Part Number: SIMPLELINK-CC26X2-SDK
Hello
Im trying out the simple_central example in simplelink_cc26x2_sdk_2_30_00_34
The aim is to read bluetooth EIR raw data from an advertiser. So basically i just need the simple_central in observer mode.
I can discover the advertiser, and i made a copy of the data received from GapScan_getAdvReport(i, &advRpt);
Here is the srtuct:
/// Event for advertising report typedef struct { /** * Bits 0 to 4 indicate connectable, scannable, directed, scan response, and * legacy respectively */ uint8_t evtType; /// Public, random, public ID, random ID, or anonymous GAP_Addr_Types_t addrType; /// Address of the advertising device uint8_t addr[B_ADDR_LEN]; /// PHY of the primary advertising channel GapScan_ScannedPhy_t primPhy; /// PHY of the secondary advertising channel GapScan_ScannedPhy_t secPhy; /// SID (0x00-0x0f) of the advertising PDU. 0xFF means no ADI field in the PDU uint8_t advSid; /// -127 dBm <= TX power <= 126 dBm int8_t txPower; /// -127 dBm <= RSSI <= 20 dBm int8_t rssi; /// Type of TargetA address in the directed advertising PDU GAP_Addr_Types_t directAddrType; /// TargetA address uint8_t directAddr[B_ADDR_LEN]; /// Periodic advertising interval. 0 means no periodic advertising. uint16_t periodicAdvInt; /// Length of the data uint16_t dataLen; /// Pointer to advertising or scan response data uint8_t *pData; } GapScan_Evt_AdvRpt_t;
it seems that i get all the data in that struct after the "discover devices" process in serial terminal. However, i actually need Extended Inquire Response data. Is there a built-in mechanism in the simple_central code to specify to the advertiser that i need EIR?
All the useful data comes with EIR.
