This reference design was found from TI, but it does not properly mention the dimensions for L1, H1, and H2. Does anyone know the exact dimensions of these parameters?
Thanks for your inquiry.
The H1 dimension in your picture is the same as W2 in our picture. With that information, you don't need H2 but simply extend the polygon to meet the vertical feed in the left 90° corner.
L1 in your picture is not very critical as long as you do not short or stray too far from the apparent proportions. In any case, we set it to 1.2 mm, which is also equals to L7 - (L5 + L6)
Hope this helps,
Rafael
