (.text:NOROM_OSC_HPOSCRelativeFrequencyOffsetGet)
000083ec 0000003c : rfc.obj (.text:NOROM_RFCSynthPowerDown)
00008428 0000003c PINCC26XX.obj (.text:PINCC26XX_getConfig)
00008464 0000003c RFCC26XX_singleMode.obj (.text:RF_runCmd)
000084a0 0000003c SPICC26XXDMA.obj (.text:SPICC26XXDMA_csnCallback$11)
000084dc 0000003c simple_peripheral.obj (.text:SimpleBLEPeripheral_createTask)
00008518 0000003c RFCC26XX_singleMode.obj (.text:dispatchOpWhen$9)
00008554 0000003c oad.obj (.text:oadReadAttrCB$23)
00008590 0000003c RFCC26XX_singleMode.obj (.text:postDirImmCmd$9)
000085cc 0000003c icall_api.obj (.text:profileSetParameter$18)
00008608 0000003c icall_api.obj (.text:sendWaitMatchCS$18)
00008644 0000003c icall_api.obj (.text:sendWaitMatchValueCS$18)
00008680 00000038 icall_api.obj (.text:GAPBondMgr_LinkEst)
000086b8 00000038 icall.obj (.text:ICall_primGetMaxMSecs$15)
000086f0 00000038 PINCC26XX.obj (.text:PIN_setOutputValue)
00008728 00000038 simple_peripheral.obj (.text:SimpleBLEPeripheral_sendAttRsp$2)
00008760 00000038 ExtFlash.obj (.text:Spi_open$19)
00008798 00000038 util.obj (.text:Util_restartClock)
000087d0 00000038 icall_api.obj (.text:linkDB_NumActive)
00008808 00000038 icall_api.obj (.text:linkDB_NumConns)
00008840 00000038 icall_api.obj (.text:registerTask$18)
00008878 00000038 rom_sysbios.aem3 : rom_sysbios.obj (.text:ti_sysbios_family_arm_cc26xx_Timer_getCurrentTick__E)
000088b0 00000036 UDMACC26XX.obj (.text:UDMACC26XX_close)
000088e6 00000036 RFCC26XX_singleMode.obj (.text:updateImplicitState$9)
0000891c 00000034 disp750a.obj (.text:EPD_2IN66_SendCommand)
00008950 00000034 disp750a.obj (.text:EPD_2IN66_SendData)
00008984 00000034 icall_api.obj (.text:GAPBondMgr_SetParameter)
000089b8 00000034 icall_api.obj (.text:GAP_SetParamValue)
000089ec 00000034 icall.obj (.text:ICall_primEntityId2ServiceId$15)
00008a20 00000034 icall.obj (.text:ICall_primFetchMsg$15)
00008a54 00000034 icall.obj (.text:ICall_primRegisterISR$15)
00008a88 00000034 icall.obj (.text:ICall_primRegisterISR_Ext$15)
00008abc 00000034 icall.obj (.text:ICall_searchServiceEntity)
00008af0 00000034 driverlib.lib : osc.obj (.text:NOROM_OSCHF_SwitchToRcOscTurnOffXosc)
00008b24 00000034 : trng.obj (.text:NOROM_TRNGConfigure)
00008b58 00000034 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:PowerCC26XX_isStableXOSC_HF)
00008b8c 00000034 RFCC26XX_singleMode.obj (.text:Q_push$9)
00008bc0 00000034 simple_peripheral.obj (.text:SimpleBLEPeripheral_processGATTMsg$2)
00008bf4 00000034 icall_api.obj (.text:linkDB_GetInfo)
00008c28 00000034 icall_api.obj (.text:osal_snv_read)
00008c5c 00000034 icall_api.obj (.text:osal_snv_write)
00008c90 00000034 icall_api.obj (.text:profileAddService$18)
00008cc4 00000034 rom_sysbios.aem3 : rom_sysbios.obj (.text:xdc_runtime_LoggerCallback_write4__E)
00008cf8 00000032 icall_api.obj (.text:gapSendParamsCmd$18)
00008d2a 00000032 icall_api.obj (.text:gapSendPtrParamsCmd$18)
00008d5c 00000032 icall_api.obj (.text:matchGapSetGetParamCS$18)
00008d8e 00000032 icall_api.obj (.text:matchGattCmdStatus$18)
00008dc0 00000032 icall_api.obj (.text:matchUtilNvCS$18)
00008df2 00000032 rom_sysbios.aem3 : rom_sysbios.obj (.text:ti_sysbios_family_arm_cc26xx_Timer_setNextTick__E)
00008e24 00000030 disp750a.obj (.text:EPD_4IN2_ReadBusy)
00008e54 00000030 disp750a.obj (.text:EPD_7IN5_V2_Clear)
00008e84 00000030 ExtFlash.obj (.text:ExtFlash_close)
00008eb4 00000030 ExtFlash.obj (.text:ExtFlash_writeEnable$19)
00008ee4 00000030 icall_cc2650.obj (.text:ICallPlatform_pwrNotify$16)
00008f14 00000030 icall.obj (.text:ICall_msecs2Ticks$15)
00008f44 00000030 icall.obj (.text:ICall_searchTask$15)
00008f74 00000030 driverlib.lib : setup_rom.obj (.text:NOROM_SetupSetAonRtcSubSecInc)
00008fa4 00000030 PINCC26XX.obj (.text:PIN_setInterrupt)
00008fd4 00000030 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:Power_releaseConstraint)
00009004 00000030 : PowerCC26XX.oem3 (.text:Power_setConstraint)
00009034 00000030 SPI.obj (.text:SPI_open)
00009064 00000030 ExtFlash.obj (.text:Spi_read$19)
00009094 00000030 ExtFlash.obj (.text:Spi_write$19)
000090c4 00000030 oad.obj (.text:crc16$23)
000090f4 00000030 oad_target_external_flash.obj (.text:saveImageInfo)
00009124 00000030 app_ble_pem3.oem3 (.text:ti_sysbios_BIOS_atExitFunc__I)
00009154 00000030 app_ble_pem3.oem3 (.text:ti_sysbios_BIOS_startFunc__I)
00009184 00000030 rom_sysbios.aem3 : rom_sysbios.obj (.text:ti_sysbios_family_arm_cc26xx_Timer_initDevice__I)
000091b4 00000030 : rom_sysbios.obj (.text:ti_sysbios_family_arm_cc26xx_Timer_setThreshold__I)
000091e4 00000030 app_ble_pem3.oem3 (.text:xdc_runtime_LoggerCallback_Object__create__S)
00009214 0000002f rom_sysbios.aem3 : rom_sysbios.obj (.text:xdc_runtime_Text_printVisFxn__I)
00009243 00000001 --HOLE-- [fill = 0]
00009244 0000002e icall_cc2650.obj (.text:ICallPlatform_pwrDispenseImpl$16)
00009272 0000002e icall_cc2650.obj (.text:ICallPlatform_pwrRequireImpl$16)
000092a0 0000002e peripheral.obj (.text:ICall_fetchServiceMsg$25)
000092ce 0000002e simple_peripheral.obj (.text:ICall_fetchServiceMsg$2)
000092fc 0000002e icall.obj (.text:ICall_msgDequeue$15)
0000932a 0000002e icall_api.obj (.text:matchProfileAddServiceCS$18)
00009358 0000002c icall_api.obj (.text:GAPBondMgr_Register)
00009384 0000002c icall_api.obj (.text:HCI_EXT_ConnEventNoticeCmd)
000093b0 0000002c icall.obj (.text:ICall_heapFree)
000093dc 0000002c oad.obj (.text:ICall_malloc$23)
00009408 0000002c simple_gatt_profile.obj (.text:ICall_malloc$26)
00009434 0000002c icall.obj (.text:ICall_msgEnqueue$15)
00009460 0000002c icall.obj (.text:ICall_primAllocMsg$15)
0000948c 0000002c icall.obj (.text:ICall_primFetchServiceMsg$15)
000094b8 0000002c icall_api.obj (.text:ICall_sendServiceMsg$18)
000094e4 0000002c driverlib.lib : ddi.obj (.text:NOROM_DDI32RegWrite)
00009510 0000002c : setup_rom.obj (.text:NOROM_SetupGetTrimForRadcExtCfg)
0000953c 0000002c PINCC26XX.obj (.text:PINCC26XX_setMux)
00009568 0000002c PINCC26XX.obj (.text:PIN_setConfig)
00009594 0000002c ExtFlash.obj (.text:extFlashPowerStandby$19)
000095c0 0000002c RFCC26XX_singleMode.obj (.text:getCmd$9)
000095ec 0000002c icall_api.obj (.text:hciSendCmd$18)
00009618 0000002c rom_sysbios.aem3 : rom_sysbios.obj (.text:ti_sysbios_knl_Clock_getTicksUntilInterrupt__E)
00009644 0000002c : rom_sysbios.obj (.text:xdc_runtime_LoggerCallback_write2__E)
00009670 0000002a icall_api.obj (.text:ICall_waitMatch$18)
0000969a 0000002a TRNGCC26XX.obj (.text:TRNGCC26XX_isParamValid)
000096c4 0000002a util.obj (.text:Util_enqueueMsg)
000096ee 0000002a icall_api.obj (.text:matchProfileCS$18)
00009718 0000002a rom_sysbios.aem3 : rom_sysbios.obj (.text:xdc_runtime_System_putchar__I)
00009742 00000028 gattservapp_util.obj (.text:GATTServApp_WriteCharCfg)
0000976a 00000002 app_ble_pem3.oem3 (.text:ti_sysbios_BIOS_nullFunc__I)
0000976c 00000028 icall.obj (.text:ICall_init)
00009794 00000028 icall.obj (.text:ICall_msgPrepend$15)
000097bc 00000028 peripheral.obj (.text:ICall_registerApp$25)
000097e4 00000028 simple_peripheral.obj (.text:ICall_registerApp$2)
0000980c 00000028 driverlib.lib : aon_batmon.obj (.text:NOROM_AONBatMonTemperatureGetDegC)
00009834 00000028 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:PowerCC26XX_switchXOSC_HF)
0000985c 00000028 : PowerCC26XX.oem3 (.text:Power_registerNotify)
00009884 00000028 SPICC26XXDMA.obj (.text:SPICC26XXDMA_flushFifos$11)
000098ac 00000028 driverlib.lib : adi.obj (.text:SafeHapiVoid)
000098d4 00000028 simple_peripheral.obj (.text:SimpleBLEPeripheral_freeAttRsp$2)
000098fc 00000028 simple_peripheral.obj (.text:SimpleBLEPeripheral_processStackMsg$2)
00009924 00000028 simple_gatt_profile.obj (.text:SimpleProfile_AddService)
0000994c 00000028 TRNGCC26XX.obj (.text:TRNGCC26XX_init)
00009974 00000028 RFCC26XX_singleMode.obj (.text:clkPowerUpFxn$9)
0000999c 00000028 gattservapp_util.obj (.text:gattServApp_FindCharCfgItem$22)
000099c4 00000028 rom_sysbios.aem3 : rom_sysbios.obj (.text:ti_sysbios_family_arm_cc26xx_Timer_getMaxTicks__E)
000099ec 00000028 : rom_sysbios.obj (.text:xdc_runtime_LoggerCallback_write0__E)
00009a14 00000028 : rom_sysbios.obj (.text:xdc_runtime_LoggerCallback_write1__E)
00009a3c 00000026 drivers_cc26xxware.aem3 : List.oem3 (.text:List_put)
00009a62 00000024 icall_api.obj (.text:GAPBondMgr_LinkTerm)
00009a86 00000024 icall_api.obj (.text:ICall_getLocalMsgEntityId$18)
00009aaa 00000024 icall_api.obj (.text:ICall_threadServes$18)
00009ace 00000002 rom_sysbios.aem3 : rom_sysbios.obj (.text:ti_sysbios_knl_Clock_triggerFunc__I)
00009ad0 00000024 PINCC26XX.obj (.text:PINCC26XX_getPinCount)
00009af4 00000024 simple_peripheral.obj (.text:SimpleBLEPeripheral_enqueueMsg$2)
00009b18 00000024 oad_target_external_flash.obj (.text:getImageFlag)
00009b3c 00000024 drivers_cc26xxware.aem3 : PowerCC26XX_calibrateRCOSC.oem3 (.text:getTdcSemaphore)
00009b60 00000024 RFCC26XX_singleMode.obj (.text:hwiFxnCpe0PowerFsm$9)
00009b84 00000024 app_ble_pem3.oem3 (.text:ti_sysbios_BIOS_registerRTSLock__I)
00009ba8 00000024 app_ble_pem3.oem3 (.text:ti_sysbios_BIOS_removeRTSLock__I)
00009bcc 00000024 rom_sysbios.aem3 : rom_sysbios.obj (.text:ti_sysbios_family_arm_m3_Hwi_cc26xxRomInitNVIC__I)
00009bf0 00000022 icall.obj (.text:ICall_dispatch$15)
00009c12 00000022 util.obj (.text:ICall_malloc$3)
00009c34 00000022 rtsv7M3_T_le_eabi.lib : memcmp.obj (.text)
00009c56 00000002 app_ble_pem3.oem3 (.text:ti_sysbios_rom_cortexm_cc26xx_CC26xx_badRomRevision__E)
00009c58 00000020 gattservapp_util.obj (.text:GATTServApp_InitCharCfg)
00009c78 00000020 icall_api.obj (.text:ICall_allocMsg$18)
00009c98 00000020 icall_api.obj (.text:ICall_getEntityId$18)
00009cb8 00000020 simple_peripheral.obj (.text:ICall_malloc$2)
00009cd8 00000020 icall.obj (.text:ICall_primService$15)
00009cf8 00000020 icall.obj (.text:ICall_searchService$15)
00009d18 00000020 driverlib.lib : rfc.obj (.text:NOROM_RFCDoorbellSendTo)
00009d38 00000020 : rfc.obj (.text:NOROM_RFCRfTrimRead)
00009d58 00000020 : setup_rom.obj (.text:NOROM_SetupGetTrimForXoscHfCtl)
00009d78 00000020 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:Power_unregisterNotify)
00009d98 00000020 UDMACC26XX.obj (.text:UDMACC26XX_initHw$14)
00009db8 00000020 RFCC26XX_singleMode.obj (.text:allocCmd$9)
00009dd8 00000020 rtsv7M3_T_le_eabi.lib : u_tofd_t2.obj (.text)
00009df8 00000020 app_ble_pem3.oem3 (.text:ti_sysbios_BIOS_rtsLock__I)
00009e18 00000020 rom_sysbios.aem3 : rom_sysbios.obj (.text:ti_sysbios_knl_Clock_stop__E)
00009e38 00000020 : rom_sysbios.obj (.text:xdc_runtime_Registry_findById__E)
00009e58 0000001e icall.obj (.text:ICall_primSendServiceMsg$15)
00009e76 0000001e PINCC26XX.obj (.text:PIN_close)
00009e94 0000001e drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:Power_getTransitionLatency)
00009eb2 0000001e icall_api.obj (.text:matchHciCS$18)
00009ed0 0000001e icall_api.obj (.text:waitMatchCS$18)
00009eee 00000002 rom_sysbios.aem3 : rom_sysbios.obj (.text:xdc_runtime_SysCallback_defaultAbort)
00009ef0 0000001c peripheral.obj (.text:GAPRole_StartDevice)
00009f0c 0000001c icall_api.obj (.text:GATT_bm_alloc)
00009f28 0000001c icall_api.obj (.text:GATT_bm_free)
00009f44 0000001c icall.obj (.text:ICall_initPrim$15)
00009f60 0000001c peripheral.obj (.text:ICall_wait$25)
00009f7c 0000001c simple_peripheral.obj (.text:ICall_wait$2)
00009f98 0000001c driverlib.lib : osc.obj (.text:NOROM_OSCClockSourceGet)
00009fb4 0000001c : setup_rom.obj (.text:NOROM_SetupGetTrimForAmpcompTh2)
00009fd0 0000001c : setup_rom.obj (.text:NOROM_SetupGetTrimForRcOscLfRtuneCtuneTrim)
00009fec 0000001c PINCC26XX.obj (.text:PINCC26XX_setIoCfgMux$8)
0000a008 0000001c PINCC26XX.obj (.text:PIN_hwi$8)
0000a024 0000001c RFCC26XX_singleMode.obj (.text:RF_runDirectCmd)
0000a040 0000001c RFCC26XX_singleMode.obj (.text:RF_runImmediateCmd)
0000a05c 0000001c TRNGCC26XX.obj (.text:TRNGCC26XX_open)
0000a078 0000001c peripheral.obj (.text:gapRole_HandleParamUpdateNoSuccess$25)
0000a094 0000001c icall_api.obj (.text:getStatusValueFromErrNo$18)
0000a0b0 0000001c TRNGCC26XX.obj (.text:openTRNG)
0000a0cc 0000001c rom_sysbios.aem3 : rom_sysbios.obj (.text:ti_sysbios_family_arm_cc26xx_Timer_dynamicStub__E)
0000a0e8 0000001c : rom_sysbios.obj (.text:xdc_runtime_LoggerCallback_Instance_init__E)
0000a104 0000001a icall_api.obj (.text:GATT_Notification)
0000a11e 0000001a icall.obj (.text:ICall_enterCSImpl)
0000a138 0000001a icall.obj (.text:ICall_primSetTimerMSecs$15)
0000a152 0000001a drivers_cc26xxware.aem3 : List.oem3 (.text:List_remove)
0000a16c 0000001a simple_peripheral.obj (.text:SimpleBLEPeripheral_processAppMsg$2)
0000a186 0000001a util.obj (.text:Util_dequeueMsg)
0000a1a0 0000001a ExtFlash.obj (.text:extFlashPowerDown$19)
0000a1ba 0000001a icall_api.obj (.text:matchGattIndNotiCS$18)
0000a1d4 0000001a rom_sysbios.aem3 : rom_sysbios_config.obj (.text:xdc_runtime_System_snprintf__E)
0000a1ee 00000002 : rom_sysbios.obj (.text:xdc_runtime_SysCallback_defaultExit)
0000a1f0 00000018 oad.obj (.text:CheckImageDownloadCount$23)
0000a208 00000018 peripheral.obj (.text:GAPRole_TerminateConnection)
0000a220 00000018 icall_cc2650.obj (.text:ICallPlatform_pwrDispense)
0000a238 00000018 icall_cc2650.obj (.text:ICallPlatform_pwrRequire)
0000a250 00000018 oad.obj (.text:ICall_free$23)
0000a268 00000018 simple_peripheral.obj (.text:ICall_free$2)
0000a280 00000018 util.obj (.text:ICall_free$3)
0000a298 00000018 icall.obj (.text:ICall_freeMsg$15)
0000a2b0 00000018 icall_api.obj (.text:ICall_freeMsg$18)
0000a2c8 00000018 peripheral.obj (.text:ICall_freeMsg$25)
0000a2e0 00000018 simple_peripheral.obj (.text:ICall_freeMsg$2)
0000a2f8 00000018 icall.obj (.text:ICall_primMalloc$15)
0000a310 00000018 driverlib.lib : aon_rtc.obj (.text:NOROM_AONRTCCurrentCompareValueGet)
0000a328 00000018 : chipinfo.obj (.text:NOROM_ChipInfo_GetPackageType)
0000a340 00000018 : osc.obj (.text:NOROM_OSCHF_TurnOnXosc)
0000a358 00000018 : rfc.obj (.text:NOROM_RFCCpeIntGetAndClear)
0000a370 00000018 : setup_rom.obj (.text:NOROM_SetupGetTrimForAdcShModeEn)
0000a388 00000018 : setup_rom.obj (.text:NOROM_SetupGetTrimForAdcShVbufEn)
0000a3a0 00000018 : setup_rom.obj (.text:NOROM_SetupGetTrimForAmpcompTh1)
0000a3b8 00000018 : setup_rom.obj (.text:NOROM_SetupGetTrimForDblrLoopFilterResetVoltage)
0000a3d0 00000018 : setup_rom.obj (.text:NOROM_SetupGetTrimForRcOscLfIBiasTrim)
0000a3e8 00000018 : setup_rom.obj (.text:NOROM_SetupGetTrimForXoscLfRegulatorAndCmirrwrRatio)
0000a400 00000018 oad_target_external_flash.obj (.text:OADTarget_open)
0000a418 00000018 PINCC26XX.obj (.text:PIN_getConfig)
0000a430 00000018 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:Power_idleFunc)
0000a448 00000018 RFCC26XX_singleMode.obj (.text:Q_pop$9)
0000a460 00000018 simple_peripheral.obj (.text:SimpleBLEPeripheral_performPeriodicTask$2)
0000a478 00000018 ExtFlash.obj (.text:Spi_close$19)
0000a490 00000018 ExtFlash.obj (.text:Spi_flash$19)
0000a4a8 00000018 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:configureRFCoreClocks)
0000a4c0 00000018 peripheral.obj (.text:gapRole_setEvent$25)
0000a4d8 00000018 rtsv7M3_T_le_eabi.lib : args_main.obj (.text)
0000a4f0 00000018 : ll_mul_t2.obj (.text)
0000a508 00000018 RFCC26XX_singleMode.obj (.text:swiFxnFsm$9)
0000a520 00000018 app_ble_pem3.oem3 (.text:ti_sysbios_BIOS_rtsUnlock__I)
0000a538 00000008 (.tramp.ti_sysbios_BIOS_RtsGateProxy_leave__E.1)
0000a540 00000018 rom_sysbios.aem3 : rom_sysbios.obj (.text:ti_sysbios_knl_Swi_or__E)
0000a558 00000018 app_ble_pem3.oem3 (.text:ti_sysbios_rom_cortexm_cc26xx_CC26xx_checkRevision__E)
0000a570 00000016 icall.obj (.text:ICall_abort$15)
0000a586 00000016 icall.obj (.text:ICall_leaveCSImpl)
0000a59c 00000016 icall.obj (.text:ICall_primStopTimer$15)
0000a5b2 00000016 simple_peripheral.obj (.text:SimpleBLEPeripheral_processCharValueChangeEvt$2)
0000a5c8 00000016 ble_user_config.obj (.text:driverTable_fnSpinlock)
0000a5de 00000016 app_ble_pem3.oem3 (.text:ti_sysbios_BIOS_exitFunc__I)
0000a5f4 00000014 devinfoservice.obj (.text:DevInfo_AddService)
0000a608 00000014 ExtFlash.obj (.text:ExtFlash_powerDown$19)
0000a61c 00000014 driverlib.lib : aon_rtc.obj (.text:NOROM_AONRTCCurrent64BitValueGet)
0000a630 00000014 : chipinfo.obj (.text:NOROM_ThisCodeIsBuiltForCC26xxHwRev22AndLater_HaltIfViolated)
0000a644 00000014 oad_target_external_flash.obj (.text:OADTarget_close)
0000a658 00000014 oad_target_external_flash.obj (.text:OADTarget_writeFlash)
0000a66c 00000014 oad.obj (.text:OAD_register)
0000a680 00000014 PINCC26XX.obj (.text:PINCC26XX_getInputValue$8)
0000a694 00000014 RFCC26XX_singleMode.obj (.text:RF_Params_init)
0000a6a8 00000014 SPI.obj (.text:SPI_Params_init)
