Just confirm, when CC3235SF is set as secondary /responder, does GPIO16 (GSPI_MOSI) still input/output?
Thank you in advance
Maynard
Hi Kobi,
Thank you for your response.
Taking the GPIO16 (GSPI_MOSI) for example, when CC3235SF is a master, only "MO" ,because CC3235SF is an output only, and when CC3235SF is a slave, needs "SI",because CC3235SF is an input only. Other SPI pins are the same. Is this correct?
Maynard
