Is it possible to configure the slew rate of an output pin using SysConfig? Specifically, I am looking to set the SLEW_RED bit in the IOCFG registers to reduce output slew rate as described in the CC13x2 Technical Reference Manual:
If SysConfig does not support slew rate configuration, how can I enable reduced slew rate while still using SysConfig to generate the rest of the configuration?
Thank you!
Peter