0000a6bc 00000014 simple_peripheral.obj (.text:SimpleBLEPeripheral_clockHandler$2)
0000a6d0 00000014 simple_gatt_profile.obj (.text:SimpleProfile_RegisterAppCBs)
0000a6e4 00000014 rtsv7M3_T_le_eabi.lib : _lock.obj (.text)
0000a6f8 00000014 : strlen.obj (.text)
0000a70c 00000014 icall_api.obj (.text:setICallCmdEvtHdr$18)
0000a720 00000014 app_ble_pem3.oem3 (.text:ti_sysbios_knl_Clock_doTick__I)
0000a734 00000008 (.tramp.ti_sysbios_knl_Clock_logTick__E.1)
0000a73c 00000012 gattservapp_util.obj (.text:GATTServApp_FindAttr)
0000a74e 00000012 RFCC26XX_singleMode.obj (.text:RF_getCmdOp)
0000a760 00000012 app_ble_pem3.oem3 (.text:xdc_runtime_Startup_exec__I)
0000a772 00000002 rom_sysbios.aem3 : rom_sysbios.obj (.text:xdc_runtime_SysCallback_defaultPutch)
0000a774 00000008 (.tramp.xdc_runtime_Startup_startMods__I.1)
0000a77c 00000010 devinfoservice.obj (.text:DevInfo_SetParameter)
0000a78c 00000010 RFCC26XX_singleMode.obj (.text:FsmDispatch$9)
0000a79c 00000010 icall_api.obj (.text:GAP_EndDiscoverable)
0000a7ac 00000010 gattservapp_util.obj (.text:GATTServApp_ReadCharCfg)
0000a7bc 00000010 icall_api.obj (.text:HCI_LE_ReadMaxDataLenCmd)
0000a7cc 00000010 icall_cc2650.obj (.text:ICallPlatform_pwrGetXOSCStartupTime)
0000a7dc 00000010 icall.obj (.text:ICall_primGetTickPeriod$15)
0000a7ec 00000010 icall.obj (.text:ICall_taskEntry$15)
0000a7fc 00000010 driverlib.lib : rfc.obj (.text:NOROM_RFCRfTrimSet)
0000a80c 00000010 : setup_rom.obj (.text:NOROM_SetupGetTrimForXoscHfFastStart)
0000a81c 00000010 : setup_rom.obj (.text:NOROM_SetupGetTrimForXoscHfIbiastherm)
0000a82c 00000010 oad_target_external_flash.obj (.text:OADTarget_getCrc)
0000a83c 00000010 oad_target_external_flash.obj (.text:OADTarget_setCrc)
0000a84c 00000010 oad_target_external_flash.obj (.text:OADTarget_systemReset)
0000a85c 00000010 ble_user_config.obj (.text:RegisterAssertCback)
0000a86c 00000010 util.obj (.text:Util_isActive)
0000a87c 00000010 ExtFlash.obj (.text:extFlashDeselect$19)
0000a88c 00000010 ExtFlash.obj (.text:extFlashSelect$19)
0000a89c 00000010 rom_sysbios.aem3 : rom_sysbios.obj (.text:ti_sysbios_family_arm_m3_Hwi_post__E)
0000a8ac 00000010 app_ble_pem3.oem3 (.text:xdc_runtime_LoggerCallback_Object__get__S)
0000a8bc 00000010 rom_sysbios.aem3 : rom_sysbios.obj (.text:xdc_runtime_SysCallback_putch__E)
0000a8cc 00000010 : rom_sysbios.obj (.text:xdc_runtime_SysCallback_ready__E)
0000a8dc 00000010 : rom_sysbios.obj (.text:xdc_runtime_System_vsnprintf__E)
0000a8ec 0000000e disp750a.obj (.text:EPD_7IN5_TurnOnDisplay)
0000a8fa 0000000e icall_api.obj (.text:GATT_Indication)
0000a908 0000000e icall_cc2650.obj (.text:ICallPlatform_pwrGetTransitionState)
0000a916 0000000e icall_cc2650.obj (.text:ICallPlatform_pwrIsStableXOSCHF)
0000a924 0000000e icall.obj (.text:ICall_primDisableMInt$15)
0000a932 0000000e icall.obj (.text:ICall_primEnableMInt$15)
0000a940 00000008 (.tramp.ti_sysbios_family_arm_m3_Hwi_enableFxn__E.1)
0000a948 00000008 (.tramp.ti_sysbios_knl_Task_enable__E.1)
0000a950 0000000e icall.obj (.text:ICall_primFreeMsg$15)
0000a95e 0000000e icall.obj (.text:ICall_primGetTicks$15)
0000a96c 0000000e driverlib.lib : vims.obj (.text:NOROM_VIMSModeGet)
0000a97a 0000000e oad_target_external_flash.obj (.text:OADTarget_imageAddress)
0000a988 0000000e SPICC26XXDMA.obj (.text:SPICC26XXDMA_init)
0000a996 0000000e util.obj (.text:Util_constructQueue)
0000a9a4 00000008 (.tramp.ti_sysbios_knl_Queue_construct.1)
0000a9ac 0000000e rtsv7M3_T_le_eabi.lib : copy_decompress_none.obj (.text:decompress:none)
0000a9ba 0000000e icall_api.obj (.text:matchGSARegisterServiceCS$18)
0000a9c8 0000000e icall_api.obj (.text:matchGapLinkEstCS$18)
0000a9d6 0000000e icall_api.obj (.text:matchGattSendRspCS$18)
0000a9e4 0000000e icall_api.obj (.text:matchLinkDBGetInfoCS$18)
0000a9f2 0000000e icall_api.obj (.text:matchLinkDBNumActiveCS$18)
0000aa00 0000000e icall_api.obj (.text:matchLinkDBNumConnsCS$18)
0000aa0e 0000000e icall_api.obj (.text:setDispatchCmdEvtHdr$18)
0000aa1c 0000000e rom_sysbios.aem3 : rom_sysbios.obj (.text:ti_sysbios_family_arm_cc26xx_TimestampProvider_get32__E)
0000aa2a 00000002 --HOLE-- [fill = 0]
0000aa2c 0000000c RFCC26XX_singleMode.obj (.text:FsmNextState$9)
0000aa38 0000000c icall_api.obj (.text:GAP_MakeDiscoverable)
0000aa44 0000000c icall_api.obj (.text:GAP_TerminateAuth)
0000aa50 0000000c icall_api.obj (.text:GAP_UpdateLinkParamReq)
0000aa5c 0000000c icall_api.obj (.text:GAP_UpdateLinkParamReqReply)
0000aa68 0000000c icall_api.obj (.text:GGS_SetParameter)
0000aa74 0000000c icall.obj (.text:ICall_clockFunc$15)
0000aa80 0000000c icall.obj (.text:ICall_primDisableInt$15)
0000aa8c 00000008 (.tramp.ti_sysbios_hal_Hwi_HwiProxy_disableInterrupt__E.1)
0000aa94 0000000c icall.obj (.text:ICall_primEnableInt$15)
0000aaa0 00000008 (.tramp.ti_sysbios_hal_Hwi_HwiProxy_enableInterrupt__E.1)
0000aaa8 0000000c icall.obj (.text:ICall_primFree$15)
0000aab4 0000000c icall.obj (.text:ICall_primSignal$15)
0000aac0 0000000c driverlib.lib : cpu.obj (.text:NOROM_CPUcpsid)
0000aacc 0000000c : cpu.obj (.text:NOROM_CPUcpsie)
0000aad8 0000000c PINCC26XX.obj (.text:PIN_registerIntCb)
0000aae4 0000000c drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:Power_getConstraintMask)
0000aaf0 0000000c : PowerCC26XX.oem3 (.text:Power_getDependencyCount)
0000aafc 0000000c : PowerCC26XX.oem3 (.text:Power_getTransitionState)
0000ab08 0000000c util.obj (.text:Util_startClock)
0000ab14 0000000c rtsv7M3_T_le_eabi.lib : copy_zero_init.obj (.text:decompress:ZI)
0000ab20 0000000c icall_api.obj (.text:matchProfileSetParamCS$18)
0000ab2c 0000000c SPICC26XXDMA.obj (.text:spiPostNotify$11)
0000ab38 0000000c rom_sysbios.aem3 : rom_sysbios.obj (.text:ti_sysbios_BIOS_getThreadType__E)
0000ab44 0000000c : rom_sysbios_config.obj (.text:ti_sysbios_hal_Hwi_Params__init__S)
0000ab50 00000008 (.tramp.xdc_runtime_Core_assignParams__I.1)
0000ab58 0000000c : rom_sysbios.obj (.text:ti_sysbios_knl_Swi_getTrigger__E)
0000ab64 0000000c app_ble_pem3.oem3 (.text:xdc_runtime_Startup_reset__I)
0000ab70 0000000c rom_sysbios.aem3 : rom_sysbios.obj (.text:xdc_runtime_Startup_rtsDone__E)
0000ab7c 0000000a icall_cc2650.obj (.text:ICallPlatform_pwrSwitchXOSCHF)
0000ab86 0000000a icall.obj (.text:ICall_primE2S$15)
0000ab90 0000000a drivers_cc26xxware.aem3 : List.oem3 (.text:List_empty)
0000ab9a 0000000a oad_target_external_flash.obj (.text:OADTarget_readFlash)
0000aba4 0000000a SPI.obj (.text:SPI_close)
0000abae 0000000a SPI.obj (.text:SPI_transfer)
0000abb8 0000000a UART.obj (.text:UART_write)
0000abc2 0000000a rom_sysbios.aem3 : rom_sysbios.obj (.text:xdc_runtime_LoggerCallback_disable__E)
0000abcc 0000000a : rom_sysbios.obj (.text:xdc_runtime_LoggerCallback_enable__E)
0000abd6 0000000a app_ble_pem3.oem3 (.text:xdc_runtime_Text_visitRope__I)
0000abe0 00000008 icall_api.obj (.text:GAP_RegisterForMsgs)
0000abe8 00000008 icall_api.obj (.text:GATT_RegisterForMsgs)
0000abf0 00000008 RFCC26XX_singleMode.obj (.text:RF_flushCmd)
0000abf8 00000008 simple_peripheral.obj (.text:SimpleBLEPeripheral_charValueChangeCB$2)
0000ac00 00000008 simple_peripheral.obj (.text:SimpleBLEPeripheral_stateChangeCB$2)
0000ac08 00000008 icall_api.obj (.text:matchHciExtConnEventNoticeCS$18)
0000ac10 00000008 icall_api.obj (.text:matchHciLeReadMaxDataLenCS$18)
0000ac18 00000006 icall_api.obj (.text:GGS_AddService)
0000ac1e 00000006 icall.obj (.text:ICall_mallocImpl)
0000ac24 00000006 driverlib.lib : cpu.obj (.text:NOROM_CPUdelay)
0000ac2a 00000006 oad_target_external_flash.obj (.text:OADTarget_eraseFlash)
0000ac30 00000006 rom_sysbios.aem3 : rom_sysbios.obj (.text:__xdc__init)
0000ac36 00000006 RFCC26XX_singleMode.obj (.text:clkInactivityFxn$9)
0000ac3c 00000006 rtsv7M3_T_le_eabi.lib : copy_decompress_rle.obj (.text:decompress:rle24)
0000ac42 00000006 icall_api.obj (.text:gattAddService$18)
0000ac48 00000006 icall_api.obj (.text:matchBondMgrSetParamCS$18)
0000ac4e 00000006 icall_api.obj (.text:matchGGSSetParamCS$18)
0000ac54 00000006 icall_api.obj (.text:matchGapConnParamUpdateReplyCS$18)
0000ac5a 00000006 icall_api.obj (.text:matchGapDeviceInitCS$18)
0000ac60 00000006 icall_api.obj (.text:matchGapEndDiscoverableCS$18)
0000ac66 00000006 icall_api.obj (.text:matchGapGetParamCS$18)
0000ac6c 00000006 icall_api.obj (.text:matchGapMakeDiscoverableCS$18)
0000ac72 00000006 icall_api.obj (.text:matchGapSetParamCS$18)
0000ac78 00000006 icall_api.obj (.text:matchGapTerminateAuthCS$18)
0000ac7e 00000006 icall_api.obj (.text:matchGapTerminateLinkReqCS$18)
0000ac84 00000006 icall_api.obj (.text:matchGapUpdateAdvDataCS$18)
0000ac8a 00000006 icall_api.obj (.text:matchGapUpdateLinkParamReqCS$18)
0000ac90 00000006 icall_api.obj (.text:matchUtilNvReadCS$18)
0000ac96 00000006 icall_api.obj (.text:matchUtilNvWriteCS$18)
0000ac9c 00000006 rom_sysbios.aem3 : rom_sysbios.obj (.text:ti_sysbios_family_arm_m3_Hwi_setFunc__E)
0000aca2 00000004 icall_api.obj (.text:GATTServApp_AddService)
0000aca6 00000004 tirtosport.aem3 : HwiP_tirtos.oem3 (.text:HwiP_disable)
0000acaa 00000004 icall.obj (.text:ICall_primAbort$15)
0000acae 00000004 drivers_cc26xxware.aem3 : List.oem3 (.text:List_head)
0000acb2 00000004 : List.oem3 (.text:List_next)
0000acb6 00000004 RFCC26XX_singleMode.obj (.text:Q_peek$9)
0000acba 00000004 util.obj (.text:Util_stopClock)
0000acbe 00000004 peripheral.obj (.text:gapRole_SetupGAP$25)
0000acc2 00000004 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:nopResourceHandler)
0000acc6 00000004 rom_sysbios.aem3 : rom_sysbios.obj (.text:ti_sysbios_family_arm_cc26xx_Timer_getCount64__E)
0000acca 00000004 : rom_sysbios.obj (.text:ti_sysbios_knl_Clock_isActive__E)
0000acce 00000004 : rom_sysbios.obj (.text:xdc_runtime_LoggerCallback_defaultCreate)
0000acd2 00000004 : rom_sysbios.obj (.text:xdc_runtime_SysCallback_defaultReady)
0000acd6 00000004 : rom_sysbios.obj (.text:xdc_runtime_System_snprintf_va__F)
0000acda 00000002 --HOLE-- [fill = 0]
0000acdc 00000008 (.tramp.ti_sysbios_BIOS_RtsGateProxy_enter__E.1)
0000ace4 00000008 (.tramp.ti_sysbios_family_arm_m3_Hwi_initNVIC__E.1)
0000acec 00000008 (.tramp.xdc_runtime_Core_createObject__I.1)
0000acf4 00000008 (.tramp.ti_sysbios_knl_Task_startup__E.1)
0000acfc 00000008 (.tramp.ti_sysbios_knl_Swi_startup__E.1)
0000ad04 00000008 (.tramp.ti_sysbios_hal_Hwi_HwiProxy_startup__E.1)
0000ad0c 00000008 (.tramp.ti_sysbios_family_arm_cc26xx_Timer_startup__E.1)
0000ad14 00000008 (.tramp.xdc_runtime_System_atexit__E.1)
0000ad1c 00000008 (.tramp.ti_sysbios_BIOS_setThreadType__E.1)
0000ad24 00000008 (.tramp.ti_sysbios_hal_Hwi_create.1)
0000ad2c 00000008 (.tramp.ti_sysbios_knl_Task_construct.1)
0000ad34 00000008 (.tramp.xdc_runtime_System_exit__E.1)
0000ad3c 00000008 (.tramp.ti_sysbios_knl_Queue_put__E.1)
0000ad44 00000008 (.tramp.ti_sysbios_knl_Semaphore_create.1)
0000ad4c 00000008 (.tramp.ti_sysbios_BIOS_start__E.1)
0000ad54 00000008 (.tramp.xdc_runtime_System_abort__E.1)
0000ad5c 00000008 (.tramp.ti_sysbios_knl_Task_create.1)
0000ad64 00000008 (.tramp.ti_sysbios_knl_Task_Params__init__S.1)
0000ad6c 00000008 (.tramp.ti_sysbios_knl_Clock_create.1)
0000ad74 00000008 (.tramp.ti_sysbios_knl_Clock_scheduleNextTick__E.1)
0000ad7c 00000008 (.tramp.ti_sysbios_knl_Clock_walkQueueDynamic__E.1)
0000ad84 00000008 (.tramp.ti_sysbios_knl_Clock_TimerProxy_getCurrentTick__E.1)
0000ad8c 00000008 (.tramp.ti_sysbios_knl_Semaphore_destruct.1)
0000ad94 00000008 (.tramp.ti_sysbios_knl_Swi_destruct.1)
0000ad9c 00000008 (.tramp.ti_sysbios_family_arm_m3_Hwi_destruct.1)
0000ada4 00000008 (.tramp.ti_sysbios_knl_Queue_get__E.1)
0000adac 00000008 (.tramp.ti_sysbios_knl_Queue_empty__E.1)
0000adb4 00000008 (.tramp.ti_sysbios_BIOS_getCpuFreq__E.1)
0000adbc 00000008 (.tramp.ti_sysbios_knl_Semaphore_post__E.1)
0000adc4 00000008 (.tramp.ti_sysbios_knl_Clock_getTicks__E.1)
0000adcc 00000008 (.tramp.ti_sysbios_knl_Task_self__E.1)
0000add4 00000008 (.tramp.ti_sysbios_family_arm_m3_Hwi_enableInterrupt__E.1)
0000addc 00000008 (.tramp.ti_sysbios_knl_Clock_construct.1)
0000ade4 00000008 (.tramp.ti_sysbios_knl_Clock_Params__init__S.1)
0000adec 00000008 (.tramp.xdc_runtime_Text_ropeText__E.1)
0000adf4 00000008 (.tramp.xdc_runtime_System_abortSpin__E.1)
0000adfc 00000008 (.tramp.ti_sysbios_knl_Clock_start__E.1)
0000ae04 00000008 (.tramp.ti_sysbios_knl_Clock_setTimeout__E.1)
0000ae0c 00000008 (.tramp.ti_sysbios_knl_Semaphore_pend__E.1)
0000ae14 00000008 (.tramp.ti_sysbios_knl_Swi_post__E.1)
0000ae1c 00000008 (.tramp.ti_sysbios_knl_Task_restore__E.1)
0000ae24 00000008 (.tramp.ti_sysbios_knl_Swi_restore__E.1)
0000ae2c 00000008 (.tramp.ti_sysbios_knl_Swi_disable__E.1)
0000ae34 00000008 (.tramp.ti_sysbios_knl_Task_disable__E.1)
0000ae3c 00000008 (.tramp.ti_sysbios_knl_Semaphore_construct.1)
0000ae44 00000008 (.tramp.ti_sysbios_knl_Semaphore_Params__init__S.1)
0000ae4c 00000008 (.tramp.ti_sysbios_knl_Swi_construct.1)
0000ae54 00000008 (.tramp.ti_sysbios_knl_Swi_Params__init__S.1)
0000ae5c 00000008 (.tramp.ti_sysbios_family_arm_m3_Hwi_construct.1)
0000ae64 00000008 (.tramp.ti_sysbios_family_arm_m3_Hwi_Params__init__S.1)
0000ae6c 00000008 (.tramp.ti_sysbios_family_arm_m3_Hwi_restoreFxn__E.1)
0000ae74 00000008 (.tramp.ti_sysbios_family_arm_m3_Hwi_disableFxn__E.1)
.const 0 0000ae7c 00001dc6
0000ae7c 000017c0 app_ble_pem3.oem3 (.const:xdc_runtime_Text_charTab__A)
0000c63c 000000cc icall.obj (.const)
0000c708 000000c8 simple_peripheral.obj (.const:.string:$P$T0$1$2)
0000c7d0 00000054 SPICC26XXDMA.obj (.const)
0000c824 00000054 oad.obj (.const)
0000c878 0000004c drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.const:resourceDB)
0000c8c4 0000004c ble_user_config.obj (.const:rfDriverTable)
0000c910 00000048 app_ble_pem3.oem3 (.const:.string)
0000c958 0000003c oad.obj (.const:.string)
0000c994 00000038 board.obj (.const:spiCC26XXDMAHWAttrs)
0000c9cc 00000034 app_ble_pem3.oem3 (.const:xdc_runtime_LoggerCallback_Module__FXNS__C)
0000ca00 0000002c gatt_uuid.obj (.const)
0000ca2c 00000028 app_ble_pem3.oem3 (.const:xdc_runtime_Startup_sfxnTab__A)
0000ca54 00000027 ble_user_config.obj (.const:txPowerTable)
0000ca7b 00000001 --HOLE-- [fill = 0]
0000ca7c 00000024 board.obj (.const:SPI_config)
0000caa0 00000020 SPI.obj (.const)
0000cac0 00000020 app_ble_pem3.oem3 (.const:xdc_runtime_LoggerCallback_Object__DESC__C)
0000cae0 0000001c app_ble_pem3.oem3 (.const:xdc_runtime_LoggerCallback_Object__PARAMS__C)
0000cafc 00000014 devinfoservice.obj (.const:.string)
0000cb10 00000014 RFCC26XX_singleMode.obj (.const)
0000cb24 00000014 ble_user_config.obj (.const)
0000cb38 00000014 devinfoservice.obj (.const)
0000cb4c 00000014 simple_gatt_profile.obj (.const)
0000cb60 00000014 app_ble_pem3.oem3 (.const:xdc_runtime_Startup_sfxnRts__A)
0000cb74 00000010 board.obj (.const:PowerCC26XX_config)
0000cb84 00000010 board.obj (.const:TRNGCC26XX_config)
0000cb94 00000010 board.obj (.const:UDMACC26XX_config)
0000cba4 00000010 app_ble_pem3.oem3 (.const:xdc_runtime_Text_nodeTab__A)
0000cbb4 0000000c simple_gatt_profile.obj (.const:.string)
0000cbc0 0000000c board.obj (.const:BoardGpioInitTable)
0000cbcc 0000000c app_ble_pem3.oem3 (.const:xdc_runtime_Startup_firstFxns__A)
0000cbd8 00000008 ExtFlash.obj (.const)
0000cbe0 00000008 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Idle_funcList__A)
0000cbe8 00000008 board.obj (.const:udmaHWAttrs)
0000cbf0 00000004 board.obj (.const:TRNGCC26XXHWAttrs)
0000cbf4 00000004 icall_cc2650.obj (.const)
0000cbf8 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Clock_tickPeriod__C)
0000cbfc 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Clock_triggerClock__C)
0000cc00 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_ILogger_Interface__BASE__C)
0000cc04 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_Log_L_error__C)
0000cc08 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_Log_L_warning__C)
0000cc0c 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_LoggerCallback_Object__count__C)
0000cc10 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_LoggerCallback_createInstFxn__C)
0000cc14 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_LoggerCallback_outputFxn__C)
0000cc18 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_Main_Module__loggerFxn2__C)
0000cc1c 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_Main_Module__loggerFxn4__C)
0000cc20 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_Main_Module__loggerFxn8__C)
0000cc24 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_Main_Module__loggerObj__C)
0000cc28 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_SysCallback_putchFxn__C)
0000cc2c 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_SysCallback_readyFxn__C)
