Other Parts Discussed in Thread: CC1312R, CC1190
We designed a customized board using CC1352P-launchpad-P2 as a reference. Since we only need the 2.4GHz signals, we dropped the 900MHz matching components, and tied one control pin on SKY13317 to GND, then used only two GPIO to switch between low and high power 900MHz signals.
/* Owned by /ti/drivers/RF as */ extern const uint_least8_t CONFIG_RF_24GHZ_CONST; #define CONFIG_RF_24GHZ 27 /* Owned by /ti/drivers/RF as */ extern const uint_least8_t CONFIG_RF_HIGH_PA_CONST; #define CONFIG_RF_HIGH_PA 28 /* Owned by /ti/drivers/RF as */ extern const uint_least8_t CONFIG_RF_SUB1GHZ_CONST; #define CONFIG_RF_SUB1GHZ 30
The GPIO were switched from DIO_28 and DIO_29 in the reference design to DIO_27 and DIO_28 to make layout easier. In such case how should we implement the RF/Antenna switching callback function? Since the name of the RF Antenna PIN names are defined in syscfg, Can we simply copy the code generated by syscfg for reference board?
/* * ======== Antenna switching ======== */ /* * ======== rfDriverCallbackAntennaSwitching ======== * Sets up the antenna switch depending on the current PHY configuration. * * Truth table: * * Path DIO27 DIO28 DIO30 * ========== ===== ===== ===== * Off 0 0 0 * 2.4 GHZ 1 0 0 * HIGH PA 0 1 0 * SUB1 GHZ 0 0 1 */ void rfDriverCallbackAntennaSwitching(RF_Handle client, RF_GlobalEvent events, void *arg) { if (events & RF_GlobalEventRadioSetup) { bool sub1GHz = false; uint8_t loDivider = 0; /* Switch off all paths. */ GPIO_write(CONFIG_RF_24GHZ, 0); GPIO_write(CONFIG_RF_HIGH_PA, 0); GPIO_write(CONFIG_RF_SUB1GHZ, 0); /* Decode the current PA configuration. */ RF_TxPowerTable_PAType paType = (RF_TxPowerTable_PAType)RF_getTxPower(client).paType; /* Decode the generic argument as a setup command. */ RF_RadioSetup* setupCommand = (RF_RadioSetup*)arg; switch (setupCommand->common.commandNo) { case (CMD_RADIO_SETUP): case (CMD_BLE5_RADIO_SETUP): loDivider = RF_LODIVIDER_MASK & setupCommand->common.loDivider; /* Sub-1GHz front-end. */ if (loDivider != 0) { sub1GHz = true; } break; case (CMD_PROP_RADIO_DIV_SETUP): loDivider = RF_LODIVIDER_MASK & setupCommand->prop_div.loDivider; /* Sub-1GHz front-end. */ if (loDivider != 0) { sub1GHz = true; } break; default:break; } if (sub1GHz) { /* Sub-1 GHz */ if (paType == RF_TxPowerTable_HighPA) { /* PA enable --> HIGH PA * LNA enable --> Sub-1 GHz */ GPIO_setMux(CONFIG_RF_24GHZ, IOC_PORT_GPIO); /* Note: RFC_GPO3 is a work-around because the RFC_GPO1 (PA enable signal) is sometimes not de-asserted on CC1352 Rev A. */ GPIO_setMux(CONFIG_RF_HIGH_PA, IOC_PORT_RFC_GPO3); GPIO_setMux(CONFIG_RF_SUB1GHZ, IOC_PORT_RFC_GPO0); } else { /* RF core active --> Sub-1 GHz */ GPIO_setMux(CONFIG_RF_24GHZ, IOC_PORT_GPIO); GPIO_setMux(CONFIG_RF_HIGH_PA, IOC_PORT_GPIO); GPIO_setMux(CONFIG_RF_SUB1GHZ, IOC_PORT_GPIO); GPIO_write(CONFIG_RF_SUB1GHZ, 1); } } else { /* 2.4 GHz */ if (paType == RF_TxPowerTable_HighPA) { /* PA enable --> HIGH PA * LNA enable --> 2.4 GHz */ GPIO_setMux(CONFIG_RF_24GHZ, IOC_PORT_RFC_GPO0); /* Note: RFC_GPO3 is a work-around because the RFC_GPO1 (PA enable signal) is sometimes not de-asserted on CC1352 Rev A. */ GPIO_setMux(CONFIG_RF_HIGH_PA, IOC_PORT_RFC_GPO3); GPIO_setMux(CONFIG_RF_SUB1GHZ, IOC_PORT_GPIO); } else { /* RF core active --> 2.4 GHz */ GPIO_setMux(CONFIG_RF_24GHZ, IOC_PORT_GPIO); GPIO_setMux(CONFIG_RF_HIGH_PA, IOC_PORT_GPIO); GPIO_setMux(CONFIG_RF_SUB1GHZ, IOC_PORT_GPIO); GPIO_write(CONFIG_RF_24GHZ, 1); } } } else if (events & RF_GlobalEventRadioPowerDown) { /* Switch off all paths. */ GPIO_write(CONFIG_RF_24GHZ, 0); GPIO_write(CONFIG_RF_HIGH_PA, 0); GPIO_write(CONFIG_RF_SUB1GHZ, 0); /* Reset the IO multiplexer to GPIO functionality */ GPIO_setMux(CONFIG_RF_24GHZ, IOC_PORT_GPIO); GPIO_setMux(CONFIG_RF_HIGH_PA, IOC_PORT_GPIO); GPIO_setMux(CONFIG_RF_SUB1GHZ, IOC_PORT_GPIO); } }
Please advise.
ZL
