i want to turn off the ELP mode what is the best option.
i followed below commands:
iw wlan0 set power_save off
echo 0 > /sys/kernel/debug/ieee80211/phy0/wlcore/sleep_auth ( is this required ..?)
what is the importance of second command.? is it mandatory. or else can you suggest some other method where i can permanently turn off the powersave mode or ELP. problem is second commands path changes every time I reload the driver (phy0 changes to phy1 and to phy2....). do suggest some better method.
Lavakumar S