0000cc30 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_System_extendFxn__C)
0000cc34 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_Text_nodeTab__C)
0000cc38 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_Text_visitRopeFxn__C)
0000cc3c 00000002 app_ble_pem3.oem3 (.const:xdc_runtime_Main_Module__loggerDefined__C)
0000cc3e 00000002 app_ble_pem3.oem3 (.const:xdc_runtime_Text_registryModsLastId__C)
0000cc40 00000002 app_ble_pem3.oem3 (.const:xdc_runtime_Text_unnamedModsLastId__C)
.cinit 0 0000cc48 00000720
0000cc48 000005a3 (.cinit..data.load) [load image, compression = rle]
0000d1eb 00000005 --HOLE-- [fill = 0]
0000d1f0 0000001e (.cinit..data:ti_sysbios_knl_Task_Module__state__V.load) [load image, compression = rle]
0000d20e 00000002 --HOLE-- [fill = 0]
0000d210 00000017 (.cinit..data:ti_sysbios_BIOS_Module__state__V.load) [load image, compression = rle]
0000d227 00000001 --HOLE-- [fill = 0]
0000d228 00000011 (.cinit..data:ti_sysbios_knl_Clock_Module__state__V.load) [load image, compression = rle]
0000d239 00000007 --HOLE-- [fill = 0]
0000d240 0000000f (.cinit..data:ti_sysbios_family_arm_m3_Hwi_Module__state__V.load) [load image, compression = rle]
0000d24f 00000001 --HOLE-- [fill = 0]
0000d250 0000000c (__TI_handler_table)
0000d25c 00000004 --HOLE-- [fill = 0]
0000d260 0000000a (.cinit..data:ti_sysbios_knl_Swi_Module__state__V.load) [load image, compression = rle]
0000d26a 00000006 --HOLE-- [fill = 0]
0000d270 0000000a (.cinit..data:xdc_runtime_Memory_Module__state__V.load) [load image, compression = rle]
0000d27a 00000006 --HOLE-- [fill = 0]
0000d280 00000009 (.cinit..data:ti_sysbios_family_arm_cc26xx_Timer_Module__state__V.load) [load image, compression = rle]
0000d289 00000007 --HOLE-- [fill = 0]
0000d290 00000009 (.cinit..data:ti_sysbios_family_arm_cc26xx_TimestampProvider_Module__state__V.load) [load image, compression = rle]
0000d299 00000007 --HOLE-- [fill = 0]
0000d2a0 00000009 (.cinit..data:xdc_runtime_Startup_Module__state__V.load) [load image, compression = rle]
0000d2a9 00000007 --HOLE-- [fill = 0]
0000d2b0 00000009 (.cinit..data:xdc_runtime_System_Module__state__V.load) [load image, compression = rle]
0000d2b9 00000007 --HOLE-- [fill = 0]
0000d2c0 00000008 (.cinit..TI.bound:dmaSpi0RxControlTableEntry$11.load) [load image, compression = zero_init]
0000d2c8 00000008 (.cinit..TI.bound:dmaSpi0TxControlTableEntry$11.load) [load image, compression = zero_init]
0000d2d0 00000008 (.cinit..TI.bound:dmaSpi1RxControlTableEntry$11.load) [load image, compression = zero_init]
0000d2d8 00000008 (.cinit..TI.bound:dmaSpi1TxControlTableEntry$11.load) [load image, compression = zero_init]
0000d2e0 00000008 (.cinit..bss.load) [load image, compression = zero_init]
0000d2e8 00000080 (__TI_cinit_table)
.init_array
* 0 00001010 00000000 UNINITIALIZED
.const:ti_sysbios_knl_Task_Object__PARAMS__C
* 0 00000100 0000003c
00000100 0000003c app_ble_pem3.oem3 (.const:ti_sysbios_knl_Task_Object__PARAMS__C)
.const:ti_sysbios_knl_Mailbox_Object__PARAMS__C
* 0 0000013c 00000034
0000013c 00000034 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Mailbox_Object__PARAMS__C)
.const:ti_sysbios_family_arm_m3_Hwi_Object__PARAMS__C
* 0 00000170 00000030
00000170 00000030 app_ble_pem3.oem3 (.const:ti_sysbios_family_arm_m3_Hwi_Object__PARAMS__C)
.const:ti_sysbios_hal_Hwi_Object__PARAMS__C
* 0 000001a0 0000002c
000001a0 0000002c app_ble_pem3.oem3 (.const:ti_sysbios_hal_Hwi_Object__PARAMS__C)
.const:ti_sysbios_heaps_HeapMem_Module__FXNS__C
* 0 000001cc 00000028
000001cc 00000028 app_ble_pem3.oem3 (.const:ti_sysbios_heaps_HeapMem_Module__FXNS__C)
.const:ti_sysbios_knl_Swi_Object__PARAMS__C
* 0 000001f4 00000028
000001f4 00000028 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Swi_Object__PARAMS__C)
.const:ti_sysbios_gates_GateHwi_Module__FXNS__C
* 0 0000021c 00000024
0000021c 00000024 app_ble_pem3.oem3 (.const:ti_sysbios_gates_GateHwi_Module__FXNS__C)
.const:ti_sysbios_gates_GateMutex_Module__FXNS__C
* 0 00000240 00000024
00000240 00000024 app_ble_pem3.oem3 (.const:ti_sysbios_gates_GateMutex_Module__FXNS__C)
.const:ti_sysbios_heaps_HeapMem_Object__PARAMS__C
* 0 00000264 00000024
00000264 00000024 app_ble_pem3.oem3 (.const:ti_sysbios_heaps_HeapMem_Object__PARAMS__C)
.const:ti_sysbios_knl_Clock_Object__PARAMS__C
* 0 00000288 00000024
00000288 00000024 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Clock_Object__PARAMS__C)
.const:ti_sysbios_knl_Semaphore_Object__PARAMS__C
* 0 000002ac 00000024
000002ac 00000024 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Semaphore_Object__PARAMS__C)
.const:ti_sysbios_family_arm_m3_Hwi_Object__DESC__C
* 0 000002d0 00000020
000002d0 00000020 app_ble_pem3.oem3 (.const:ti_sysbios_family_arm_m3_Hwi_Object__DESC__C)
.const:ti_sysbios_gates_GateHwi_Object__DESC__C
* 0 000002f0 00000020
000002f0 00000020 app_ble_pem3.oem3 (.const:ti_sysbios_gates_GateHwi_Object__DESC__C)
.const:ti_sysbios_gates_GateMutex_Object__DESC__C
* 0 00000310 00000020
00000310 00000020 app_ble_pem3.oem3 (.const:ti_sysbios_gates_GateMutex_Object__DESC__C)
.const:ti_sysbios_hal_Hwi_Object__DESC__C
* 0 00000330 00000020
00000330 00000020 app_ble_pem3.oem3 (.const:ti_sysbios_hal_Hwi_Object__DESC__C)
.const:ti_sysbios_heaps_HeapMem_Object__DESC__C
* 0 00000350 00000020
00000350 00000020 app_ble_pem3.oem3 (.const:ti_sysbios_heaps_HeapMem_Object__DESC__C)
.const:ti_sysbios_knl_Clock_Object__DESC__C
* 0 00000370 00000020
00000370 00000020 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Clock_Object__DESC__C)
.const:ti_sysbios_knl_Mailbox_Object__DESC__C
* 0 00000390 00000020
00000390 00000020 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Mailbox_Object__DESC__C)
.const:ti_sysbios_knl_Queue_Object__DESC__C
* 0 000003b0 00000020
000003b0 00000020 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Queue_Object__DESC__C)
.const:ti_sysbios_knl_Semaphore_Object__DESC__C
* 0 000003d0 00000020
000003d0 00000020 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Semaphore_Object__DESC__C)
.const:ti_sysbios_knl_Swi_Object__DESC__C
* 0 000003f0 00000020
000003f0 00000020 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Swi_Object__DESC__C)
.const:ti_sysbios_knl_Task_Object__DESC__C
* 0 00000410 00000020
00000410 00000020 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Task_Object__DESC__C)
.const:ti_sysbios_gates_GateHwi_Object__PARAMS__C
* 0 00000430 00000018
00000430 00000018 app_ble_pem3.oem3 (.const:ti_sysbios_gates_GateHwi_Object__PARAMS__C)
.const:ti_sysbios_gates_GateMutex_Object__PARAMS__C
* 0 00000448 00000018
00000448 00000018 app_ble_pem3.oem3 (.const:ti_sysbios_gates_GateMutex_Object__PARAMS__C)
.const:ti_sysbios_knl_Queue_Object__PARAMS__C
* 0 00000460 00000018
00000460 00000018 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Queue_Object__PARAMS__C)
.const:ti_sysbios_knl_Idle_funcList__C
* 0 00000478 00000008
00000478 00000008 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Idle_funcList__C)
.const:ti_sysbios_family_arm_cc26xx_Timer_startupNeeded__C
* 0 00000484 00000004
00000484 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_family_arm_cc26xx_Timer_startupNeeded__C)
.const:ti_sysbios_family_arm_m3_Hwi_E_alreadyDefined__C
* 0 00000488 00000004
00000488 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_family_arm_m3_Hwi_E_alreadyDefined__C)
.const:ti_sysbios_family_arm_m3_Hwi_E_hwiLimitExceeded__C
* 0 0000048c 00000004
0000048c 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_family_arm_m3_Hwi_E_hwiLimitExceeded__C)
.const:ti_sysbios_family_arm_m3_Hwi_NUM_INTERRUPTS__C
* 0 00000490 00000004
00000490 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_family_arm_m3_Hwi_NUM_INTERRUPTS__C)
.const:ti_sysbios_family_arm_m3_Hwi_Object__count__C
* 0 00000494 00000004
00000494 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_family_arm_m3_Hwi_Object__count__C)
.const:ti_sysbios_family_arm_m3_Hwi_Object__table__C
* 0 00000498 00000004
00000498 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_family_arm_m3_Hwi_Object__table__C)
.const:ti_sysbios_family_arm_m3_Hwi_ccr__C
* 0 0000049c 00000004
0000049c 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_family_arm_m3_Hwi_ccr__C)
.const:ti_sysbios_family_arm_m3_Hwi_excHandlerFunc__C
* 0 000004a0 00000004
000004a0 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_family_arm_m3_Hwi_excHandlerFunc__C)
.const:ti_sysbios_family_arm_m3_Hwi_nullIsrFunc__C
* 0 000004a4 00000004
000004a4 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_family_arm_m3_Hwi_nullIsrFunc__C)
.const:ti_sysbios_family_arm_m3_Hwi_numSparseInterrupts__C
* 0 000004a8 00000004
000004a8 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_family_arm_m3_Hwi_numSparseInterrupts__C)
.const:ti_sysbios_family_arm_m3_Hwi_priGroup__C
* 0 000004ac 00000004
000004ac 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_family_arm_m3_Hwi_priGroup__C)
.const:ti_sysbios_family_arm_m3_TaskSupport_stackAlignment__C
* 0 000004b0 00000004
000004b0 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_family_arm_m3_TaskSupport_stackAlignment__C)
.const:ti_sysbios_heaps_HeapMem_E_memory__C
* 0 000004b4 00000004
000004b4 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_heaps_HeapMem_E_memory__C)
.const:ti_sysbios_heaps_HeapMem_Module__gateObj__C
* 0 000004b8 00000004
000004b8 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_heaps_HeapMem_Module__gateObj__C)
.const:ti_sysbios_heaps_HeapMem_Object__count__C
* 0 000004bc 00000004
000004bc 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_heaps_HeapMem_Object__count__C)
.const:ti_sysbios_heaps_HeapMem_Object__table__C
* 0 000004c0 00000004
000004c0 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_heaps_HeapMem_Object__table__C)
.const:ti_sysbios_heaps_HeapMem_reqAlign__C
* 0 000004c4 00000004
000004c4 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_heaps_HeapMem_reqAlign__C)
.const:ti_sysbios_knl_Clock_serviceMargin__C
* 0 000004c8 00000004
000004c8 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Clock_serviceMargin__C)
.const:ti_sysbios_knl_Mailbox_Object__count__C
* 0 000004cc 00000004
000004cc 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Mailbox_Object__count__C)
.const:ti_sysbios_knl_Mailbox_Object__table__C
* 0 000004d0 00000004
000004d0 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Mailbox_Object__table__C)
.const:ti_sysbios_knl_Queue_Object__count__C
* 0 000004d4 00000004
000004d4 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Queue_Object__count__C)
.const:ti_sysbios_knl_Queue_Object__table__C
* 0 000004d8 00000004
000004d8 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Queue_Object__table__C)
.const:ti_sysbios_knl_Swi_Object__count__C
* 0 000004dc 00000004
000004dc 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Swi_Object__count__C)
.const:ti_sysbios_knl_Swi_Object__table__C
* 0 000004e0 00000004
000004e0 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Swi_Object__table__C)
.const:ti_sysbios_knl_Swi_numPriorities__C
* 0 000004e4 00000004
000004e4 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Swi_numPriorities__C)
.const:ti_sysbios_knl_Task_Object__count__C
* 0 000004e8 00000004
000004e8 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Task_Object__count__C)
.const:ti_sysbios_knl_Task_Object__table__C
* 0 000004ec 00000004
000004ec 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Task_Object__table__C)
.const:ti_sysbios_knl_Task_allBlockedFunc__C
* 0 000004f0 00000004
000004f0 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Task_allBlockedFunc__C)
.const:ti_sysbios_knl_Task_defaultStackHeap__C
* 0 000004f4 00000004
000004f4 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Task_defaultStackHeap__C)
.const:ti_sysbios_knl_Task_defaultStackSize__C
* 0 000004f8 00000004
000004f8 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Task_defaultStackSize__C)
.const:ti_sysbios_knl_Task_numConstructedTasks__C
* 0 000004fc 00000004
000004fc 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Task_numConstructedTasks__C)
.const:ti_sysbios_family_arm_cc26xx_Timer_Module__id__C
* 0 00000502 00000002
00000502 00000002 app_ble_pem3.oem3 (.const:ti_sysbios_family_arm_cc26xx_Timer_Module__id__C)
.const:ti_sysbios_family_arm_cc26xx_TimestampProvider_useClockTimer__C
* 0 00000504 00000002
00000504 00000002 app_ble_pem3.oem3 (.const:ti_sysbios_family_arm_cc26xx_TimestampProvider_useClockTimer__C)
.const:ti_sysbios_family_arm_m3_Hwi_Module__id__C
* 0 00000506 00000002
00000506 00000002 app_ble_pem3.oem3 (.const:ti_sysbios_family_arm_m3_Hwi_Module__id__C)
.const:ti_sysbios_gates_GateHwi_Module__id__C
* 0 00000508 00000002
00000508 00000002 app_ble_pem3.oem3 (.const:ti_sysbios_gates_GateHwi_Module__id__C)
.const:ti_sysbios_gates_GateMutex_Module__id__C
* 0 0000050a 00000002
0000050a 00000002 app_ble_pem3.oem3 (.const:ti_sysbios_gates_GateMutex_Module__id__C)
.const:ti_sysbios_heaps_HeapMem_Module__id__C
* 0 0000050c 00000002
0000050c 00000002 app_ble_pem3.oem3 (.const:ti_sysbios_heaps_HeapMem_Module__id__C)
.const:ti_sysbios_knl_Task_initStackFlag__C
* 0 0000050e 00000002
0000050e 00000002 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Task_initStackFlag__C)
.const:ti_sysbios_knl_Clock_tickMode__C
* 0 00000510 00000001
00000510 00000001 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Clock_tickMode__C)
.const:xdc_runtime_Startup_firstFxns__C
* 0 00000514 00000008
00000514 00000008 app_ble_pem3.oem3 (.const:xdc_runtime_Startup_firstFxns__C)
.const:xdc_runtime_Startup_lastFxns__C
* 0 0000051c 00000008
0000051c 00000008 app_ble_pem3.oem3 (.const:xdc_runtime_Startup_lastFxns__C)
.const:xdc_runtime_Assert_E_assertFailed__C
* 0 00000524 00000004
00000524 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_Assert_E_assertFailed__C)
.const:xdc_runtime_Error_E_memory__C
* 0 00000528 00000004
00000528 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_Error_E_memory__C)
.const:xdc_runtime_Error_policyFxn__C
* 0 0000052c 00000004
0000052c 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_Error_policyFxn__C)
.const:xdc_runtime_IGateProvider_Interface__BASE__C
* 0 00000530 00000004
00000530 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_IGateProvider_Interface__BASE__C)
.const:xdc_runtime_IHeap_Interface__BASE__C
* 0 00000534 00000004
00000534 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_IHeap_Interface__BASE__C)
.const:xdc_runtime_IModule_Interface__BASE__C
* 0 00000538 00000004
00000538 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_IModule_Interface__BASE__C)
.const:xdc_runtime_Main_Module__diagsEnabled__C
* 0 0000053c 00000004
0000053c 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_Main_Module__diagsEnabled__C)
.const:xdc_runtime_Main_Module__diagsIncluded__C
* 0 00000540 00000004
00000540 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_Main_Module__diagsIncluded__C)
.const:xdc_runtime_Main_Module__diagsMask__C
* 0 00000544 00000004
00000544 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_Main_Module__diagsMask__C)
.const:xdc_runtime_Memory_defaultHeapInstance__C
* 0 00000548 00000004
00000548 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_Memory_defaultHeapInstance__C)
.const:xdc_runtime_Startup_execImpl__C
* 0 0000054c 00000004
0000054c 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_Startup_execImpl__C)
.const:xdc_runtime_Startup_maxPasses__C
* 0 00000550 00000004
00000550 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_Startup_maxPasses__C)
.const:xdc_runtime_Startup_sfxnRts__C
* 0 00000554 00000004
00000554 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_Startup_sfxnRts__C)
.const:xdc_runtime_Startup_sfxnTab__C
* 0 00000558 00000004
00000558 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_Startup_sfxnTab__C)
.const:xdc_runtime_Startup_startModsFxn__C
* 0 0000055c 00000004
0000055c 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_Startup_startModsFxn__C)
.const:xdc_runtime_SysCallback_abortFxn__C
* 0 00000560 00000004
00000560 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_SysCallback_abortFxn__C)
.const:xdc_runtime_SysCallback_exitFxn__C
* 0 00000564 00000004
00000564 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_SysCallback_exitFxn__C)
.const:xdc_runtime_System_abortFxn__C
* 0 00000568 00000004
00000568 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_System_abortFxn__C)
.const:xdc_runtime_System_exitFxn__C
* 0 0000056c 00000004
0000056c 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_System_exitFxn__C)
.const:xdc_runtime_System_maxAtexitHandlers__C
* 0 00000570 00000004
