Other Parts Discussed in Thread: CC2340R5
I have an application that receives UART data and needs to resume the task. After the data is processed, it needs to reply to the user about whether the data is correct and then suspend the task. Why can't UART2_write and UART2_read be used together in the same task?
I have tried integrating the user_uart2callback example, but it seems not to work either.
full code
/* * Copyright (c) 2020, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ /* * ======== uart2callback.c ======== */ /* POSIX Header files */ #include <pthread.h> /* For usleep() */ #include <unistd.h> #include <stdint.h> #include <stddef.h> #include <string.h> /* POSIX Header files */ #include <semaphore.h> /* Driver Header files */ #include <ti/drivers/GPIO.h> #include <ti/drivers/UART2.h> /* Driver configuration */ #include "ti_drivers_config.h" /* RTOS header files */ #include <FreeRTOS.h> #include <task.h> //#include <inc_task.h> //INC_TASK_H #define USER_STACK_SIZE 1024 #define UART_MAX_READ_SIZE 250 static sem_t sem; static volatile size_t numBytesRead, UART_status = 0; UART2_Handle uart; UART2_Params uartParams; TaskHandle_t user_xHandle; pthread_mutex_t LEDBlink_mutex;//pthread_mutex_lock ,pthread_mutex_unlock uint8_t uartReadBuffer[250] = {0}; void callbackFxn(UART2_Handle handle, void *buffer, size_t count, void *userArg, int_fast16_t status); void Open_UART_FUN() { char input; const char echoPrompt[] = "Echoing characters:\r\n"; uint32_t status = UART2_STATUS_SUCCESS; /* Create a UART in CALLBACK read mode */ UART2_Params_init(&uartParams); uartParams.readMode = UART2_Mode_CALLBACK; uartParams.readCallback = callbackFxn; uartParams.baudRate = 115200; uart = UART2_open(CONFIG_UART2_0, &uartParams); if (uart == NULL) { /* UART2_open() failed */ while (1) {} } /* Turn on user LED to indicate successful initialization */ //GPIO_write(CONFIG_GPIO_LED_0, CONFIG_GPIO_LED_ON); /* Pass NULL for bytesWritten since it's not used in this example */ UART2_write(uart, echoPrompt, sizeof(echoPrompt), NULL); UART2_read(uart, uartReadBuffer, UART_MAX_READ_SIZE, NULL); } /******************************************************************************* */ /* Task to be created. */ void vTaskCode( void * pvParameters ) { /* The parameter value is expected to be 1 as 1 is passed in the pvParameters value in the call to xTaskCreate() below. */ for( ;; ) { /* Task code goes here. */ GPIO_toggle(CONFIG_GPIO_LED_0); // UART2_write(uart, (char*)"OK\r\n", strlen("OK\r\n"), NULL); UART2_read(uart, uartReadBuffer, UART_MAX_READ_SIZE, NULL); vTaskSuspend(NULL); } } /* Function that creates a task. */ void vOtherFunction( void ) { BaseType_t xReturned; /* Configure the LED pin */ GPIO_setConfig(CONFIG_GPIO_LED_0, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW); /* Turn on user LED to indicate successful initialization */ GPIO_write(CONFIG_GPIO_LED_0, CONFIG_GPIO_LED_ON); /* Create the task, storing the handle. */ xReturned = xTaskCreate( vTaskCode, /* Function that implements the task. */ "user_app", /* Text name for the task. */ USER_STACK_SIZE, /* Stack size in words, not bytes. */ ( void * ) 1, /* Parameter passed into the task. */ tskIDLE_PRIORITY,/* Priority at which the task is created. */ &user_xHandle ); /* Used to pass out the created task's handle. */ } /* * ======== callbackFxn ======== */ void callbackFxn(UART2_Handle handle, void *buffer, size_t count, void *userArg, int_fast16_t status) { if (status != UART2_STATUS_SUCCESS) { /* RX error occured in UART2_read() */ while (1) {} } numBytesRead = count; //thread_mutex_lock(&LEDBlink_mutex); UART_status = 1; //hread_mutex_unlock(&LEDBlink_mutex); memcpy(uartReadBuffer,buffer,numBytesRead); BaseType_t xYieldRequired; //xYieldRequired // Resume the suspended task. xYieldRequired = xTaskResumeFromISR(user_xHandle); // We should switch context so the ISR returns to a different task. // NOTE: How this is done depends on the port you are using. Check // the documentation and examples for your port. portYIELD_FROM_ISR(xYieldRequired); }
UART2 LED success
UART2 LED fail
void vTaskCode( void * pvParameters ) { /* The parameter value is expected to be 1 as 1 is passed in the pvParameters value in the call to xTaskCreate() below. */ for( ;; ) { /* Task code goes here. */ GPIO_toggle(CONFIG_GPIO_LED_0); UART2_write(uart, (char*)"OK\r\n", strlen("OK\r\n"), NULL); UART2_read(uart, uartReadBuffer, UART_MAX_READ_SIZE, NULL); vTaskSuspend(NULL); } }
