Hi
can someone please help me with comparison between pointer and integer ('uint16_t' (aka 'unsigned short') and 'void *') [-Wpointer-integer-compare] problem
uint16_t no_of_repetition = 0; // no of repeat cycle
David
Hi
David
This is a 'c' question and not related to the driver. Have you checked stackoverflow.com or similar?
Hi David,
I agree with TheGhostOf, this is more of a C question.
It looks like you are comparing an actual uint16_t variable, and a NULL pointer, hence the warning.
Try replacing NULL by an arbitrary number.
Arthur