00000570 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_System_maxAtexitHandlers__C)
.const:xdc_runtime_Text_charTab__C
* 0 00000574 00000004
00000574 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_Text_charTab__C)
.const:xdc_runtime_Text_nameEmpty__C
* 0 00000578 00000004
00000578 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_Text_nameEmpty__C)
.const:xdc_runtime_Text_nameStatic__C
* 0 0000057c 00000004
0000057c 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_Text_nameStatic__C)
.const:xdc_runtime_Text_nameUnknown__C
* 0 00000580 00000004
00000580 00000004 app_ble_pem3.oem3 (.const:xdc_runtime_Text_nameUnknown__C)
.const:xdc_runtime_Main_Module__id__C
* 0 00000584 00000002
00000584 00000002 app_ble_pem3.oem3 (.const:xdc_runtime_Main_Module__id__C)
.const:xdc_runtime_Memory_Module__id__C
* 0 00000586 00000002
00000586 00000002 app_ble_pem3.oem3 (.const:xdc_runtime_Memory_Module__id__C)
.const:xdc_runtime_Text_charCnt__C
* 0 00000588 00000002
00000588 00000002 app_ble_pem3.oem3 (.const:xdc_runtime_Text_charCnt__C)
.const:xdc_runtime_Text_isLoaded__C
* 0 0000058a 00000002
0000058a 00000002 app_ble_pem3.oem3 (.const:xdc_runtime_Text_isLoaded__C)
.const:xdc_runtime_Error_policy__C
* 0 0000058c 00000001
0000058c 00000001 app_ble_pem3.oem3 (.const:xdc_runtime_Error_policy__C)
.const:ti_sysbios_rom_ROM_AONRTCChannelEnable
* 0 00000590 00000004
00000590 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_rom_ROM_AONRTCChannelEnable)
.const:ti_sysbios_rom_ROM_AONRTCCompareValueSet
* 0 00000594 00000004
00000594 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_rom_ROM_AONRTCCompareValueSet)
.const:ti_sysbios_rom_ROM_AONRTCCurrentCompareValueGet
* 0 00000598 00000004
00000598 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_rom_ROM_AONRTCCurrentCompareValueGet)
.const:ti_sysbios_rom_ROM_AONRTCEventClear
* 0 0000059c 00000004
0000059c 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_rom_ROM_AONRTCEventClear)
.const:ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_getCount64__E
* 0 000005a0 00000004
000005a0 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_getCount64__E)
.const:ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_getCurrentTick__E
* 0 000005a4 00000004
000005a4 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_getCurrentTick__E)
.const:ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_getMaxTicks__E
* 0 000005a8 00000004
000005a8 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_getMaxTicks__E)
.const:ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_initDevice__I
* 0 000005ac 00000004
000005ac 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_initDevice__I)
.const:ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_setNextTick__E
* 0 000005b0 00000004
000005b0 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_setNextTick__E)
.const:ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_setThreshold__I
* 0 000005b4 00000004
000005b4 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_setThreshold__I)
.const:ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_start__E
* 0 000005b8 00000004
000005b8 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_start__E)
.const:ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_TimestampProvider_get32__E
* 0 000005bc 00000004
000005bc 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_TimestampProvider_get32__E)
.const:ti_sysbios_rom_ROM_xdc_runtime_Startup_getState__I
* 0 000005c0 00000004
000005c0 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_rom_ROM_xdc_runtime_Startup_getState__I)
.const:ti_sysbios_rom_ROM_xdc_runtime_System_SupportProxy_abort__E
* 0 000005c4 00000004
000005c4 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_rom_ROM_xdc_runtime_System_SupportProxy_abort__E)
.const:ti_sysbios_rom_ROM_xdc_runtime_System_SupportProxy_exit__E
* 0 000005c8 00000004
000005c8 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_rom_ROM_xdc_runtime_System_SupportProxy_exit__E)
.const:ti_sysbios_gates_GateMutex_Instance_State_sem__O
* 0 000005cc 00000004
000005cc 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_gates_GateMutex_Instance_State_sem__O)
.const:ti_sysbios_knl_Clock_Module_State_clockQ__O
* 0 000005d0 00000004
000005d0 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Clock_Module_State_clockQ__O)
.const:ti_sysbios_knl_Mailbox_Instance_State_dataQue__O
* 0 000005d4 00000004
000005d4 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Mailbox_Instance_State_dataQue__O)
.const:ti_sysbios_knl_Mailbox_Instance_State_dataSem__O
* 0 000005d8 00000004
000005d8 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Mailbox_Instance_State_dataSem__O)
.const:ti_sysbios_knl_Mailbox_Instance_State_freeQue__O
* 0 000005dc 00000004
000005dc 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Mailbox_Instance_State_freeQue__O)
.const:ti_sysbios_knl_Mailbox_Instance_State_freeSem__O
* 0 000005e0 00000004
000005e0 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Mailbox_Instance_State_freeSem__O)
.const:ti_sysbios_knl_Semaphore_Instance_State_pendQ__O
* 0 000005e4 00000004
000005e4 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Semaphore_Instance_State_pendQ__O)
.const:ti_sysbios_knl_Task_Module_State_inactiveQ__O
* 0 000005e8 00000004
000005e8 00000004 app_ble_pem3.oem3 (.const:ti_sysbios_knl_Task_Module_State_inactiveQ__O)
.ccfg 0 000005ec 00000058
000005ec 00000058 ccfg_app_ble.obj (.ccfg:retain)
.resetVecs
* 0 00001010 0000003c
00001010 0000003c app_ble_pem3.oem3 (.resetVecs)
.vecs 0 20000000 000000c8 NOLOAD SECTION
20000000 000000c8 app_ble_pem3.oem3 (.vecs)
* 0 20000100 00000044 UNINITIALIZED
20000100 00000044 app_ble_pem3.oem3 (.data:ti_sysbios_knl_Task_Module__state__V)
* 0 20000144 00000034 UNINITIALIZED
20000144 00000034 app_ble_pem3.oem3 (.data:ti_sysbios_family_arm_m3_Hwi_Module__state__V)
.data 0 20000148 00001709 UNINITIALIZED
20000148 00000384 simple_peripheral.obj (.data)
200004cc 00000380 peripheral.obj (.data)
2000084c 00000338 uart_logs.obj (.data)
20000b84 00000240 simple_gatt_profile.obj (.data)
20000dc4 00000004 SPI.obj (.data)
20000dc8 00000228 RFCC26XX_singleMode.obj (.data)
20000ff0 000001e0 devinfoservice.obj (.data)
200011d0 00000124 oad.obj (.data)
200012f4 00000110 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.data:PowerCC26XX_module)
20001404 000000e8 app_ble_pem3.oem3 (.data)
200014ec 00000094 icall.obj (.data)
20001580 0000006c ExtFlash.obj (.data)
200015ec 00000058 ble_user_config.obj (.data:rfRegTbl)
20001644 0000004c app_ble_pem3.oem3 (.data:ti_sysbios_knl_Task_Object__table__V)
20001690 00000048 app_ble_pem3.oem3 (.data:ti_sysbios_family_arm_cc26xx_Timer_Object__table__V)
200016d8 00000038 disp750a.obj (.data)
20001710 00000038 app_ble_pem3.oem3 (.data:ti_sysbios_gates_GateMutex_Object__table__V)
20001748 00000030 app_ble_pem3.oem3 (.data:ti_sysbios_knl_Swi_Module_State_0_readyQ__A)
20001778 00000030 app_ble_pem3.oem3 (.data:ti_sysbios_knl_Swi_Object__table__V)
200017a8 00000030 app_ble_pem3.oem3 (.data:ti_sysbios_knl_Task_Module_State_0_readyQ__A)
200017d8 00000030 main.obj (.data:user0Cfg)
20001808 00000014 oad_target_external_flash.obj (.data)
2000181c 0000000c icall_api.obj (.data)
20001828 00000008 icall_cc2650.obj (.data)
20001830 00000008 rtsv7M3_T_le_eabi.lib : _lock.obj (.data)
20001838 00000008 : exit.obj (.data)
20001840 00000008 app_ble_pem3.oem3 (.data:xdc_runtime_Registry_Module__state__V)
20001848 00000004 ble_user_config.obj (.data)
2000184c 00000004 rtsv7M3_T_le_eabi.lib : stkdepth_vars.obj (.data)
20001850 00000001 TRNGCC26XX.obj (.data)
* 0 20000178 0000002c UNINITIALIZED
20000178 0000002c app_ble_pem3.oem3 (.data:ti_sysbios_knl_Clock_Module__state__V)
* 0 200001a4 00000024 UNINITIALIZED
200001a4 00000024 app_ble_pem3.oem3 (.data:ti_sysbios_BIOS_Module__state__V)
* 0 200001c8 0000001c UNINITIALIZED
200001c8 0000001c app_ble_pem3.oem3 (.data:ti_sysbios_knl_Swi_Module__state__V)
* 0 200001e4 00000008 UNINITIALIZED
200001e4 00000008 app_ble_pem3.oem3 (.data:ti_sysbios_family_arm_cc26xx_Timer_Module__state__V)
* 0 200001ec 00000004 UNINITIALIZED
200001ec 00000004 app_ble_pem3.oem3 (.data:ti_sysbios_family_arm_cc26xx_TimestampProvider_Module__state__V)
* 0 200001f0 00000008 UNINITIALIZED
200001f0 00000008 app_ble_pem3.oem3 (.data:xdc_runtime_Startup_Module__state__V)
* 0 200001f8 00000008 UNINITIALIZED
200001f8 00000008 app_ble_pem3.oem3 (.data:xdc_runtime_System_Module__state__V)
* 0 20000200 00000004 UNINITIALIZED
20000200 00000004 app_ble_pem3.oem3 (.data:xdc_runtime_Memory_Module__state__V)
* 0 20000430 00000010 UNINITIALIZED
20000430 00000010 SPICC26XXDMA.obj (.TI.bound:dmaSpi0RxControlTableEntry$11)
* 0 20000440 00000010 UNINITIALIZED
20000440 00000010 SPICC26XXDMA.obj (.TI.bound:dmaSpi0TxControlTableEntry$11)
* 0 20000500 00000010 UNINITIALIZED
20000500 00000010 SPICC26XXDMA.obj (.TI.bound:dmaSpi1RxControlTableEntry$11)
* 0 20000510 00000010 UNINITIALIZED
20000510 00000010 SPICC26XXDMA.obj (.TI.bound:dmaSpi1TxControlTableEntry$11)
.bss 0 20001858 00000c56 UNINITIALIZED
20001858 00000680 app_ble_pem3.oem3 (.bss:ti_sysbios_heaps_HeapMem_Instance_State_0_buf__A)
20001ed8 00000200 app_ble_pem3.oem3 (.bss:taskStackSection)
200020d8 000001b8 board.obj (.bss:spiCC26XXDMAObjects)
20002290 00000110 PINCC26XX.obj (.bss)
200023a0 000000c8 app_ble_pem3.oem3 (.bss:ti_sysbios_family_arm_m3_Hwi_dispatchTable)
20002468 00000020 (.common:udmaObjects)
20002488 00000014 driverlib.lib : osc.obj (.bss:oscHfGlobals)
2000249c 00000008 : sys_ctrl.obj (.bss:powerQualGlobals)
200024a4 00000004 (.common:dispatchInUs$9)
200024a8 00000004 (.common:trngCC26XXObjects)
200024ac 00000001 (.common:bRestart$9)
200024ad 00000001 (.common:driverlib_release_0_47020)
.vtable 0 200024ae 00000000 UNINITIALIZED
.vtable_ram
* 0 200024ae 00000000 UNINITIALIZED
vtable_ram
.sysmem 0 200024ae 00000000 UNINITIALIZED
.nonretenvar
.stack 0 20003f18 00000400 UNINITIALIZED
20003f18 00000400 --HOLE--
.bootVecs
* 0 00000000 00000008 DSECT
00000000 00000008 boot.aem3 : boot.oem3 (.bootVecs)
xdc.meta 0 00000000 000000f5 COPY SECTION
00000000 000000f5 app_ble_pem3.oem3 (xdc.meta)
LINKER GENERATED COPY TABLES
__TI_cinit_table @ 0000d2e8 records: 16, size/record: 8, table size: 128
.data: load addr=0000cc48, load size=000005a3 bytes, run addr=20000148, run size=00001709 bytes, compression=rle
.data:ti_sysbios_knl_Task_Module__state__V: load addr=0000d1f0, load size=0000001e bytes, run addr=20000100, run size=00000044 bytes, compression=rle
.data:ti_sysbios_BIOS_Module__state__V: load addr=0000d210, load size=00000017 bytes, run addr=200001a4, run size=00000024 bytes, compression=rle
.data:ti_sysbios_knl_Clock_Module__state__V: load addr=0000d228, load size=00000011 bytes, run addr=20000178, run size=0000002c bytes, compression=rle
.data:ti_sysbios_family_arm_m3_Hwi_Module__state__V: load addr=0000d240, load size=0000000f bytes, run addr=20000144, run size=00000034 bytes, compression=rle
.data:ti_sysbios_knl_Swi_Module__state__V: load addr=0000d260, load size=0000000a bytes, run addr=200001c8, run size=0000001c bytes, compression=rle
.data:xdc_runtime_Memory_Module__state__V: load addr=0000d270, load size=0000000a bytes, run addr=20000200, run size=00000004 bytes, compression=rle
.data:ti_sysbios_family_arm_cc26xx_Timer_Module__state__V: load addr=0000d280, load size=00000009 bytes, run addr=200001e4, run size=00000008 bytes, compression=rle
.data:ti_sysbios_family_arm_cc26xx_TimestampProvider_Module__state__V: load addr=0000d290, load size=00000009 bytes, run addr=200001ec, run size=00000004 bytes, compression=rle
.data:xdc_runtime_Startup_Module__state__V: load addr=0000d2a0, load size=00000009 bytes, run addr=200001f0, run size=00000008 bytes, compression=rle
.data:xdc_runtime_System_Module__state__V: load addr=0000d2b0, load size=00000009 bytes, run addr=200001f8, run size=00000008 bytes, compression=rle
.TI.bound:dmaSpi0RxControlTableEntry$11: load addr=0000d2c0, load size=00000008 bytes, run addr=20000430, run size=00000010 bytes, compression=zero_init
.TI.bound:dmaSpi0TxControlTableEntry$11: load addr=0000d2c8, load size=00000008 bytes, run addr=20000440, run size=00000010 bytes, compression=zero_init
.TI.bound:dmaSpi1RxControlTableEntry$11: load addr=0000d2d0, load size=00000008 bytes, run addr=20000500, run size=00000010 bytes, compression=zero_init
.TI.bound:dmaSpi1TxControlTableEntry$11: load addr=0000d2d8, load size=00000008 bytes, run addr=20000510, run size=00000010 bytes, compression=zero_init
.bss: load addr=0000d2e0, load size=00000008 bytes, run addr=20001858, run size=00000c56 bytes, compression=zero_init
LINKER GENERATED HANDLER TABLE
__TI_handler_table @ 0000d250 records: 3, size/record: 4, table size: 12
index: 0, handler: __TI_decompress_rle24
index: 1, handler: __TI_decompress_none
index: 2, handler: __TI_zero_init
FAR CALL TRAMPOLINES
callee name trampoline name
callee addr tramp addr call addr call info
ti_sysbios_BIOS_RtsGateProxy_leave__E $Tramp$TT$L$PI$$ti_sysbios_BIOS_RtsGateProxy_leave__E
1001c24d 0000a538 0000a52e app_ble_pem3.oem3 (.text:ti_sysbios_BIOS_rtsUnlock__I)
ti_sysbios_knl_Clock_logTick__E $Tramp$TT$L$PI$$ti_sysbios_knl_Clock_logTick__E
1001be67 0000a734 0000a722 app_ble_pem3.oem3 (.text:ti_sysbios_knl_Clock_doTick__I)
xdc_runtime_Startup_startMods__I $Tramp$TT$L$PI$$xdc_runtime_Startup_startMods__I
1001c30d 0000a774 0000a76a app_ble_pem3.oem3 (.text:xdc_runtime_Startup_exec__I)
ti_sysbios_family_arm_m3_Hwi_enableFxn__E $Tramp$TT$L$PI$$ti_sysbios_family_arm_m3_Hwi_enableFxn__E
1001c155 0000a940 0000a934 icall.obj (.text:ICall_primEnableMInt$15)
ti_sysbios_knl_Task_enable__E $Tramp$TT$L$PI$$ti_sysbios_knl_Task_enable__E
1001c243 0000a948 0000a938 icall.obj (.text:ICall_primEnableMInt$15)
ti_sysbios_knl_Queue_construct $Tramp$TT$L$PI$$ti_sysbios_knl_Queue_construct
1001b8f5 0000a9a4 0000a99c util.obj (.text:Util_constructQueue)
ti_sysbios_hal_Hwi_HwiProxy_disableInterrupt__E $Tramp$TT$L$PI$$ti_sysbios_hal_Hwi_HwiProxy_disableInterrupt__E
1001c281 0000aa8c 0000aa84 icall.obj (.text:ICall_primDisableInt$15)
ti_sysbios_hal_Hwi_HwiProxy_enableInterrupt__E $Tramp$TT$L$PI$$ti_sysbios_hal_Hwi_HwiProxy_enableInterrupt__E
1001c285 0000aaa0 0000aa98 icall.obj (.text:ICall_primEnableInt$15)
xdc_runtime_Core_assignParams__I $Tramp$TT$L$PI$$xdc_runtime_Core_assignParams__I
1001c5f1 0000ab50 0000ab48 rom_sysbios.aem3 : rom_sysbios_config.obj (.text:ti_sysbios_hal_Hwi_Params__init__S)
ti_sysbios_BIOS_RtsGateProxy_enter__E $Tramp$TT$L$PI$$ti_sysbios_BIOS_RtsGateProxy_enter__E
1001c249 0000acdc 00009dfe app_ble_pem3.oem3 (.text:ti_sysbios_BIOS_rtsLock__I)
ti_sysbios_family_arm_m3_Hwi_initNVIC__E $Tramp$TT$L$PI$$ti_sysbios_family_arm_m3_Hwi_initNVIC__E
1001a699 0000ace4 00009bce rom_sysbios.aem3 : rom_sysbios.obj (.text:ti_sysbios_family_arm_m3_Hwi_cc26xxRomInitNVIC__I)
xdc_runtime_Core_createObject__I $Tramp$TT$L$PI$$xdc_runtime_Core_createObject__I
1001c405 0000acec 000091f8 app_ble_pem3.oem3 (.text:xdc_runtime_LoggerCallback_Object__create__S)
ti_sysbios_knl_Task_startup__E $Tramp$TT$L$PI$$ti_sysbios_knl_Task_startup__E
1001c309 0000acf4 00009178 app_ble_pem3.oem3 (.text:ti_sysbios_BIOS_startFunc__I)
ti_sysbios_knl_Swi_startup__E $Tramp$TT$L$PI$$ti_sysbios_knl_Swi_startup__E
1001c23d 0000acfc 00009174 app_ble_pem3.oem3 (.text:ti_sysbios_BIOS_startFunc__I)
ti_sysbios_hal_Hwi_HwiProxy_startup__E $Tramp$TT$L$PI$$ti_sysbios_hal_Hwi_HwiProxy_startup__E
1001c28d 0000ad04 00009170 app_ble_pem3.oem3 (.text:ti_sysbios_BIOS_startFunc__I)
ti_sysbios_family_arm_cc26xx_Timer_startup__E $Tramp$TT$L$PI$$ti_sysbios_family_arm_cc26xx_Timer_startup__E
1001b795 0000ad0c 0000916c app_ble_pem3.oem3 (.text:ti_sysbios_BIOS_startFunc__I)
xdc_runtime_System_atexit__E $Tramp$TT$L$PI$$xdc_runtime_System_atexit__E
1001c681 0000ad14 00009164 app_ble_pem3.oem3 (.text:ti_sysbios_BIOS_startFunc__I)
ti_sysbios_BIOS_setThreadType__E $Tramp$TT$L$PI$$ti_sysbios_BIOS_setThreadType__E
1001c045 0000ad1c 00009130 app_ble_pem3.oem3 (.text:ti_sysbios_BIOS_atExitFunc__I)
0000a5e8 app_ble_pem3.oem3 (.text:ti_sysbios_BIOS_exitFunc__I)
ti_sysbios_hal_Hwi_create $Tramp$TT$L$PI$$ti_sysbios_hal_Hwi_create
1001ab79 0000ad24 00008a74 icall.obj (.text:ICall_primRegisterISR$15)
00008aa8 icall.obj (.text:ICall_primRegisterISR_Ext$15)
ti_sysbios_knl_Task_construct $Tramp$TT$L$PI$$ti_sysbios_knl_Task_construct
1001b125 0000ad2c 000080ae peripheral.obj (.text:GAPRole_createTask)
00008508 simple_peripheral.obj (.text:SimpleBLEPeripheral_createTask)
xdc_runtime_System_exit__E $Tramp$TT$L$PI$$xdc_runtime_System_exit__E
1001c7d1 0000ad34 00007e54 boot.aem3 : boot.oem3 (.text)
