Hi
SDK using : simplelink_cc13xx_cc26xx_sdk_7_10_01_24
Code Using : simple_peripheral_LP_CC2652R7_tirtos7_ticlang
We are using the default SDK code without any modification.
In project properties -> build -> steps -> Post-build steps column I entered the below statement to generate the .bin file. But the generated .bin file is oversized (720 KB)
"${CCE_INSTALL_ROOT}/utils/tiobj2bin/tiobj2bin" "${BuildArtifactFileName}" "${BuildArtifactFileBaseName}.bin" "${CG_TOOL_ROOT}/bin/armofd" "${CG_TOOL_ROOT}/bin/armhex" "${CCE_INSTALL_ROOT}/utils/tiobj2bin/mkhex4bin"
Please help here to get the optimised file size