0000a5ee app_ble_pem3.oem3 (.text:ti_sysbios_BIOS_exitFunc__I)
ti_sysbios_knl_Queue_put__E $Tramp$TT$L$PI$$ti_sysbios_knl_Queue_put__E
1001bf2d 0000ad3c 00007ba0 simple_peripheral.obj (.text:SimpleBLEPeripheral_processOadWriteCB)
000096e0 util.obj (.text:Util_enqueueMsg)
ti_sysbios_knl_Semaphore_create $Tramp$TT$L$PI$$ti_sysbios_knl_Semaphore_create
1001b5ad 0000ad44 00007938 icall.obj (.text:ICall_newTask$15)
ti_sysbios_BIOS_start__E $Tramp$TT$L$PI$$ti_sysbios_BIOS_start__E
1001c055 0000ad4c 000068fa main.obj (.text:main)
xdc_runtime_System_abort__E $Tramp$TT$L$PI$$xdc_runtime_System_abort__E
1001c749 0000ad54 000068c6 main.obj (.text:main)
ti_sysbios_knl_Task_create $Tramp$TT$L$PI$$ti_sysbios_knl_Task_create
1001ae19 0000ad5c 000060c6 icall.obj (.text:ICall_createRemoteTasks)
00007fa6 icall.obj (.text:ICall_primCreateTask$15)
ti_sysbios_knl_Task_Params__init__S $Tramp$TT$L$PI$$ti_sysbios_knl_Task_Params__init__S
1001c1d9 0000ad64 000060aa icall.obj (.text:ICall_createRemoteTasks)
00007f90 icall.obj (.text:ICall_primCreateTask$15)
0000808e peripheral.obj (.text:GAPRole_createTask)
000084ea simple_peripheral.obj (.text:SimpleBLEPeripheral_createTask)
ti_sysbios_knl_Clock_create $Tramp$TT$L$PI$$ti_sysbios_knl_Clock_create
1001b3ed 0000ad6c 00005e2e icall.obj (.text:ICall_primSetTimer$15)
ti_sysbios_knl_Clock_scheduleNextTick__E $Tramp$TT$L$PI$$ti_sysbios_knl_Clock_scheduleNextTick__E
1001bebd 0000ad74 000059f6 rom_sysbios.aem3 : rom_sysbios.obj (.text:ti_sysbios_knl_Clock_workFuncDynamic__E)
ti_sysbios_knl_Clock_walkQueueDynamic__E $Tramp$TT$L$PI$$ti_sysbios_knl_Clock_walkQueueDynamic__E
1001a80d 0000ad7c 000059be rom_sysbios.aem3 : rom_sysbios.obj (.text:ti_sysbios_knl_Clock_workFuncDynamic__E)
000059da : rom_sysbios.obj (.text:ti_sysbios_knl_Clock_workFuncDynamic__E)
ti_sysbios_knl_Clock_TimerProxy_getCurrentTick__E $Tramp$TT$L$PI$$ti_sysbios_knl_Clock_TimerProxy_getCurrentTick__E
1001c095 0000ad84 0000598c rom_sysbios.aem3 : rom_sysbios.obj (.text:ti_sysbios_knl_Clock_workFuncDynamic__E)
0000962a : rom_sysbios.obj (.text:ti_sysbios_knl_Clock_getTicksUntilInterrupt__E)
ti_sysbios_knl_Semaphore_destruct $Tramp$TT$L$PI$$ti_sysbios_knl_Semaphore_destruct
1001c2e1 0000ad8c 00005092 SPICC26XXDMA.obj (.text:SPICC26XXDMA_close)
ti_sysbios_knl_Swi_destruct $Tramp$TT$L$PI$$ti_sysbios_knl_Swi_destruct
1001c2e9 0000ad94 00005080 SPICC26XXDMA.obj (.text:SPICC26XXDMA_close)
ti_sysbios_family_arm_m3_Hwi_destruct $Tramp$TT$L$PI$$ti_sysbios_family_arm_m3_Hwi_destruct
1001c261 0000ad9c 00005078 SPICC26XXDMA.obj (.text:SPICC26XXDMA_close)
000088d2 UDMACC26XX.obj (.text:UDMACC26XX_close)
ti_sysbios_knl_Queue_get__E $Tramp$TT$L$PI$$ti_sysbios_knl_Queue_get__E
1001bf11 0000ada4 00004f5e simple_peripheral.obj (.text:SimpleBLEPeripheral_taskFxn$2)
0000a18a util.obj (.text:Util_dequeueMsg)
ti_sysbios_knl_Queue_empty__E $Tramp$TT$L$PI$$ti_sysbios_knl_Queue_empty__E
1001c113 0000adac 00004f36 simple_peripheral.obj (.text:SimpleBLEPeripheral_taskFxn$2)
00004f54 simple_peripheral.obj (.text:SimpleBLEPeripheral_taskFxn$2)
ti_sysbios_BIOS_getCpuFreq__E $Tramp$TT$L$PI$$ti_sysbios_BIOS_getCpuFreq__E
1001bff9 0000adb4 000048f6 SPICC26XXDMA.obj (.text:SPICC26XXDMA_initHw$11)
ti_sysbios_knl_Semaphore_post__E $Tramp$TT$L$PI$$ti_sysbios_knl_Semaphore_post__E
1001ac41 0000adbc 000046f0 icall.obj (.text:ICall_primWaitMatch$15)
000058ce PINCC26XX.obj (.text:PIN_open)
00005906 RFCC26XX_singleMode.obj (.text:fsmPowerDownState$9)
00005ae6 SPICC26XXDMA.obj (.text:SPICC26XXDMA_transferCallback$11)
000064ae icall.obj (.text:ICall_primSend$15)
00006c4c PINCC26XX.obj (.text:PIN_add)
00007874 RFCC26XX_singleMode.obj (.text:syncCb$9)
00007ba6 simple_peripheral.obj (.text:SimpleBLEPeripheral_processOadWriteCB)
000096e8 util.obj (.text:Util_enqueueMsg)
0000a4ce peripheral.obj (.text:gapRole_setEvent$25)
0000a6c8 simple_peripheral.obj (.text:SimpleBLEPeripheral_clockHandler$2)
0000aab8 icall.obj (.text:ICall_primSignal$15)
ti_sysbios_knl_Clock_getTicks__E $Tramp$TT$L$PI$$ti_sysbios_knl_Clock_getTicks__E
1001b6d9 0000adc4 00004668 icall.obj (.text:ICall_primWaitMatch$15)
000046d2 icall.obj (.text:ICall_primWaitMatch$15)
0000a962 icall.obj (.text:ICall_primGetTicks$15)
ti_sysbios_knl_Task_self__E $Tramp$TT$L$PI$$ti_sysbios_knl_Task_self__E
1001c1e5 0000adcc 0000461e icall.obj (.text:ICall_primWaitMatch$15)
00006cc8 icall.obj (.text:ICall_primEnroll$15)
00006f14 icall.obj (.text:ICall_primThreadServes$15)
000075ac icall.obj (.text:ICall_primWait$15)
000076f0 icall.obj (.text:ICall_primRegisterApp$15)
00007964 icall.obj (.text:ICall_primGetEntityId$15)
00008a24 icall.obj (.text:ICall_primFetchMsg$15)
ti_sysbios_family_arm_m3_Hwi_enableInterrupt__E $Tramp$TT$L$PI$$ti_sysbios_family_arm_m3_Hwi_enableInterrupt__E
1001b2dd 0000add4 000042b6 RFCC26XX_singleMode.obj (.text:fsmPowerUpState$9)
ti_sysbios_knl_Clock_construct $Tramp$TT$L$PI$$ti_sysbios_knl_Clock_construct
1001b579 0000addc 0000403a drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:Power_init)
00004048 : PowerCC26XX.oem3 (.text:Power_init)
00004056 : PowerCC26XX.oem3 (.text:Power_init)
000047a4 RFCC26XX_singleMode.obj (.text:rf_init$9)
0000503e RFCC26XX_singleMode.obj (.text:RF_open)
0000688c drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:PowerCC26XX_calibrate)
00007bf0 util.obj (.text:Util_constructClock)
ti_sysbios_knl_Clock_Params__init__S $Tramp$TT$L$PI$$ti_sysbios_knl_Clock_Params__init__S
1001c185 0000ade4 00004022 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:Power_init)
0000502e RFCC26XX_singleMode.obj (.text:RF_open)
00005e1a icall.obj (.text:ICall_primSetTimer$15)
00006874 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:PowerCC26XX_calibrate)
00007bca util.obj (.text:Util_constructClock)
xdc_runtime_Text_ropeText__E $Tramp$TT$L$PI$$xdc_runtime_Text_ropeText__E
1001c7e9 0000adec 00003b72 uart_logs.obj (.text:uartLog_doPrint$1)
00007aac rom_sysbios.aem3 : rom_sysbios.obj (.text:xdc_runtime_Text_visitRope2__I)
00007aba : rom_sysbios.obj (.text:xdc_runtime_Text_visitRope2__I)
xdc_runtime_System_abortSpin__E $Tramp$TT$L$PI$$xdc_runtime_System_abortSpin__E
1001c899 0000adf4 0000348e drivers_cc26xxware.aem3 : PowerCC26XX_calibrateRCOSC.oem3 (.text:PowerCC26XX_doCalibrate)
00006da6 : PowerCC26XX_calibrateRCOSC.oem3 (.text:PowerCC26XX_RCOSC_clockFunc)
ti_sysbios_knl_Clock_start__E $Tramp$TT$L$PI$$ti_sysbios_knl_Clock_start__E
1001bfe3 0000adfc 00003326 RFCC26XX_singleMode.obj (.text:RF_postCmd)
0000350c drivers_cc26xxware.aem3 : PowerCC26XX_calibrateRCOSC.oem3 (.text:PowerCC26XX_doCalibrate)
000040d4 : PowerCC26XX.oem3 (.text:Power_init)
00004a5e RFCC26XX_singleMode.obj (.text:radioOpDoneCb$9)
00004c90 power_cc26xx_tirtos.aem3 : PowerCC26XX_tirtos.oem3 (.text:PowerCC26XX_standbyPolicy)
00005cae drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:switchXOSCHFclockFunc)
00005e72 icall.obj (.text:ICall_primSetTimer$15)
00006140 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:disableLFClockQualifiers)
00006b80 RFCC26XX_singleMode.obj (.text:decActiveClientCnt$9)
000071be RFCC26XX_singleMode.obj (.text:fsmXOSCState$9)
000074ea drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:configureXOSCHF)
000087c4 util.obj (.text:Util_restartClock)
00009e2a rom_sysbios.aem3 : rom_sysbios.obj (.text:ti_sysbios_knl_Clock_stop__E)
0000ab0a util.obj (.text:Util_startClock)
ti_sysbios_knl_Clock_setTimeout__E $Tramp$TT$L$PI$$ti_sysbios_knl_Clock_setTimeout__E
1001c2c1 0000ae04 00003320 RFCC26XX_singleMode.obj (.text:RF_postCmd)
000040ce drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:Power_init)
00004a56 RFCC26XX_singleMode.obj (.text:radioOpDoneCb$9)
00004c8a power_cc26xx_tirtos.aem3 : PowerCC26XX_tirtos.oem3 (.text:PowerCC26XX_standbyPolicy)
00005ca8 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:switchXOSCHFclockFunc)
00005e6c icall.obj (.text:ICall_primSetTimer$15)
0000613a drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:disableLFClockQualifiers)
00006b7a RFCC26XX_singleMode.obj (.text:decActiveClientCnt$9)
000071b8 RFCC26XX_singleMode.obj (.text:fsmXOSCState$9)
000074e4 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:configureXOSCHF)
000087be util.obj (.text:Util_restartClock)
ti_sysbios_knl_Semaphore_pend__E $Tramp$TT$L$PI$$ti_sysbios_knl_Semaphore_pend__E
1001a0cd 0000ae0c 00002bce SPICC26XXDMA.obj (.text:SPICC26XXDMA_transfer)
00002be2 SPICC26XXDMA.obj (.text:SPICC26XXDMA_transfer)
0000467c icall.obj (.text:ICall_primWaitMatch$15)
0000585c PINCC26XX.obj (.text:PIN_open)
00005ed0 RFCC26XX_singleMode.obj (.text:RF_pendCmd)
00006c20 PINCC26XX.obj (.text:PIN_add)
000075ec icall.obj (.text:ICall_primWait$15)
ti_sysbios_knl_Swi_post__E $Tramp$TT$L$PI$$ti_sysbios_knl_Swi_post__E
1001b321 0000ae14 000029ba SPICC26XXDMA.obj (.text:SPICC26XXDMA_hwiFxn$11)
0000a554 rom_sysbios.aem3 : rom_sysbios.obj (.text:ti_sysbios_knl_Swi_or__E)
0000a72a app_ble_pem3.oem3 (.text:ti_sysbios_knl_Clock_doTick__I)
ti_sysbios_knl_Task_restore__E $Tramp$TT$L$PI$$ti_sysbios_knl_Task_restore__E
1001ba49 0000ae1c 000020f0 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:Power_sleep)
000060ea icall.obj (.text:ICall_createRemoteTasks)
0000a596 icall.obj (.text:ICall_leaveCSImpl)
ti_sysbios_knl_Swi_restore__E $Tramp$TT$L$PI$$ti_sysbios_knl_Swi_restore__E
1001b5e1 0000ae24 000020e6 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:Power_sleep)
000037f0 RFCC26XX_singleMode.obj (.text:abortCmd$9)
00005e98 RFCC26XX_singleMode.obj (.text:RF_pendCmd)
00005ec4 RFCC26XX_singleMode.obj (.text:RF_pendCmd)
00005ee4 RFCC26XX_singleMode.obj (.text:RF_pendCmd)
ti_sysbios_knl_Swi_disable__E $Tramp$TT$L$PI$$ti_sysbios_knl_Swi_disable__E
1001c0d5 0000ae2c 00001f42 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:Power_sleep)
000037ce RFCC26XX_singleMode.obj (.text:abortCmd$9)
00005e86 RFCC26XX_singleMode.obj (.text:RF_pendCmd)
00009126 app_ble_pem3.oem3 (.text:ti_sysbios_BIOS_atExitFunc__I)
ti_sysbios_knl_Task_disable__E $Tramp$TT$L$PI$$ti_sysbios_knl_Task_disable__E
1001c0f5 0000ae34 00001f2a drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:Power_sleep)
00006094 icall.obj (.text:ICall_createRemoteTasks)
0000912a app_ble_pem3.oem3 (.text:ti_sysbios_BIOS_atExitFunc__I)
0000a120 icall.obj (.text:ICall_enterCSImpl)
0000a926 icall.obj (.text:ICall_primDisableMInt$15)
ti_sysbios_knl_Semaphore_construct $Tramp$TT$L$PI$$ti_sysbios_knl_Semaphore_construct
1001b709 0000ae3c 000011e0 SPICC26XXDMA.obj (.text:SPICC26XXDMA_open)
00003130 PINCC26XX.obj (.text:PIN_init)
00005022 RFCC26XX_singleMode.obj (.text:RF_open)
ti_sysbios_knl_Semaphore_Params__init__S $Tramp$TT$L$PI$$ti_sysbios_knl_Semaphore_Params__init__S
1001c1c1 0000ae44 000011ce SPICC26XXDMA.obj (.text:SPICC26XXDMA_open)
0000311c PINCC26XX.obj (.text:PIN_init)
00005012 RFCC26XX_singleMode.obj (.text:RF_open)
ti_sysbios_knl_Swi_construct $Tramp$TT$L$PI$$ti_sysbios_knl_Swi_construct
1001b085 0000ae4c 00001182 SPICC26XXDMA.obj (.text:SPICC26XXDMA_open)
000031c6 PINCC26XX.obj (.text:PIN_init)
00004730 RFCC26XX_singleMode.obj (.text:rf_init$9)
00004772 RFCC26XX_singleMode.obj (.text:rf_init$9)
ti_sysbios_knl_Swi_Params__init__S $Tramp$TT$L$PI$$ti_sysbios_knl_Swi_Params__init__S
1001c1cd 0000ae54 0000116c SPICC26XXDMA.obj (.text:SPICC26XXDMA_open)
000031b4 PINCC26XX.obj (.text:PIN_init)
0000471c RFCC26XX_singleMode.obj (.text:rf_init$9)
00004762 RFCC26XX_singleMode.obj (.text:rf_init$9)
ti_sysbios_family_arm_m3_Hwi_construct $Tramp$TT$L$PI$$ti_sysbios_family_arm_m3_Hwi_construct
1001af29 0000ae5c 00001160 SPICC26XXDMA.obj (.text:SPICC26XXDMA_open)
000031a8 PINCC26XX.obj (.text:PIN_init)
00004756 RFCC26XX_singleMode.obj (.text:rf_init$9)
00004796 RFCC26XX_singleMode.obj (.text:rf_init$9)
0000689c drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:PowerCC26XX_calibrate)
00007108 UDMACC26XX.obj (.text:UDMACC26XX_open)
ti_sysbios_family_arm_m3_Hwi_Params__init__S $Tramp$TT$L$PI$$ti_sysbios_family_arm_m3_Hwi_Params__init__S
1001c13d 0000ae64 00001142 SPICC26XXDMA.obj (.text:SPICC26XXDMA_open)
00003192 PINCC26XX.obj (.text:PIN_init)
0000473c RFCC26XX_singleMode.obj (.text:rf_init$9)
0000477e RFCC26XX_singleMode.obj (.text:rf_init$9)
000070f2 UDMACC26XX.obj (.text:UDMACC26XX_open)
ti_sysbios_family_arm_m3_Hwi_restoreFxn__E $Tramp$TT$L$PI$$ti_sysbios_family_arm_m3_Hwi_restoreFxn__E
1001c219 0000ae6c 00001044 SPICC26XXDMA.obj (.text:SPICC26XXDMA_open)
00001132 SPICC26XXDMA.obj (.text:SPICC26XXDMA_open)
0000128e SPICC26XXDMA.obj (.text:SPICC26XXDMA_open)
00001c64 RFCC26XX_singleMode.obj (.text:fsmActiveState$9)
00001c7e RFCC26XX_singleMode.obj (.text:fsmActiveState$9)
00002b2e SPICC26XXDMA.obj (.text:SPICC26XXDMA_transfer)
00002b64 SPICC26XXDMA.obj (.text:SPICC26XXDMA_transfer)
00002be8 SPICC26XXDMA.obj (.text:SPICC26XXDMA_transfer)
00002f80 SPICC26XXDMA.obj (.text:SPICC26XXDMA_swiFxn$11)
000032ce RFCC26XX_singleMode.obj (.text:RF_postCmd)
00003330 RFCC26XX_singleMode.obj (.text:RF_postCmd)
0000338c RFCC26XX_singleMode.obj (.text:RF_postCmd)
00003550 SPICC26XXDMA.obj (.text:SPICC26XXDMA_transferCancel)
000035c2 SPICC26XXDMA.obj (.text:SPICC26XXDMA_transferCancel)
00003658 SPICC26XXDMA.obj (.text:SPICC26XXDMA_transferCancel)
00003724 RFCC26XX_singleMode.obj (.text:abortCmd$9)
0000374c RFCC26XX_singleMode.obj (.text:abortCmd$9)
00003780 RFCC26XX_singleMode.obj (.text:abortCmd$9)
000037e2 RFCC26XX_singleMode.obj (.text:abortCmd$9)
00003812 RFCC26XX_singleMode.obj (.text:abortCmd$9)
00004a16 RFCC26XX_singleMode.obj (.text:radioOpDoneCb$9)
00004b40 PINCC26XX.obj (.text:PINCC26XX_setIoCfg$8)
00004dd6 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:Power_releaseDependency)
00004ea6 : PowerCC26XX.oem3 (.text:Power_setDependency)
00004fc4 RFCC26XX_singleMode.obj (.text:RF_open)
00004fd2 RFCC26XX_singleMode.obj (.text:RF_open)
000050a8 SPICC26XXDMA.obj (.text:SPICC26XXDMA_close)
00005cd6 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:switchXOSCHFclockFunc)
00005f6e TRNGCC26XX.obj (.text:TRNGCC26XX_getNumber)
00005fd0 RFCC26XX_singleMode.obj (.text:swiFxnHw$9)
00005fea RFCC26XX_singleMode.obj (.text:swiFxnHw$9)
00006080 uart_logs.obj (.text:uartLog_outputFxn)
00006b86 RFCC26XX_singleMode.obj (.text:decActiveClientCnt$9)
00006be2 uart_logs.obj (.text:uartLog_flush)
00006df6 RFCC26XX_singleMode.obj (.text:RF_getCurrentTime)
00006dfe RFCC26XX_singleMode.obj (.text:RF_getCurrentTime)
00007116 UDMACC26XX.obj (.text:UDMACC26XX_open)
000073ca drivers_cc26xxware.aem3 : PowerCC26XX_calibrateRCOSC.oem3 (.text:PowerCC26XX_initiateCalibration)
0000759a RFCC26XX_singleMode.obj (.text:ratChanFree$9)
000077ce RFCC26XX_singleMode.obj (.text:RF_getInfo)
000081a0 RFCC26XX_singleMode.obj (.text:RF_getRssi)
000085ac RFCC26XX_singleMode.obj (.text:postDirImmCmd$9)
000085c0 RFCC26XX_singleMode.obj (.text:postDirImmCmd$9)
000088e0 UDMACC26XX.obj (.text:UDMACC26XX_close)
00008b7c drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:PowerCC26XX_isStableXOSC_HF)
00008bb8 RFCC26XX_singleMode.obj (.text:Q_push$9)
00008ff8 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:Power_releaseConstraint)
00009028 : PowerCC26XX.oem3 (.text:Power_setConstraint)
00009852 : PowerCC26XX.oem3 (.text:PowerCC26XX_switchXOSC_HF)
00009966 TRNGCC26XX.obj (.text:TRNGCC26XX_init)
00009a5c drivers_cc26xxware.aem3 : List.oem3 (.text:List_put)
00009d8c : PowerCC26XX.oem3 (.text:Power_unregisterNotify)
0000a06a TRNGCC26XX.obj (.text:TRNGCC26XX_open)
0000a458 RFCC26XX_singleMode.obj (.text:Q_pop$9)
0000a58e icall.obj (.text:ICall_leaveCSImpl)
ti_sysbios_family_arm_m3_Hwi_disableFxn__E $Tramp$TT$L$PI$$ti_sysbios_family_arm_m3_Hwi_disableFxn__E
1001c149 0000ae74 00001020 SPICC26XXDMA.obj (.text:SPICC26XXDMA_open)
0000112a SPICC26XXDMA.obj (.text:SPICC26XXDMA_open)
00001c44 RFCC26XX_singleMode.obj (.text:fsmActiveState$9)
00002b16 SPICC26XXDMA.obj (.text:SPICC26XXDMA_transfer)
00002b36 SPICC26XXDMA.obj (.text:SPICC26XXDMA_transfer)
00002f5a SPICC26XXDMA.obj (.text:SPICC26XXDMA_swiFxn$11)
00003220 RFCC26XX_singleMode.obj (.text:RF_postCmd)
000032e4 RFCC26XX_singleMode.obj (.text:RF_postCmd)
00003542 SPICC26XXDMA.obj (.text:SPICC26XXDMA_transferCancel)
0000359a SPICC26XXDMA.obj (.text:SPICC26XXDMA_transferCancel)
000036c4 RFCC26XX_singleMode.obj (.text:abortCmd$9)
000049f4 RFCC26XX_singleMode.obj (.text:radioOpDoneCb$9)
00004b22 PINCC26XX.obj (.text:PINCC26XX_setIoCfg$8)
00004d22 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:Power_releaseDependency)
00004df6 : PowerCC26XX.oem3 (.text:Power_setDependency)
00004fbc RFCC26XX_singleMode.obj (.text:RF_open)
0000509e SPICC26XXDMA.obj (.text:SPICC26XXDMA_close)
00005c60 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:switchXOSCHFclockFunc)
00005f0a TRNGCC26XX.obj (.text:TRNGCC26XX_getNumber)
00005f8a RFCC26XX_singleMode.obj (.text:swiFxnHw$9)
00006012 uart_logs.obj (.text:uartLog_outputFxn)
00006b30 RFCC26XX_singleMode.obj (.text:decActiveClientCnt$9)
00006baa uart_logs.obj (.text:uartLog_flush)
00006de6 RFCC26XX_singleMode.obj (.text:RF_getCurrentTime)
000070de UDMACC26XX.obj (.text:UDMACC26XX_open)
000073b6 drivers_cc26xxware.aem3 : PowerCC26XX_calibrateRCOSC.oem3 (.text:PowerCC26XX_initiateCalibration)
00007558 RFCC26XX_singleMode.obj (.text:ratChanFree$9)
00007792 RFCC26XX_singleMode.obj (.text:RF_getInfo)
00008190 RFCC26XX_singleMode.obj (.text:RF_getRssi)
00008594 RFCC26XX_singleMode.obj (.text:postDirImmCmd$9)
000088b6 UDMACC26XX.obj (.text:UDMACC26XX_close)
00008b5a drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:PowerCC26XX_isStableXOSC_HF)
00008b9a RFCC26XX_singleMode.obj (.text:Q_push$9)
00008ba2 RFCC26XX_singleMode.obj (.text:Q_push$9)
00008fd8 drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:Power_releaseConstraint)
00009008 : PowerCC26XX.oem3 (.text:Power_setConstraint)
00009836 : PowerCC26XX.oem3 (.text:PowerCC26XX_switchXOSC_HF)
0000994e TRNGCC26XX.obj (.text:TRNGCC26XX_init)
00009d7c drivers_cc26xxware.aem3 : PowerCC26XX.oem3 (.text:Power_unregisterNotify)
0000a05e TRNGCC26XX.obj (.text:TRNGCC26XX_open)
0000a12a icall.obj (.text:ICall_enterCSImpl)
0000a44c RFCC26XX_singleMode.obj (.text:Q_pop$9)
0000a92a icall.obj (.text:ICall_primDisableMInt$15)
0000aca6 tirtosport.aem3 : HwiP_tirtos.oem3 (.text:HwiP_disable)
[61 trampolines]
[267 trampoline calls]
GLOBAL SYMBOLS: SORTED ALPHABETICALLY BY Name
address name
10014c00 A1_rw
10019ffe A2_rw
10019ffc A3_rw
20004f2c A4_rw
20004f7c ACCX
20004f80 ACCY
20004f84 ACCZ
10015229 ATOMICPATTERN
10016c29 AddRoundKeySubBytes_Sw
10018a19 AesCcm_authEncrypt_Sw
10018a35 AesCcm_decryptAuth_Sw
10018b09 AesCcm_getNumBlocks_Sw
10018ac5 Aes_decrypt_Sw
10018a99 Aes_encrypt_Sw
00007cd5 AssertHandler
0000cbc0 BoardGpioInitTable
00007eb1 C$$EXIT
20004f2c COMMON_RAM_BASE_ADDR
10014c01 COMMON_ROM_BASE_ADDR
10015a6d COPY
000075fd DEV_SPI_WriteByte
00005847 DefaultAssertCback
0000a5f5 DevInfo_AddService
0000a77d DevInfo_SetParameter
10017959 ECC_allocWorkzone
10017961 ECC_setWin
10017969 ECDSA_sign
10017b01 ECDSA_verif
0000891d EPD_2IN66_SendCommand
00008951 EPD_2IN66_SendData
00008e25 EPD_4IN2_ReadBusy
00007d19 EPD_4IN2_Reset
0000a8ed EPD_7IN5_TurnOnDisplay
00008e55 EPD_7IN5_V2_Clear
00005a11 EPD_7IN5_V2_Init
10015a11 EXPORTOPERAND
20004f78 EXPW
20004f6c EXPX
20004f70 EXPY
20004f74 EXPZ
00008e85 ExtFlash_close
00006ea5 ExtFlash_erase
00007fc1 ExtFlash_open
00008001 ExtFlash_read
00006691 ExtFlash_write
10016f58 FFMult2
10017058 FFMult3
10016d05 FFMult_Sw
10018d6c Fill1
00008681 GAPBondMgr_LinkEst
00009a63 GAPBondMgr_LinkTerm
00009359 GAPBondMgr_Register
00008985 GAPBondMgr_SetParameter
00003ed5 GAPRole_GetParameter
00008041 GAPRole_SendUpdateParam
00001ccd GAPRole_SetParameter
00009ef1 GAPRole_StartDevice
0000a209 GAPRole_TerminateConnection
00008081 GAPRole_createTask
0000764d GAP_DeviceInit
0000a79d GAP_EndDiscoverable
000082fd GAP_GetParamValue
0000aa39 GAP_MakeDiscoverable
0000abe1 GAP_RegisterForMsgs
000089b9 GAP_SetParamValue
0000aa45 GAP_TerminateAuth
00007d5d GAP_TerminateLinkReq
0000769d GAP_UpdateAdvertisingData
0000aa51 GAP_UpdateLinkParamReq
0000aa5d GAP_UpdateLinkParamReqReply
0000aca3 GATTServApp_AddService
0000a73d GATTServApp_FindAttr
00009c59 GATTServApp_InitCharCfg
00007455 GATTServApp_ProcessCCCWriteReq
00006369 GATTServApp_ProcessCharCfg
0000a7ad GATTServApp_ReadCharCfg
00008339 GATTServApp_RegisterService
00009743 GATTServApp_WriteCharCfg
0000a8fb GATT_Indication
0000a105 GATT_Notification
0000abe9 GATT_RegisterForMsgs
000080c1 GATT_SendRsp
00009f0d GATT_bm_alloc
00009f29 GATT_bm_free
10015141 GETBIT
10015155 GETDIGIT
100151a5 GETDIGITL2R
0000ac19 GGS_AddService
0000aa69 GGS_SetParameter
00009385 HCI_EXT_ConnEventNoticeCmd
0000a7bd HCI_LE_ReadMaxDataLenCmd
20001510 HEAPMGR_SIZE
0000aca7 HwiP_disable
UNDEFED HwiP_restore
00008375 ICallPlatform_pwrConfigACAction
0000a221 ICallPlatform_pwrDispense
0000a909 ICallPlatform_pwrGetTransitionState
0000a7cd ICallPlatform_pwrGetXOSCStartupTime
0000a917 ICallPlatform_pwrIsStableXOSCHF
000078c9 ICallPlatform_pwrRegisterNotify
0000a239 ICallPlatform_pwrRequire
0000ab7d ICallPlatform_pwrSwitchXOSCHF
000063dd ICallPlatform_pwrUpdActivityCounter
0000608d ICall_createRemoteTasks
200014ec ICall_dispatcher
0000a11f ICall_enterCSImpl
200014f4 ICall_enterCriticalSection
000093b1 ICall_freeImpl
000093b1 ICall_heapFree
00006771 ICall_heapInit
00005d79 ICall_heapMalloc
0000976d ICall_init
0000a587 ICall_leaveCSImpl
200014f8 ICall_leaveCriticalSection
0000ac1f ICall_mallocImpl
00008abd ICall_searchServiceEntity
10015a35 IMPORTDATA
100159a9 IMPORTLENGTH
100159ad IMPORTMODULUS
100159d1 IMPORTOPERAND
1001568d INVERT
10016da1 InvAddRoundKey_Sw
10016ed5 InvMixColumns_Sw
10016dc9 InvRoundKey_Sw
10017264 InvSbox
10016ea1 InvShiftRows_Sw
10016e8d InvSubBytes_Sw
100154f5 JACADD
20004fe8 LEN
100158ac LUTC
100158dc LUTINCI
100158f4 LUTJ
1001588c LUTOPCODE
10015894 LUTOPSIGN
100158c4 LUTSE
1001596c LUTSTATE
0000ab91 List_empty
0000acaf List_head
0000acb3 List_next
00009a3d List_put
0000a153 List_remove
10018825 MB_ClearInts
100187f5 MB_DisableInts
10018835 MB_EnableHWInts
10018799 MB_EnableInts
10018945 MB_FwDebugDump
10018755 MB_Init
10018935 MB_ReadMailboxStatus
1001893d MB_RegisterIsrCback
10018865 MB_SendCommand
100188a5 MB_SendCommandSynch
20004fe4 MOD
20004fd8 MSBMOD
10016c79 MixColumns_Sw
10018b9c NIST_Curve_P256_Gx
10018bc0 NIST_Curve_P256_Gy
10018b54 NIST_Curve_P256_a
10018b78 NIST_Curve_P256_b
10018b0c NIST_Curve_P256_p
10018b30 NIST_Curve_P256_r
0000980d NOROM_AONBatMonTemperatureGetDegC
0000a61d NOROM_AONRTCCurrent64BitValueGet
0000a311 NOROM_AONRTCCurrentCompareValueGet
0000aac1 NOROM_CPUcpsid
0000aacd NOROM_CPUcpsie
0000ac25 NOROM_CPUdelay
00007add NOROM_ChipInfo_GetChipFamily
00006621 NOROM_ChipInfo_GetHwRevision
0000a329 NOROM_ChipInfo_GetPackageType
00008101 NOROM_DDI16BitfieldRead
00007b25 NOROM_DDI16BitfieldWrite
000094e5 NOROM_DDI32RegWrite
00009f99 NOROM_OSCClockSourceGet
000079ad NOROM_OSCClockSourceSet
00006f5d NOROM_OSCHF_AttemptToSwitchToXosc
00005ced NOROM_OSCHF_GetStartupTime
00008af1 NOROM_OSCHF_SwitchToRcOscTurnOffXosc
0000a341 NOROM_OSCHF_TurnOnXosc
000083b1 NOROM_OSC_HPOSCRelativeFrequencyOffsetGet
000061ff NOROM_RFCAdi3VcoLdoVoltageMode
0000a359 NOROM_RFCCpeIntGetAndClear
00009d19 NOROM_RFCDoorbellSendTo
000066ff NOROM_RFCRTrim
00009d39 NOROM_RFCRfTrimRead
0000a7fd NOROM_RFCRfTrimSet
000083ed NOROM_RFCSynthPowerDown
00006201 NOROM_SetupAfterColdResetWakeupFromShutDownCfg1
000047ed NOROM_SetupAfterColdResetWakeupFromShutDownCfg2
00003da5 NOROM_SetupAfterColdResetWakeupFromShutDownCfg3
0000a371 NOROM_SetupGetTrimForAdcShModeEn
0000a389 NOROM_SetupGetTrimForAdcShVbufEn
000067dd NOROM_SetupGetTrimForAmpcompCtrl
0000a3a1 NOROM_SetupGetTrimForAmpcompTh1
00009fb5 NOROM_SetupGetTrimForAmpcompTh2
000069f5 NOROM_SetupGetTrimForAnabypassValue1
0000a3b9 NOROM_SetupGetTrimForDblrLoopFilterResetVoltage
00009511 NOROM_SetupGetTrimForRadcExtCfg
0000a3d1 NOROM_SetupGetTrimForRcOscLfIBiasTrim
00009fd1 NOROM_SetupGetTrimForRcOscLfRtuneCtuneTrim
00009d59 NOROM_SetupGetTrimForXoscHfCtl
0000a80d NOROM_SetupGetTrimForXoscHfFastStart
0000a81d NOROM_SetupGetTrimForXoscHfIbiastherm
0000a3e9 NOROM_SetupGetTrimForXoscLfRegulatorAndCmirrwrRatio
00008f75 NOROM_SetupSetAonRtcSubSecInc
0000773d NOROM_SetupSetCacheModeAccordingToCcfgSetting
0000548d NOROM_SetupTrimDevice
00006fb9 NOROM_SysCtrlAdjustRechargeAfterPowerDown
00002131 NOROM_SysCtrlSetRechargeBeforePowerDown
00006a5d NOROM_SysCtrl_DCDC_VoltageConditionalControl
00008b25 NOROM_TRNGConfigure
0000a631 NOROM_ThisCodeIsBuiltForCC26xxHwRev22AndLater_HaltIfViolated
0000a96d NOROM_VIMSModeGet
0000a645 OADTarget_close
0000ac2b OADTarget_eraseFlash
0000a82d OADTarget_getCrc
00006ac5 OADTarget_getCurrentImageHeader
0000a97b OADTarget_imageAddress
0000a401 OADTarget_open
0000ab9b OADTarget_readFlash
0000a83d OADTarget_setCrc
00008141 OADTarget_storeImageHeader
0000a84d OADTarget_systemReset
00007015 OADTarget_validateNewImage
0000a659 OADTarget_writeFlash
000072f5 OAD_addService
00005335 OAD_imgBlockWrite
00005675 OAD_imgIdentifyWrite
0000a66d OAD_register
200016e4 OneTimeVar
10014c04 P1_ro
10019ffe P1_ro_2
20004f40 P2_rw
20004f40 P2_s0
20004fac P2_zi
00008429 PINCC26XX_getConfig
00009ad1 PINCC26XX_getPinCount
0000953d PINCC26XX_setMux
20002324 PIN_HandleTable
20002290 PIN_NumPins
00006bfd PIN_add
00009e77 PIN_close
0000a419 PIN_getConfig
0000a681 PIN_getInputValue
00003065 PIN_init
00005849 PIN_open
0000aad9 PIN_registerIntCb
0000734d PIN_remove
00009569 PIN_setConfig
00008fa5 PIN_setInterrupt
000086f1 PIN_setOutputValue
00006d85 PowerCC26XX_RCOSC_clockFunc
000064c5 PowerCC26XX_auxISR
00006849 PowerCC26XX_calibrate
0000cb74 PowerCC26XX_config
000033b1 PowerCC26XX_doCalibrate
00005ced PowerCC26XX_getXoscStartupTime
000073a5 PowerCC26XX_initiateCalibration
00008b59 PowerCC26XX_isStableXOSC_HF
200012f4 PowerCC26XX_module
00004c49 PowerCC26XX_standbyPolicy
00009835 PowerCC26XX_switchXOSC_HF
0000aae5 Power_getConstraintMask
0000aaf1 Power_getDependencyCount
00009e95 Power_getTransitionLatency
0000aafd Power_getTransitionState
0000a431 Power_idleFunc
00003ff5 Power_init
0000985d Power_registerNotify
00008fd5 Power_releaseConstraint
00004d1d Power_releaseDependency
00009005 Power_setConstraint
00004df1 Power_setDependency
00001f09 Power_sleep
00009d79 Power_unregisterNotify
10017158 RCon
10018415 RFHAL_AddTxDataEntry
100184f9 RFHAL_AllocDataEntry
100184a9 RFHAL_AllocDataEntryQueue
10018315 RFHAL_AllocRatChan
100185e1 RFHAL_BuildDataEntryRingBuffer
10018669 RFHAL_BuildLinkedBuffer
10018551 RFHAL_BuildRingBuffer
10018549 RFHAL_FreeDataEntry
100184c5 RFHAL_FreeDataEntryQueue
10018485 RFHAL_FreeNextTxDataEntry
1001833d RFHAL_FreeRatChan
100184cd RFHAL_GetNextDataEntry
100184d1 RFHAL_GetTempDataEntry
100183b9 RFHAL_InitDataQueue
100182ad RFHAL_InitRfHal
10018369 RFHAL_MapRatChansToInt
100184d5 RFHAL_NextDataEntryDone
100183c5 RFHAL_QueueRFDataEntries
10018391 RFHAL_RegisterRatChanCallback
0000a695 RF_Params_init
000036b1 RF_cancelCmd
0000abf1 RF_flushCmd
0000a74f RF_getCmdOp
00006de5 RF_getCurrentTime
0000778d RF_getInfo
00008181 RF_getRssi
00004f8d RF_open
00005e81 RF_pendCmd
00003215 RF_postCmd
00008465 RF_runCmd
0000a025 RF_runDirectCmd
0000a041 RF_runImmediateCmd
0000a85d RegisterAssertCback
00007e29 ResetISR
10016b79 RoundKey_Sw
10015101 SAVEPOINT
20004f68 SCAL
100150e5 SCALARMUL
10014ced SCALARMUL_core
10015019 SCALARMUL_final
10014c05 SCALARMUL_init
10015a51 SETOPERAND
10015a91 SETWORD
10018089 SHA256_final
10018129 SHA256_full
10017ffd SHA256_init
10017ef1 SHA256_nextState
10018019 SHA256_process
10017e75 SHA256_round
10017f49 SHA256_saveBuffer
10017e39 SHA256_updateW
UNDEFED SHT$$INIT_ARRAY$$Base
UNDEFED SHT$$INIT_ARRAY$$Limit
00005055 SPICC26XXDMA_close
00004b6d SPICC26XXDMA_control
0000c7d0 SPICC26XXDMA_fxnTable
0000a989 SPICC26XXDMA_init
00001011 SPICC26XXDMA_open
00002afd SPICC26XXDMA_transfer
00003535 SPICC26XXDMA_transferCancel
0000a6a9 SPI_Params_init
0000aba5 SPI_close
0000ca7c SPI_config
0000caa0 SPI_defaultParams
00009035 SPI_open
0000abaf SPI_transfer
10015821 SQUAREMULTIPLYWORD
10017895 SSP_CCM_Auth_Encrypt_Sw
10017365 SSP_CCM_Auth_Sw
1001767d SSP_CCM_Decrypt_Sw
100174fd SSP_CCM_Encrypt_Sw
100178f5 SSP_CCM_InvAuth_Decrypt_Sw
10017839 SSP_CCM_InvAuth_Sw
10017771 SSP_CTR_Decrypt_Sw
100175ed SSP_CTR_Encrypt_Sw
000098ad SafeHapiVoid
10017164 Sbox
10015215 SelectReg
10016c45 ShiftRows_Sw
000084dd SimpleBLEPeripheral_createTask
00007b6d SimpleBLEPeripheral_processOadWriteCB
00009925 SimpleProfile_AddService
00007de5 SimpleProfile_GetParameter
0000a6d1 SimpleProfile_RegisterAppCBs
000073fd SimpleProfile_SetParameter
20004f88 TMP1
20004f8c TMP2
20004f90 TMP3
20004f94 TMP4
20004f98 TMP5
20004f9c TMP6
0000cbf0 TRNGCC26XXHWAttrs
0000cb84 TRNGCC26XX_config
00005f05 TRNGCC26XX_getNumber
0000994d TRNGCC26XX_init
0000969b TRNGCC26XX_isParamValid
0000a05d TRNGCC26XX_open
0000abb9 UART_write
000088b1 UDMACC26XX_close
0000cb94 UDMACC26XX_config
000062f1 UDMACC26XX_hwiIntFxn
000070cd UDMACC26XX_open
00007bb5 Util_constructClock
0000a997 Util_constructQueue
0000a187 Util_dequeueMsg
000096c5 Util_enqueueMsg
0000a86d Util_isActive
00008799 Util_restartClock
0000ab09 Util_startClock
0000acbb Util_stopClock
10015a85 ZERO
00000000 __ASM__
0000006f __ISA__
00000081 __PLAT__
20004318 __STACK_END
00000400 __STACK_SIZE
20004318 __STACK_TOP
000000a8 __TARG__
0000d2e8 __TI_CINIT_Base
0000d368 __TI_CINIT_Limit
0000d250 __TI_Handler_Table_Base
0000d25c __TI_Handler_Table_Limit
00005535 __TI_auto_init
20001838 __TI_cleanup_ptr
0000a9ad __TI_decompress_none
0000ac3d __TI_decompress_rle24
2000183c __TI_dtors_ptr
0000cc48 __TI_static_base__
0000ab15 __TI_zero_init
000000cd __TRDR__
00007c8d __aeabi_d2iz
00004421 __aeabi_dmul
00007fbf __aeabi_idiv0
0000a4f1 __aeabi_lmul
00006185 __aeabi_memclr
00006185 __aeabi_memclr4
00006185 __aeabi_memclr8
00005711 __aeabi_memcpy
00005711 __aeabi_memcpy4
00005711 __aeabi_memcpy8
00006187 __aeabi_memset
00006187 __aeabi_memset4
00006187 __aeabi_memset8
00009dd9 __aeabi_ui2d
00008201 __aeabi_uidiv
00008201 __aeabi_uidivmod
00002725 __aeabi_uldivmod
ffffffff __binit__
ffffffff __c_args__
000005ec __ccfg
10019ffe __checksum_CommonROM
10014c00 __checksum_begin_CommonROM
10019ffd __checksum_end_CommonROM
0000e0ea __checksum_value_CommonROM
10018ced __exit
20003f18 __stack
0000ac31 __xdc__init
200014e8 __xdc__init__addr
0000a4d9 _args_main
00007e29 _c_int00
00001000 _imgHdr
20001830 _lock
0000a6e5 _nop
0000a6ed _register_lock
0000a6e7 _register_unlock
20001834 _unlock
00007eb5 abort
20001848 appAssertCback
0000ca1a appearanceUUID
20004fdc aux64
ffffffff binit
0000ca16 charAggFormatUUID
0000ca0c charExtPropsUUID
0000ca14 charFormatUUID
0000ca0e charUserDescUUID
0000ca02 characterUUID
0000ca10 clientCharCfgUUID
00007a45 copy_in
0000cb0c devInfo11073CertUUID
0000cb40 devInfoCBs
0000cb04 devInfoFirmwareRevUUID
0000cb06 devInfoHardwareRevUUID
0000cb0a devInfoMfrNameUUID
0000cb00 devInfoModelNumberUUID
0000cb0e devInfoPnpIdUUID
0000cb02 devInfoSerialNumberUUID
0000cafc devInfoServUUID
0000cb08 devInfoSoftwareRevUUID
0000cafe devInfoSystemIdUUID
0000ca18 deviceNameUUID
2000014c dispHandle
0000a5c9 driverTable_fnSpinlock
200024ad driverlib_release_0_47020
10017dbd eccRom_genKeys
10017ded eccRom_genSharedSecret
20004fa0 eccRom_param_Gx
20004fa4 eccRom_param_Gy
20004f50 eccRom_param_a
20004fa8 eccRom_param_b
20004f48 eccRom_param_p
20004f4c eccRom_param_r
20004f40 eccRom_windowSize
20004f44 eccRom_workzone
200016dc epdPinHandle
200016e8 epdPinState
200016f4 epdPinTable
00007ebd exit
0000ca26 extReportRefUUID
20004fcc fwInfoCmd
200005e0 gapRoleTask
20000630 gapRoleTaskStack
0000a4c1 gapRole_clockHandler
0000ca04 gapServiceUUID
0000ca06 gattServiceUUID
00009b19 getImageFlag
20003f18 heapEnd
200024ae heapStart
20004f58 inPointX
20004f5c inPointY
20004f54 inScalar
0000ca0a includeUUID
2000181c lastAppOpcodeSent
200004cc linkDBNumConns
00008bf5 linkDB_GetInfo
000087d1 linkDB_NumActive
00008809 linkDB_NumConns
10016551 mADD
10015bd5 mINVK
10015f81 mMULT
10016749 mOUT
10015a9d mSET
1001664d mSUB
000068b5 main
2000184c main_func_sp
10018949 mbCmdAckIsr
1001895d mbCpe0Isr
10018985 mbCpe1Isr
100189e5 mbHwIsr
00009c35 memcmp
00005711 memcpy
0000618d memset
0000c82c oadCBs
200016d8 one_ms
0000a0b1 openTRNG
00008c29 osal_snv_read
00008c5d osal_snv_write
20004f60 outPointX
20004f64 outPointY
20004ffc pSspAesEncrypt_Sw
0000ca20 periConnParamUUID
0000ca1c periPrivacyFlagUUID
20001820 pfnBMAlloc
20001824 pfnBMFree
0000ca00 primaryServiceUUID
20004fac ratChanInfo
0000ca1e reconnectAddrUUID
0000ca28 reportRefUUID
0000c878 resourceDB
0000c8c4 rfDriverTable
200015ec rfRegTbl
200016e0 rx_packet_counter
000090f5 saveImageInfo
200001f8 sbpTask
20000248 sbpTaskStack
0000ca08 secondaryServiceUUID
0000ca12 servCharCfgUUID
0000ca22 serviceChangedUUID
0000cb54 simpleProfileCBs
20000bec simpleProfileChar5
0000cbb4 simpleProfileServUUID
0000cbb6 simpleProfilechar1UUID
0000cbb8 simpleProfilechar2UUID
0000cbba simpleProfilechar3UUID
0000cbbc simpleProfilechar4UUID
0000cbbe simpleProfilechar5UUID
0000c994 spiCC26XXDMAHWAttrs
200020d8 spiCC26XXDMAObjects
10016d29 sspAesDecrypt_Sw
10016af5 sspAesEncryptBasic_Sw
10016a99 sspAesEncryptKeyExp_Sw
10016979 sspAesEncrypt_Sw
10016985 sspKeyExpansion_Sw
10016975 ssp_KeyInit_Sw
0000a6f9 strlen
200001a4 ti_sysbios_BIOS_Module__state__V
1001bc29 ti_sysbios_BIOS_RtsGateProxy_Handle__label__S
UNDEFED ti_sysbios_BIOS_RtsGateProxy_Handle__label__S__mangled__
1001bab9 ti_sysbios_BIOS_RtsGateProxy_Object__delete__S
UNDEFED ti_sysbios_BIOS_RtsGateProxy_Object__delete__S__mangled__
1001c179 ti_sysbios_BIOS_RtsGateProxy_Params__init__S
UNDEFED ti_sysbios_BIOS_RtsGateProxy_Params__init__S__mangled__
1001c249 ti_sysbios_BIOS_RtsGateProxy_enter__E
1001c24d ti_sysbios_BIOS_RtsGateProxy_leave__E
1001c275 ti_sysbios_BIOS_RtsGateProxy_query__E
UNDEFED ti_sysbios_BIOS_RtsGateProxy_query__E__mangled__
00009125 ti_sysbios_BIOS_atExitFunc__I
0000a5df ti_sysbios_BIOS_exitFunc__I
1001c035 ti_sysbios_BIOS_exit__E
1001bff9 ti_sysbios_BIOS_getCpuFreq__E
0000ab39 ti_sysbios_BIOS_getThreadType__E
000082bf ti_sysbios_BIOS_linkedWithIncorrectBootLibrary__E
0000976b ti_sysbios_BIOS_nullFunc__I
00009b85 ti_sysbios_BIOS_registerRTSLock__I
00009ba9 ti_sysbios_BIOS_removeRTSLock__I
00009df9 ti_sysbios_BIOS_rtsLock__I
0000a521 ti_sysbios_BIOS_rtsUnlock__I
1001c045 ti_sysbios_BIOS_setThreadType__E
00009155 ti_sysbios_BIOS_startFunc__I
1001c055 ti_sysbios_BIOS_start__E
0000548d ti_sysbios_family_arm_cc26xx_Boot_trimDevice
00000502 ti_sysbios_family_arm_cc26xx_Timer_Module__id__C
20001404 ti_sysbios_family_arm_cc26xx_Timer_Module__root__V
1001bb49 ti_sysbios_family_arm_cc26xx_Timer_Module__startupDone__S
200001e4 ti_sysbios_family_arm_cc26xx_Timer_Module__state__V
1001ba71 ti_sysbios_family_arm_cc26xx_Timer_Module_startup__E
20001690 ti_sysbios_family_arm_cc26xx_Timer_Object__table__V
0000a0cd ti_sysbios_family_arm_cc26xx_Timer_dynamicStub__E
0000acc7 ti_sysbios_family_arm_cc26xx_Timer_getCount64__E
00008879 ti_sysbios_family_arm_cc26xx_Timer_getCurrentTick__E
1001c251 ti_sysbios_family_arm_cc26xx_Timer_getExpiredTicks__E
000099c5 ti_sysbios_family_arm_cc26xx_Timer_getMaxTicks__E
1001c255 ti_sysbios_family_arm_cc26xx_Timer_getPeriod__E
00009185 ti_sysbios_family_arm_cc26xx_Timer_initDevice__I
1001a469 ti_sysbios_family_arm_cc26xx_Timer_periodicStub__E
1001b769 ti_sysbios_family_arm_cc26xx_Timer_postInit__I
00008df3 ti_sysbios_family_arm_cc26xx_Timer_setNextTick__E
1001c259 ti_sysbios_family_arm_cc26xx_Timer_setPeriod__E
000091b5 ti_sysbios_family_arm_cc26xx_Timer_setThreshold__I
00006c61 ti_sysbios_family_arm_cc26xx_Timer_start__E
00000484 ti_sysbios_family_arm_cc26xx_Timer_startupNeeded__C
1001b795 ti_sysbios_family_arm_cc26xx_Timer_startup__E
200001ec ti_sysbios_family_arm_cc26xx_TimestampProvider_Module__state__V
1001bb69 ti_sysbios_family_arm_cc26xx_TimestampProvider_Module_startup__E
0000aa1d ti_sysbios_family_arm_cc26xx_TimestampProvider_get32__E
1001b9d1 ti_sysbios_family_arm_cc26xx_TimestampProvider_get64__E
1001c12f ti_sysbios_family_arm_cc26xx_TimestampProvider_getFreq__E
00000504 ti_sysbios_family_arm_cc26xx_TimestampProvider_useClockTimer__C
00000488 ti_sysbios_family_arm_m3_Hwi_E_alreadyDefined__C
0000048c ti_sysbios_family_arm_m3_Hwi_E_hwiLimitExceeded__C
1001aed1 ti_sysbios_family_arm_m3_Hwi_Instance_finalize__E
1001a3c9 ti_sysbios_family_arm_m3_Hwi_Instance_init__E
2000142c ti_sysbios_family_arm_m3_Hwi_Module_State_0_excActive__A
20001430 ti_sysbios_family_arm_m3_Hwi_Module_State_0_excContext__A
20001434 ti_sysbios_family_arm_m3_Hwi_Module_State_0_excStack__A
00000506 ti_sysbios_family_arm_m3_Hwi_Module__id__C
2000140c ti_sysbios_family_arm_m3_Hwi_Module__root__V
1001bb89 ti_sysbios_family_arm_m3_Hwi_Module__startupDone__S
20000144 ti_sysbios_family_arm_m3_Hwi_Module__state__V
1001b1c1 ti_sysbios_family_arm_m3_Hwi_Module_startup__E
00000490 ti_sysbios_family_arm_m3_Hwi_NUM_INTERRUPTS__C
000002d0 ti_sysbios_family_arm_m3_Hwi_Object__DESC__C
00000170 ti_sysbios_family_arm_m3_Hwi_Object__PARAMS__C
00000494 ti_sysbios_family_arm_m3_Hwi_Object__count__C
1001aab1 ti_sysbios_family_arm_m3_Hwi_Object__create__S
1001bba9 ti_sysbios_family_arm_m3_Hwi_Object__delete__S
1001be69 ti_sysbios_family_arm_m3_Hwi_Object__destruct__S
1001b7c1 ti_sysbios_family_arm_m3_Hwi_Object__get__S
00000498 ti_sysbios_family_arm_m3_Hwi_Object__table__C
20001414 ti_sysbios_family_arm_m3_Hwi_Object__table__V
1001c13d ti_sysbios_family_arm_m3_Hwi_Params__init__S
00009bcd ti_sysbios_family_arm_m3_Hwi_cc26xxRomInitNVIC__I
0000049c ti_sysbios_family_arm_m3_Hwi_ccr__C
1001af29 ti_sysbios_family_arm_m3_Hwi_construct
1001ab15 ti_sysbios_family_arm_m3_Hwi_create
1001c25d ti_sysbios_family_arm_m3_Hwi_delete
1001c261 ti_sysbios_family_arm_m3_Hwi_destruct
1001c149 ti_sysbios_family_arm_m3_Hwi_disableFxn__E
1001b299 ti_sysbios_family_arm_m3_Hwi_disableInterrupt__E
1001aa49 ti_sysbios_family_arm_m3_Hwi_dispatchC__I
200023a0 ti_sysbios_family_arm_m3_Hwi_dispatchTable
1001c89d ti_sysbios_family_arm_m3_Hwi_dispatch__I
1001c1fb ti_sysbios_family_arm_m3_Hwi_doSwiRestore__I
1001c213 ti_sysbios_family_arm_m3_Hwi_doTaskRestore__I
1001c155 ti_sysbios_family_arm_m3_Hwi_enableFxn__E
1001b2dd ti_sysbios_family_arm_m3_Hwi_enableInterrupt__E
1001ca01 ti_sysbios_family_arm_m3_Hwi_excHandlerAsm__I
000004a0 ti_sysbios_family_arm_m3_Hwi_excHandlerFunc__C
1001bbc9 ti_sysbios_family_arm_m3_Hwi_excHandler__I
1001b465 ti_sysbios_family_arm_m3_Hwi_getStackInfo__E
1001a699 ti_sysbios_family_arm_m3_Hwi_initNVIC__E
1001c9b9 ti_sysbios_family_arm_m3_Hwi_initStacks__E
000004a4 ti_sysbios_family_arm_m3_Hwi_nullIsrFunc__C
000004a8 ti_sysbios_family_arm_m3_Hwi_numSparseInterrupts__C
e000e000 ti_sysbios_family_arm_m3_Hwi_nvic
1001ca3f ti_sysbios_family_arm_m3_Hwi_pendSV__I
1001c065 ti_sysbios_family_arm_m3_Hwi_plug__E
1001a319 ti_sysbios_family_arm_m3_Hwi_postInit__I
0000a89d ti_sysbios_family_arm_m3_Hwi_post__E
000004ac ti_sysbios_family_arm_m3_Hwi_priGroup__C
20000000 ti_sysbios_family_arm_m3_Hwi_ramVectors
00001010 ti_sysbios_family_arm_m3_Hwi_resetVectors
1001c219 ti_sysbios_family_arm_m3_Hwi_restoreFxn__E
1001ca57 ti_sysbios_family_arm_m3_Hwi_return
0000ac9d ti_sysbios_family_arm_m3_Hwi_setFunc__E
1001be85 ti_sysbios_family_arm_m3_Hwi_setPriority__E
1001c203 ti_sysbios_family_arm_m3_Hwi_startup__E
1001c00d ti_sysbios_family_arm_m3_Hwi_switchFromBootStack__E
1001c265 ti_sysbios_family_arm_m3_TaskSupport_Module__startupDone__S
1001c96d ti_sysbios_family_arm_m3_TaskSupport_buildTaskStack
1001c161 ti_sysbios_family_arm_m3_TaskSupport_getStackAlignment__E
1001ca59 ti_sysbios_family_arm_m3_TaskSupport_glue
000004b0 ti_sysbios_family_arm_m3_TaskSupport_stackAlignment__C
1001b49d ti_sysbios_family_arm_m3_TaskSupport_start__E
1001ca69 ti_sysbios_family_arm_m3_TaskSupport_swap__E
1001ca21 ti_sysbios_family_xxx_Hwi_switchAndRunFunc
1001bbe9 ti_sysbios_gates_GateHwi_Handle__label__S
1001b463 ti_sysbios_gates_GateHwi_Instance_init__E
0000021c ti_sysbios_gates_GateHwi_Module__FXNS__C
00000508 ti_sysbios_gates_GateHwi_Module__id__C
20001438 ti_sysbios_gates_GateHwi_Module__root__V
000002f0 ti_sysbios_gates_GateHwi_Object__DESC__C
00000430 ti_sysbios_gates_GateHwi_Object__PARAMS__C
1001ba95 ti_sysbios_gates_GateHwi_Object__create__S
1001bc09 ti_sysbios_gates_GateHwi_Object__delete__S
20001440 ti_sysbios_gates_GateHwi_Object__table__V
1001c16d ti_sysbios_gates_GateHwi_enter__E
1001c21f ti_sysbios_gates_GateHwi_leave__E
1001c269 ti_sysbios_gates_GateHwi_query__E
1001bc29 ti_sysbios_gates_GateMutex_Handle__label__S
000005cc ti_sysbios_gates_GateMutex_Instance_State_sem__O
1001c075 ti_sysbios_gates_GateMutex_Instance_finalize__E
1001bea1 ti_sysbios_gates_GateMutex_Instance_init__E
00000240 ti_sysbios_gates_GateMutex_Module__FXNS__C
0000050a ti_sysbios_gates_GateMutex_Module__id__C
20001444 ti_sysbios_gates_GateMutex_Module__root__V
00000310 ti_sysbios_gates_GateMutex_Object__DESC__C
00000448 ti_sysbios_gates_GateMutex_Object__PARAMS__C
1001b649 ti_sysbios_gates_GateMutex_Object__create__S
1001bab9 ti_sysbios_gates_GateMutex_Object__delete__S
1001bc49 ti_sysbios_gates_GateMutex_Object__destruct__S
20001710 ti_sysbios_gates_GateMutex_Object__table__V
1001c179 ti_sysbios_gates_GateMutex_Params__init__S
1001b7ed ti_sysbios_gates_GateMutex_construct
1001b679 ti_sysbios_gates_GateMutex_create
1001c26d ti_sysbios_gates_GateMutex_delete
1001c271 ti_sysbios_gates_GateMutex_destruct
1001b6a9 ti_sysbios_gates_GateMutex_enter__E
1001bf9d ti_sysbios_gates_GateMutex_leave__E
1001c275 ti_sysbios_gates_GateMutex_query__E
1001c279 ti_sysbios_hal_Hwi_HwiProxy_Module__startupDone__S
UNDEFED ti_sysbios_hal_Hwi_HwiProxy_Module__startupDone__S__mangled__
1001c085 ti_sysbios_hal_Hwi_HwiProxy_Object__create__S
1001bba9 ti_sysbios_hal_Hwi_HwiProxy_Object__delete__S
UNDEFED ti_sysbios_hal_Hwi_HwiProxy_Object__delete__S__mangled__
1001c13d ti_sysbios_hal_Hwi_HwiProxy_Params__init__S
UNDEFED ti_sysbios_hal_Hwi_HwiProxy_Params__init__S__mangled__
1001be49 ti_sysbios_hal_Hwi_HwiProxy_create
1001c27d ti_sysbios_hal_Hwi_HwiProxy_delete
1001c281 ti_sysbios_hal_Hwi_HwiProxy_disableInterrupt__E
UNDEFED ti_sysbios_hal_Hwi_HwiProxy_disableInterrupt__E__mangled__
1001c285 ti_sysbios_hal_Hwi_HwiProxy_enableInterrupt__E
UNDEFED ti_sysbios_hal_Hwi_HwiProxy_enableInterrupt__E__mangled__
1001c289 ti_sysbios_hal_Hwi_HwiProxy_getStackInfo__E
UNDEFED ti_sysbios_hal_Hwi_HwiProxy_getStackInfo__E__mangled__
0000a89d ti_sysbios_hal_Hwi_HwiProxy_post__E
1001c28d ti_sysbios_hal_Hwi_HwiProxy_startup__E
UNDEFED ti_sysbios_hal_Hwi_HwiProxy_startup__E__mangled__
1001c291 ti_sysbios_hal_Hwi_HwiProxy_switchFromBootStack__E
UNDEFED ti_sysbios_hal_Hwi_HwiProxy_switchFromBootStack__E__mangled__
1001c1f1 ti_sysbios_hal_Hwi_Instance_finalize__E
1001b9f9 ti_sysbios_hal_Hwi_Instance_init__E
2000144c ti_sysbios_hal_Hwi_Module__root__V
1001c021 ti_sysbios_hal_Hwi_Module_startup__E
00000330 ti_sysbios_hal_Hwi_Object__DESC__C
000001a0 ti_sysbios_hal_Hwi_Object__PARAMS__C
1001bc69 ti_sysbios_hal_Hwi_Object__delete__S
0000ab45 ti_sysbios_hal_Hwi_Params__init__S
1001ab79 ti_sysbios_hal_Hwi_create
1001c295 ti_sysbios_hal_Hwi_delete
1001c281 ti_sysbios_hal_Hwi_disableInterrupt__E
UNDEFED ti_sysbios_hal_Hwi_disableInterrupt__E
1001c285 ti_sysbios_hal_Hwi_enableInterrupt__E
UNDEFED ti_sysbios_hal_Hwi_enableInterrupt__E
1001c289 ti_sysbios_hal_Hwi_getStackInfo__E
UNDEFED ti_sysbios_hal_Hwi_getStackInfo__E
1001b819 ti_sysbios_hal_Hwi_initStack
0000a89d ti_sysbios_hal_Hwi_post__E
1001c28d ti_sysbios_hal_Hwi_startup__E
UNDEFED ti_sysbios_hal_Hwi_startup__E
1001c299 ti_sysbios_hal_Hwi_switchFromBootStack__E
UNDEFED ti_sysbios_hal_Hwi_switchFromBootStack__E
000004b4 ti_sysbios_heaps_HeapMem_E_memory__C
1001bc89 ti_sysbios_heaps_HeapMem_Handle__label__S
20001858 ti_sysbios_heaps_HeapMem_Instance_State_0_buf__A
1001b4d5 ti_sysbios_heaps_HeapMem_Instance_init__E
1001bc29 ti_sysbios_heaps_HeapMem_Module_GateProxy_Handle__label__S
UNDEFED ti_sysbios_heaps_HeapMem_Module_GateProxy_Handle__label__S__mangled__
1001bab9 ti_sysbios_heaps_HeapMem_Module_GateProxy_Object__delete__S
UNDEFED ti_sysbios_heaps_HeapMem_Module_GateProxy_Object__delete__S__mangled__
1001c179 ti_sysbios_heaps_HeapMem_Module_GateProxy_Params__init__S
UNDEFED ti_sysbios_heaps_HeapMem_Module_GateProxy_Params__init__S__mangled__
1001c29d ti_sysbios_heaps_HeapMem_Module_GateProxy_enter__E
1001c2a1 ti_sysbios_heaps_HeapMem_Module_GateProxy_leave__E
1001c275 ti_sysbios_heaps_HeapMem_Module_GateProxy_query__E
UNDEFED ti_sysbios_heaps_HeapMem_Module_GateProxy_query__E__mangled__
000001cc ti_sysbios_heaps_HeapMem_Module__FXNS__C
000004b8 ti_sysbios_heaps_HeapMem_Module__gateObj__C
0000050c ti_sysbios_heaps_HeapMem_Module__id__C
20001454 ti_sysbios_heaps_HeapMem_Module__root__V
00000350 ti_sysbios_heaps_HeapMem_Object__DESC__C
00000264 ti_sysbios_heaps_HeapMem_Object__PARAMS__C
000004bc ti_sysbios_heaps_HeapMem_Object__count__C
1001b845 ti_sysbios_heaps_HeapMem_Object__create__S
1001bca9 ti_sysbios_heaps_HeapMem_Object__delete__S
1001b871 ti_sysbios_heaps_HeapMem_Object__get__S
000004c0 ti_sysbios_heaps_HeapMem_Object__table__C
2000145c ti_sysbios_heaps_HeapMem_Object__table__V
1001a199 ti_sysbios_heaps_HeapMem_alloc__E
1001a795 ti_sysbios_heaps_HeapMem_free__E
1001b209 ti_sysbios_heaps_HeapMem_getStats__E
1001b545 ti_sysbios_heaps_HeapMem_init__I
1001c2a5 ti_sysbios_heaps_HeapMem_isBlocking__E
000004c4 ti_sysbios_heaps_HeapMem_reqAlign__C
1001c105 ti_sysbios_heaps_HeapMem_restore__E
1001bfcd ti_sysbios_knl_Clock_Instance_finalize__E
1001b50d ti_sysbios_knl_Clock_Instance_init__E
000005d0 ti_sysbios_knl_Clock_Module_State_clockQ__O
20001474 ti_sysbios_knl_Clock_Module__root__V
20000178 ti_sysbios_knl_Clock_Module__state__V
1001bcc9 ti_sysbios_knl_Clock_Module_startup__E
00000370 ti_sysbios_knl_Clock_Object__DESC__C
00000288 ti_sysbios_knl_Clock_Object__PARAMS__C
1001badd ti_sysbios_knl_Clock_Object__delete__S
1001bce9 ti_sysbios_knl_Clock_Object__destruct__S
2000147c ti_sysbios_knl_Clock_Object__table__V
1001c185 ti_sysbios_knl_Clock_Params__init__S
1001c2a9 ti_sysbios_knl_Clock_TimerProxy_Module__startupDone__S
UNDEFED ti_sysbios_knl_Clock_TimerProxy_Module__startupDone__S__mangled__
1001c095 ti_sysbios_knl_Clock_TimerProxy_getCurrentTick__E
1001c2ad ti_sysbios_knl_Clock_TimerProxy_getExpiredTicks__E
1001c0a5 ti_sysbios_knl_Clock_TimerProxy_getMaxTicks__E
1001c2b1 ti_sysbios_knl_Clock_TimerProxy_getPeriod__E
1001c0b5 ti_sysbios_knl_Clock_TimerProxy_setNextTick__E
1001b795 ti_sysbios_knl_Clock_TimerProxy_startup__E
UNDEFED ti_sysbios_knl_Clock_TimerProxy_startup__E__mangled__
1001ba21 ti_sysbios_knl_Clock_addI__E
1001b579 ti_sysbios_knl_Clock_construct
1001b3ed ti_sysbios_knl_Clock_create
1001c2b5 ti_sysbios_knl_Clock_delete
1001c2b9 ti_sysbios_knl_Clock_destruct
0000a721 ti_sysbios_knl_Clock_doTick__I
00009619 ti_sysbios_knl_Clock_getTicksUntilInterrupt__E
1001b6d9 ti_sysbios_knl_Clock_getTicks__E
1001c191 ti_sysbios_knl_Clock_getTimerHandle__E
0000accb ti_sysbios_knl_Clock_isActive__E
1001be67 ti_sysbios_knl_Clock_logTick__E
1001c2bd ti_sysbios_knl_Clock_removeI__E
1001bebd ti_sysbios_knl_Clock_scheduleNextTick__E
000004c8 ti_sysbios_knl_Clock_serviceMargin__C
1001c2c1 ti_sysbios_knl_Clock_setTimeout__E
1001a719 ti_sysbios_knl_Clock_startI__E
1001bfe3 ti_sysbios_knl_Clock_start__E
00009e19 ti_sysbios_knl_Clock_stop__E
00000510 ti_sysbios_knl_Clock_tickMode__C
0000cbf8 ti_sysbios_knl_Clock_tickPeriod__C
0000cbfc ti_sysbios_knl_Clock_triggerClock__C
00009acf ti_sysbios_knl_Clock_triggerFunc__I
1001a80d ti_sysbios_knl_Clock_walkQueueDynamic__E
00005979 ti_sysbios_knl_Clock_workFuncDynamic__E
1001a885 ti_sysbios_knl_Clock_workFunc__E
2000149c ti_sysbios_knl_Event_Module__root__V
0000cbe0 ti_sysbios_knl_Idle_funcList__A
00000478 ti_sysbios_knl_Idle_funcList__C
1001c20b ti_sysbios_knl_Idle_loop__E
1001bd09 ti_sysbios_knl_Idle_run__E
000005d4 ti_sysbios_knl_Mailbox_Instance_State_dataQue__O
000005d8 ti_sysbios_knl_Mailbox_Instance_State_dataSem__O
000005dc ti_sysbios_knl_Mailbox_Instance_State_freeQue__O
000005e0 ti_sysbios_knl_Mailbox_Instance_State_freeSem__O
1001a9dd ti_sysbios_knl_Mailbox_Instance_finalize__E
1001a001 ti_sysbios_knl_Mailbox_Instance_init__E
200014a4 ti_sysbios_knl_Mailbox_Module__root__V
1001b251 ti_sysbios_knl_Mailbox_Module_startup__E
00000390 ti_sysbios_knl_Mailbox_Object__DESC__C
0000013c ti_sysbios_knl_Mailbox_Object__PARAMS__C
000004cc ti_sysbios_knl_Mailbox_Object__count__C
1001bd29 ti_sysbios_knl_Mailbox_Object__delete__S
1001bed9 ti_sysbios_knl_Mailbox_Object__destruct__S
1001b89d ti_sysbios_knl_Mailbox_Object__get__S
000004d0 ti_sysbios_knl_Mailbox_Object__table__C
1001c19d ti_sysbios_knl_Mailbox_Params__init__S
1001af81 ti_sysbios_knl_Mailbox_construct
1001abdd ti_sysbios_knl_Mailbox_create
1001c2c5 ti_sysbios_knl_Mailbox_delete
1001c2c9 ti_sysbios_knl_Mailbox_destruct
1001a8fd ti_sysbios_knl_Mailbox_pend__E
1001b8c9 ti_sysbios_knl_Mailbox_postInit__I
1001a591 ti_sysbios_knl_Mailbox_post__E
1001c22b ti_sysbios_knl_Queue_Instance_init__E
200014ac ti_sysbios_knl_Queue_Module__root__V
000003b0 ti_sysbios_knl_Queue_Object__DESC__C
00000460 ti_sysbios_knl_Queue_Object__PARAMS__C
000004d4 ti_sysbios_knl_Queue_Object__count__C
1001bd49 ti_sysbios_knl_Queue_Object__delete__S
1001bef5 ti_sysbios_knl_Queue_Object__destruct__S
1001bd69 ti_sysbios_knl_Queue_Object__get__S
000004d8 ti_sysbios_knl_Queue_Object__table__C
1001b8f5 ti_sysbios_knl_Queue_construct
1001b921 ti_sysbios_knl_Queue_create
1001c2cd ti_sysbios_knl_Queue_delete
1001c1a9 ti_sysbios_knl_Queue_dequeue__E
1001c2d1 ti_sysbios_knl_Queue_destruct
1001c231 ti_sysbios_knl_Queue_elemClear__E
1001c113 ti_sysbios_knl_Queue_empty__E
1001c1b5 ti_sysbios_knl_Queue_enqueue__E
1001bf11 ti_sysbios_knl_Queue_get__E
1001c2d5 ti_sysbios_knl_Queue_head__E
1001c2d9 ti_sysbios_knl_Queue_next__E
1001bf2d ti_sysbios_knl_Queue_put__E
1001c121 ti_sysbios_knl_Queue_remove__E
000005e4 ti_sysbios_knl_Semaphore_Instance_State_pendQ__O
1001c0c5 ti_sysbios_knl_Semaphore_Instance_finalize__E
1001bb01 ti_sysbios_knl_Semaphore_Instance_init__E
200014b4 ti_sysbios_knl_Semaphore_Module__root__V
000003d0 ti_sysbios_knl_Semaphore_Object__DESC__C
000002ac ti_sysbios_knl_Semaphore_Object__PARAMS__C
1001bb25 ti_sysbios_knl_Semaphore_Object__delete__S
1001bd89 ti_sysbios_knl_Semaphore_Object__destruct__S
1001c1c1 ti_sysbios_knl_Semaphore_Params__init__S
1001b709 ti_sysbios_knl_Semaphore_construct
1001b5ad ti_sysbios_knl_Semaphore_create
1001c2dd ti_sysbios_knl_Semaphore_delete
1001c2e1 ti_sysbios_knl_Semaphore_destruct
1001b94d ti_sysbios_knl_Semaphore_pendTimeout__I
1001a0cd ti_sysbios_knl_Semaphore_pend__E
1001ac41 ti_sysbios_knl_Semaphore_post__E
1001bf9b ti_sysbios_knl_Swi_Instance_finalize__E
1001aca5 ti_sysbios_knl_Swi_Instance_init__E
20001748 ti_sysbios_knl_Swi_Module_State_0_readyQ__A
200014bc ti_sysbios_knl_Swi_Module__root__V
200001c8 ti_sysbios_knl_Swi_Module__state__V
1001c237 ti_sysbios_knl_Swi_Module_startup__E
000003f0 ti_sysbios_knl_Swi_Object__DESC__C
000001f4 ti_sysbios_knl_Swi_Object__PARAMS__C
000004dc ti_sysbios_knl_Swi_Object__count__C
1001bda9 ti_sysbios_knl_Swi_Object__delete__S
1001bf49 ti_sysbios_knl_Swi_Object__destruct__S
1001b979 ti_sysbios_knl_Swi_Object__get__S
000004e0 ti_sysbios_knl_Swi_Object__table__C
20001778 ti_sysbios_knl_Swi_Object__table__V
1001c1cd ti_sysbios_knl_Swi_Params__init__S
1001b085 ti_sysbios_knl_Swi_construct
1001ad05 ti_sysbios_knl_Swi_create
1001c2e5 ti_sysbios_knl_Swi_delete
1001c2e9 ti_sysbios_knl_Swi_destruct
1001c0d5 ti_sysbios_knl_Swi_disable__E
1001c0e5 ti_sysbios_knl_Swi_enabled__E
0000ab59 ti_sysbios_knl_Swi_getTrigger__E
000004e4 ti_sysbios_knl_Swi_numPriorities__C
0000a541 ti_sysbios_knl_Swi_or__E
1001c2ed ti_sysbios_knl_Swi_postInit__I
1001b321 ti_sysbios_knl_Swi_post__E
1001ad61 ti_sysbios_knl_Swi_restoreHwi__E
1001b5e1 ti_sysbios_knl_Swi_restore__E
1001b0d5 ti_sysbios_knl_Swi_runLoop__I
1001afd9 ti_sysbios_knl_Swi_run__I
1001b031 ti_sysbios_knl_Swi_schedule__I
1001c23d ti_sysbios_knl_Swi_startup__E
20001ed8 ti_sysbios_knl_Task_Instance_State_0_stack__A
1001a4fd ti_sysbios_knl_Task_Instance_finalize__E
1001a25d ti_sysbios_knl_Task_Instance_init__E
200014cc ti_sysbios_knl_Task_Module_State_0_idleTask__A
200017a8 ti_sysbios_knl_Task_Module_State_0_readyQ__A
000005e8 ti_sysbios_knl_Task_Module_State_inactiveQ__O
200014c4 ti_sysbios_knl_Task_Module__root__V
20000100 ti_sysbios_knl_Task_Module__state__V
1001adbd ti_sysbios_knl_Task_Module_startup__E
00000410 ti_sysbios_knl_Task_Object__DESC__C
00000100 ti_sysbios_knl_Task_Object__PARAMS__C
000004e8 ti_sysbios_knl_Task_Object__count__C
1001bdc9 ti_sysbios_knl_Task_Object__delete__S
1001bf65 ti_sysbios_knl_Task_Object__destruct__S
1001bde9 ti_sysbios_knl_Task_Object__get__S
000004ec ti_sysbios_knl_Task_Object__table__C
20001644 ti_sysbios_knl_Task_Object__table__V
1001c1d9 ti_sysbios_knl_Task_Params__init__S
1001c2f1 ti_sysbios_knl_Task_SupportProxy_Module__startupDone__S
UNDEFED ti_sysbios_knl_Task_SupportProxy_Module__startupDone__S__mangled__
1001c2f5 ti_sysbios_knl_Task_SupportProxy_getStackAlignment__E
UNDEFED ti_sysbios_knl_Task_SupportProxy_getStackAlignment__E__mangled__
1001c2f9 ti_sysbios_knl_Task_SupportProxy_start__E
UNDEFED ti_sysbios_knl_Task_SupportProxy_start__E__mangled__
1001c2fd ti_sysbios_knl_Task_SupportProxy_swap__E
UNDEFED ti_sysbios_knl_Task_SupportProxy_swap__E__mangled__
000004f0 ti_sysbios_knl_Task_allBlockedFunc__C
1001b365 ti_sysbios_knl_Task_allBlockedFunction__I
1001b615 ti_sysbios_knl_Task_blockI__E
1001b125 ti_sysbios_knl_Task_construct
1001ae19 ti_sysbios_knl_Task_create
000004f4 ti_sysbios_knl_Task_defaultStackHeap__C
000004f8 ti_sysbios_knl_Task_defaultStackSize__C
1001c301 ti_sysbios_knl_Task_delete
1001c305 ti_sysbios_knl_Task_destruct
1001c0f5 ti_sysbios_knl_Task_disable__E
1001c243 ti_sysbios_knl_Task_enable__E
1001be09 ti_sysbios_knl_Task_enter__I
1001b429 ti_sysbios_knl_Task_exit__E
0000050e ti_sysbios_knl_Task_initStackFlag__C
000004fc ti_sysbios_knl_Task_numConstructedTasks__C
1001a615 ti_sysbios_knl_Task_postInit__I
1001b739 ti_sysbios_knl_Task_processVitalTaskFlag__I
1001be29 ti_sysbios_knl_Task_restoreHwi__E
1001ba49 ti_sysbios_knl_Task_restore__E
1001b175 ti_sysbios_knl_Task_schedule__I
1001c1e5 ti_sysbios_knl_Task_self__E
1001bf81 ti_sysbios_knl_Task_sleepTimeout__I
1001a96d ti_sysbios_knl_Task_sleep__E
1001ae75 ti_sysbios_knl_Task_startCore__E
1001c309 ti_sysbios_knl_Task_startup__E
1001ca71 ti_sysbios_knl_Task_swapReturn
1001b9a5 ti_sysbios_knl_Task_unblockI__E
1001bfb5 ti_sysbios_knl_Task_unblock__E
1001b3a9 ti_sysbios_knl_Task_yield__E
00000590 ti_sysbios_rom_ROM_AONRTCChannelEnable
00000594 ti_sysbios_rom_ROM_AONRTCCompareValueSet
00000598 ti_sysbios_rom_ROM_AONRTCCurrentCompareValueGet
0000059c ti_sysbios_rom_ROM_AONRTCEventClear
000005a0 ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_getCount64__E
000005a4 ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_getCurrentTick__E
000005a8 ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_getMaxTicks__E
000005ac ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_initDevice__I
000005b0 ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_setNextTick__E
000005b4 ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_setThreshold__I
000005b8 ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_Timer_start__E
000005bc ti_sysbios_rom_ROM_ti_sysbios_family_arm_cc26xx_TimestampProvider_get32__E
000005c0 ti_sysbios_rom_ROM_xdc_runtime_Startup_getState__I
000005c4 ti_sysbios_rom_ROM_xdc_runtime_System_SupportProxy_abort__E
000005c8 ti_sysbios_rom_ROM_xdc_runtime_System_SupportProxy_exit__E
00009c57 ti_sysbios_rom_cortexm_cc26xx_CC26xx_badRomRevision__E
0000a559 ti_sysbios_rom_cortexm_cc26xx_CC26xx_checkRevision__E
1001ca9b ti_sysbios_rom_cortexm_cc26xx_CC26xx_getRevision__E
200024a8 trngCC26XXObjects
0000cb2c trngDriverTable
0000ca54 txPowerTable
0000cb24 txPwrTbl
20000904 uartLog_evBuf
2000084e uartLog_evBufIsEmpty
20000850 uartLog_evtNum
00006b95 uartLog_flush
2000084d uartLog_head
20000858 uartLog_outBuf
0000600d uartLog_outputFxn
2000084c uartLog_tail
0000cbe8 udmaHWAttrs
20002468 udmaObjects
200017d8 user0Cfg
0000ca24 validRangeUUID
00000524 xdc_runtime_Assert_E_assertFailed__C
1001c5a9 xdc_runtime_Assert_raise__I
1001c6ed xdc_runtime_Core_assignLabel__I
1001c5f1 xdc_runtime_Core_assignParams__I
1001c639 xdc_runtime_Core_constructObject__I
1001c405 xdc_runtime_Core_createObject__I
1001c4f9 xdc_runtime_Core_deleteObject__I
1001c7a1 xdc_runtime_Core_destructObject__I
00000528 xdc_runtime_Error_E_memory__C
1001c7b9 xdc_runtime_Error_check__E
1001c841 xdc_runtime_Error_init__E
0000052c xdc_runtime_Error_policyFxn__C
1001c487 xdc_runtime_Error_policySpin__E
0000058c xdc_runtime_Error_policy__C
1001c769 xdc_runtime_Error_raiseX__E
1001c885 xdc_runtime_Gate_enterSystem__E
1001c879 xdc_runtime_Gate_leaveSystem__E
00000530 xdc_runtime_IGateProvider_Interface__BASE__C
00000534 xdc_runtime_IHeap_Interface__BASE__C
0000cc00 xdc_runtime_ILogger_Interface__BASE__C
00000538 xdc_runtime_IModule_Interface__BASE__C
0000cc04 xdc_runtime_Log_L_error__C
0000cc08 xdc_runtime_Log_L_warning__C
0000a0e9 xdc_runtime_LoggerCallback_Instance_init__E
0000c9cc xdc_runtime_LoggerCallback_Module__FXNS__C
200014d0 xdc_runtime_LoggerCallback_Module__root__V
00008241 xdc_runtime_LoggerCallback_Module_startup__E
0000cac0 xdc_runtime_LoggerCallback_Object__DESC__C
0000cae0 xdc_runtime_LoggerCallback_Object__PARAMS__C
0000cc0c xdc_runtime_LoggerCallback_Object__count__C
000091e5 xdc_runtime_LoggerCallback_Object__create__S
0000a8ad xdc_runtime_LoggerCallback_Object__get__S
200014d8 xdc_runtime_LoggerCallback_Object__table__V
0000cc10 xdc_runtime_LoggerCallback_createInstFxn__C
0000accf xdc_runtime_LoggerCallback_defaultCreate
0000abc3 xdc_runtime_LoggerCallback_disable__E
0000abcd xdc_runtime_LoggerCallback_enable__E
0000cc14 xdc_runtime_LoggerCallback_outputFxn__C
000099ed xdc_runtime_LoggerCallback_write0__E
00009a15 xdc_runtime_LoggerCallback_write1__E
00009645 xdc_runtime_LoggerCallback_write2__E
00008cc5 xdc_runtime_LoggerCallback_write4__E
00007ef5 xdc_runtime_LoggerCallback_write8__E
UNDEFED xdc_runtime_Main_Module_GateProxy_Handle__label__S
UNDEFED xdc_runtime_Main_Module_GateProxy_Object__delete__S
UNDEFED xdc_runtime_Main_Module_GateProxy_query__E
0000053c xdc_runtime_Main_Module__diagsEnabled__C
00000540 xdc_runtime_Main_Module__diagsIncluded__C
00000544 xdc_runtime_Main_Module__diagsMask__C
00000584 xdc_runtime_Main_Module__id__C
0000cc3c xdc_runtime_Main_Module__loggerDefined__C
0000cc18 xdc_runtime_Main_Module__loggerFxn2__C
0000cc1c xdc_runtime_Main_Module__loggerFxn4__C
0000cc20 xdc_runtime_Main_Module__loggerFxn8__C
0000cc24 xdc_runtime_Main_Module__loggerObj__C
1001bc89 xdc_runtime_Memory_HeapProxy_Handle__label__S
UNDEFED xdc_runtime_Memory_HeapProxy_Handle__label__S__mangled__
1001bca9 xdc_runtime_Memory_HeapProxy_Object__delete__S
UNDEFED xdc_runtime_Memory_HeapProxy_Object__delete__S__mangled__
1001c889 xdc_runtime_Memory_HeapProxy_alloc__E
1001c88d xdc_runtime_Memory_HeapProxy_free__E
00000586 xdc_runtime_Memory_Module__id__C
20000200 xdc_runtime_Memory_Module__state__V
1001c489 xdc_runtime_Memory_alloc__E
1001c84d xdc_runtime_Memory_calloc__E
00000548 xdc_runtime_Memory_defaultHeapInstance__C
1001c801 xdc_runtime_Memory_free__E
1001c859 xdc_runtime_Memory_getMaxDefaultTypeAlign__E
1001c785 xdc_runtime_Memory_valloc__E
20001840 xdc_runtime_Registry_Module__state__V
00009e39 xdc_runtime_Registry_findById__E
200001f0 xdc_runtime_Startup_Module__state__V
00000001 xdc_runtime_Startup__EXECFXN__C
00000001 xdc_runtime_Startup__RESETFXN__C
0000054c xdc_runtime_Startup_execImpl__C
1001c559 xdc_runtime_Startup_exec__E
0000a761 xdc_runtime_Startup_exec__I
0000cbcc xdc_runtime_Startup_firstFxns__A
00000514 xdc_runtime_Startup_firstFxns__C
0000723d xdc_runtime_Startup_getState__I
0000051c xdc_runtime_Startup_lastFxns__C
00000550 xdc_runtime_Startup_maxPasses__C
0000ab65 xdc_runtime_Startup_reset__I
0000ab71 xdc_runtime_Startup_rtsDone__E
0000cb60 xdc_runtime_Startup_sfxnRts__A
00000554 xdc_runtime_Startup_sfxnRts__C
0000ca2c xdc_runtime_Startup_sfxnTab__A
00000558 xdc_runtime_Startup_sfxnTab__C
0000055c xdc_runtime_Startup_startModsFxn__C
1001c30d xdc_runtime_Startup_startMods__I
00000560 xdc_runtime_SysCallback_abortFxn__C
1001c811 xdc_runtime_SysCallback_abort__E
00009eef xdc_runtime_SysCallback_defaultAbort
0000a1ef xdc_runtime_SysCallback_defaultExit
0000a773 xdc_runtime_SysCallback_defaultPutch
0000acd3 xdc_runtime_SysCallback_defaultReady
00000564 xdc_runtime_SysCallback_exitFxn__C
1001c821 xdc_runtime_SysCallback_exit__E
0000cc28 xdc_runtime_SysCallback_putchFxn__C
0000a8bd xdc_runtime_SysCallback_putch__E
0000cc2c xdc_runtime_SysCallback_readyFxn__C
0000a8cd xdc_runtime_SysCallback_ready__E
1001bbe9 xdc_runtime_System_Module_GateProxy_Handle__label__S
UNDEFED xdc_runtime_System_Module_GateProxy_Handle__label__S__mangled__
1001bc09 xdc_runtime_System_Module_GateProxy_Object__delete__S
UNDEFED xdc_runtime_System_Module_GateProxy_Object__delete__S__mangled__
1001c891 xdc_runtime_System_Module_GateProxy_enter__E
1001c895 xdc_runtime_System_Module_GateProxy_leave__E
1001c269 xdc_runtime_System_Module_GateProxy_query__E
UNDEFED xdc_runtime_System_Module_GateProxy_query__E__mangled__
200001f8 xdc_runtime_System_Module__state__V
1001c87f xdc_runtime_System_Module_startup__E
UNDEFED xdc_runtime_System_SupportProxy_abort__E
UNDEFED xdc_runtime_System_SupportProxy_exit__E
0000a8bd xdc_runtime_System_SupportProxy_putch__E
0000a8cd xdc_runtime_System_SupportProxy_ready__E
00000568 xdc_runtime_System_abortFxn__C
1001c899 xdc_runtime_System_abortSpin__E
00007eb5 xdc_runtime_System_abortStd__E
1001c749 xdc_runtime_System_abort__E
1001c681 xdc_runtime_System_atexit__E
00001419 xdc_runtime_System_doPrint__I
0000056c xdc_runtime_System_exitFxn__C
1001c89b xdc_runtime_System_exitSpin__E
00007ebd xdc_runtime_System_exitStd__E
1001c7d1 xdc_runtime_System_exit__E
0000cc30 xdc_runtime_System_extendFxn__C
00006701 xdc_runtime_System_formatNum__I
00000570 xdc_runtime_System_maxAtexitHandlers__C
0000451d xdc_runtime_System_printfExtend__I
1001c6b9 xdc_runtime_System_processAtExit__E
00009719 xdc_runtime_System_putchar__I
0000a1d5 xdc_runtime_System_snprintf__E
0000acd7 xdc_runtime_System_snprintf_va__F
0000a8dd xdc_runtime_System_vsnprintf__E
00000588 xdc_runtime_Text_charCnt__C
0000ae7c xdc_runtime_Text_charTab__A
00000574 xdc_runtime_Text_charTab__C
1001c71d xdc_runtime_Text_cordText__E
0000058a xdc_runtime_Text_isLoaded__C
00000578 xdc_runtime_Text_nameEmpty__C
0000057c xdc_runtime_Text_nameStatic__C
00000580 xdc_runtime_Text_nameUnknown__C
0000cba4 xdc_runtime_Text_nodeTab__A
0000cc34 xdc_runtime_Text_nodeTab__C
00009215 xdc_runtime_Text_printVisFxn__I
00007299 xdc_runtime_Text_putLab__E
00005b39 xdc_runtime_Text_putMod__E
000057ad xdc_runtime_Text_putSite__E
0000cc3e xdc_runtime_Text_registryModsLastId__C
1001c7e9 xdc_runtime_Text_ropeText__E
0000cc40 xdc_runtime_Text_unnamedModsLastId__C
00007a91 xdc_runtime_Text_visitRope2__I
0000cc38 xdc_runtime_Text_visitRopeFxn__C
0000abd7 xdc_runtime_Text_visitRope__I
00007f39 xdc_runtime_Text_xprintf__I
1001c831 xdc_runtime_Timestamp_SupportProxy_get32__E
0000aa1d xdc_runtime_Timestamp_SupportProxy_get32__E__mangled__
1001b9d1 xdc_runtime_Timestamp_SupportProxy_get64__E
UNDEFED xdc_runtime_Timestamp_SupportProxy_get64__E__mangled__
1001c12f xdc_runtime_Timestamp_SupportProxy_getFreq__E
UNDEFED xdc_runtime_Timestamp_SupportProxy_getFreq__E__mangled__
1001c831 xdc_runtime_Timestamp_get32__E
UNDEFED xdc_runtime_Timestamp_get32__E
1001b9d1 xdc_runtime_Timestamp_get64__E
UNDEFED xdc_runtime_Timestamp_get64__E
1001c12f xdc_runtime_Timestamp_getFreq__E
UNDEFED xdc_runtime_Timestamp_getFreq__E
10015d19 zADD
10015eb5 zADD32
10015de9 zMACC32
10015f0d zMULT32
10015bcd zSET
10015d5d zSUB
10015e69 zSUB32
GLOBAL SYMBOLS: SORTED BY Symbol Address
address name
00000000 __ASM__
0000006f __ISA__
00000081 __PLAT__
000000a8 __TARG__
000000cd __TRDR__
000005ec __ccfg
00001000 _imgHdr
00003065 PIN_init
00003215 RF_postCmd
00003ff5 Power_init
00004f8d RF_open
00005711 memcpy
00005849 PIN_open
00005e81 RF_pendCmd
0000618d memset
000068b5 main
00006bfd PIN_add
0000734d PIN_remove
0000778d RF_getInfo
00007a45 copy_in
00007e29 ResetISR
00007e29 _c_int00
00007eb1 C$$EXIT
00007eb5 abort
00007ebd exit
00008181 RF_getRssi
00008465 RF_runCmd
00009035 SPI_open
0000976d ICall_init
00009a3d List_put
00009c35 memcmp
00009e77 PIN_close
0000a0b1 openTRNG
0000a4d9 _args_main
0000a6e5 _nop
0000a6f9 strlen
0000ab91 List_empty
0000aba5 SPI_close
0000abb9 UART_write
0000acaf List_head
0000acb3 List_next
0000c82c oadCBs
0000c878 resourceDB
0000ca7c SPI_config
0000cb24 txPwrTbl
0000cb40 devInfoCBs
10014c00 A1_rw
10014c04 P1_ro
100150e5 SCALARMUL
10015101 SAVEPOINT
10015141 GETBIT
10015155 GETDIGIT
10015215 SelectReg
100154f5 JACADD
1001568d INVERT
1001588c LUTOPCODE
10015894 LUTOPSIGN
100158ac LUTC
100158c4 LUTSE
100158dc LUTINCI
100158f4 LUTJ
1001596c LUTSTATE
10015a35 IMPORTDATA
10015a51 SETOPERAND
10015a6d COPY
10015a85 ZERO
10015a91 SETWORD
10015a9d mSET
10015bcd zSET
10015bd5 mINVK
10015d19 zADD
10015d5d zSUB
10015de9 zMACC32
10015e69 zSUB32
10015eb5 zADD32
10015f0d zMULT32
10015f81 mMULT
10016551 mADD
1001664d mSUB
10016749 mOUT
10016d05 FFMult_Sw
10016f58 FFMult2
10017058 FFMult3
10017158 RCon
10017164 Sbox
10017264 InvSbox
10017961 ECC_setWin
10017969 ECDSA_sign
10018755 MB_Init
1001895d mbCpe0Isr
10018985 mbCpe1Isr
100189e5 mbHwIsr
10018ced __exit
10018d6c Fill1
10019ffc A3_rw
10019ffe A2_rw
10019ffe P1_ro_2
2000014c dispHandle
200001f8 sbpTask
200015ec rfRegTbl
200016d8 one_ms
200016e4 OneTimeVar
200017d8 user0Cfg
20001820 pfnBMAlloc
20001824 pfnBMFree
20001830 _lock
20001834 _unlock
200024ae heapStart
20003f18 __stack
20003f18 heapEnd
20004f2c A4_rw
20004f40 P2_rw
20004f40 P2_s0
20004f54 inScalar
20004f58 inPointX
20004f5c inPointY
20004f60 outPointX
20004f64 outPointY
20004f68 SCAL
20004f6c EXPX
20004f70 EXPY
20004f74 EXPZ
20004f78 EXPW
20004f7c ACCX
20004f80 ACCY
20004f84 ACCZ
20004f88 TMP1
20004f8c TMP2
20004f90 TMP3
20004f94 TMP4
20004f98 TMP5
20004f9c TMP6
20004fac P2_zi
20004fcc fwInfoCmd
20004fd8 MSBMOD
20004fdc aux64
20004fe4 MOD
20004fe8 LEN
ffffffff __binit__
ffffffff __c_args__
ffffffff binit
[1197 symbols]
We need urgent help since we are about to start production process.
Please help us as soon as possible
Thank you
Dnyaneshvar Salve
