I am new to sysconfig and I now I likely need help getting the last pin connected on this Mikroe ProFET 15. I need an ADC pin on the booster header with the current configuration.
I have determined max output V as used at about 0.7VDC at 13.5VDC and 11A so less than 1.8VDC.
/** * These arguments were used when this file was generated. They will be automatically applied on subsequent loads * via the GUI or CLI. Run CLI with '--help' for additional information on how to override these arguments. * @cliArgs --board "/ti/boards/CC3235SF_LAUNCHXL" --rtos "tirtos7" --product "simplelink_cc32xx_sdk@7.10.00.13" * @versions {"tool":"1.17.0+3128"} */ /** * Import the modules used in this configuration. */ const DriverLib = scripting.addModule("/ti/devices/DriverLib"); const Display = scripting.addModule("/ti/display/Display"); const Display1 = Display.addInstance(); const ADC = scripting.addModule("/ti/drivers/ADC", {}, false); const ADC1 = ADC.addInstance(); const Board = scripting.addModule("/ti/drivers/Board"); const Crypto = scripting.addModule("/ti/drivers/Crypto"); const Crypto1 = Crypto.addInstance(); const DMA = scripting.addModule("/ti/drivers/DMA"); const GPIO = scripting.addModule("/ti/drivers/GPIO"); const GPIO1 = GPIO.addInstance(); const GPIO2 = GPIO.addInstance(); const GPIO3 = GPIO.addInstance(); const GPIO4 = GPIO.addInstance(); const GPIO5 = GPIO.addInstance(); const I2C = scripting.addModule("/ti/drivers/I2C", {}, false); const I2C1 = I2C.addInstance(); const I2S = scripting.addModule("/ti/drivers/I2S", {}, false); const I2S1 = I2S.addInstance(); const Power = scripting.addModule("/ti/drivers/Power"); const SPI = scripting.addModule("/ti/drivers/SPI"); const SPI1 = SPI.addInstance(); const Timer = scripting.addModule("/ti/drivers/Timer"); const Timer1 = Timer.addInstance(); const Timer2 = Timer.addInstance(); const Timer3 = Timer.addInstance(); const Watchdog = scripting.addModule("/ti/drivers/Watchdog"); const Watchdog1 = Watchdog.addInstance(); const SimpleLinkWifi = scripting.addModule("/ti/drivers/net/wifi/SimpleLinkWifi"); const atcmd = scripting.addModule("/ti/drivers/net/wifi/atcmd", {}, false); const atcmd1 = atcmd.addInstance(); const net_utils = scripting.addModule("/ti/drivers/net/wifi/net_utils", {}, false); const net_utils1 = net_utils.addInstance(); const HTTPClient = scripting.addModule("/ti/net/HTTPClient", {}, false); const HTTPClient1 = HTTPClient.addInstance(); const MQTT = scripting.addModule("/ti/net/MQTT", {}, false); const MQTT1 = MQTT.addInstance(); const SNTP = scripting.addModule("/ti/net/SNTP"); const SlNet = scripting.addModule("/ti/net/SlNet"); const SlNet1 = SlNet.addInstance(); const Settings = scripting.addModule("/ti/posix/tirtos/Settings"); const BIOS = scripting.addModule("/ti/sysbios/BIOS"); const Event = scripting.addModule("/ti/sysbios/knl/Event"); const Idle = scripting.addModule("/ti/sysbios/knl/Idle", {}, false); const Idle2 = Idle.addInstance(); const Mailbox = scripting.addModule("/ti/sysbios/knl/Mailbox"); const Error = scripting.addModule("/ti/sysbios/runtime/Error"); const SysCallback = scripting.addModule("/ti/sysbios/runtime/SysCallback"); const Timestamp = scripting.addModule("/ti/sysbios/runtime/Timestamp"); const JSON = scripting.addModule("/ti/utils/JSON"); /** * Write custom configuration values to the imported modules. */ Display1.$name = "CONFIG_Display_0"; Display1.$hardware = system.deviceData.board.components.XDS110UART; Display1.uart.$name = "CONFIG_UART2_0"; Display1.uart.uart.$assign = "UART0"; Display1.uart.uart.txPin.$assign = "GP01"; Display1.uart.uart.txDmaChannel.$assign = "UDMA_CH9"; Display1.uart.uart.rxPin.$assign = "GP02"; Display1.uart.uart.rxDmaChannel.$assign = "UDMA_CH8"; ADC1.$name = "CONFIG_ADC_PFIS"; Crypto1.$name = "CONFIG_Crypto_0"; GPIO1.$hardware = system.deviceData.board.components.SW2; GPIO1.$name = "CONFIG_GPIO_BUTTON_0"; GPIO1.interruptTrigger = "Rising Edge"; GPIO1.gpioPin.$assign = "boosterpack.3"; GPIO2.$hardware = system.deviceData.board.components.SW3; GPIO2.$name = "CONFIG_GPIO_BUTTON_1"; GPIO2.interruptTrigger = "Rising Edge"; GPIO2.gpioPin.$assign = "boosterpack.11"; GPIO3.$hardware = system.deviceData.board.components.LED_BLUE; GPIO3.$name = "CONFIG_GPIO_LED_0"; GPIO4.$name = "CONFIG_GPIO_PF15IN"; GPIO4.mode = "Output"; GPIO4.gpioPin.$assign = "boosterpack.28"; GPIO5.$name = "CONFIG_GPIO_PFDEN"; GPIO5.gpioPin.$assign = "boosterpack.19"; I2C1.$hardware = system.deviceData.board.components.LP_I2C; I2C1.$name = "CONFIG_I2C_TMP"; I2S1.$name = "CONFIG_I2S_0"; Power.ioRetentionShutdown = ["GRP_1"]; Power.parkPins.$name = "ti_drivers_power_PowerCC32XXPins0"; SPI1.$name = "CONFIG_SPI_0"; SPI1.mode = "Four Pin CS Active Low"; SPI1.defaultTxBufferValue = "0"; SPI1.spi.$assign = "SPI0"; SPI1.spi.sclkPin.$assign = "boosterpack.7"; SPI1.spi.pociPin.$assign = "boosterpack.14"; SPI1.spi.picoPin.$assign = "boosterpack.15"; SPI1.spi.dmaRxChannel.$assign = "UDMA_CH6"; SPI1.spi.dmaTxChannel.$assign = "UDMA_CH7"; SPI1.spi.csnPin.$assign = "boosterpack.18"; Timer1.$name = "CONFIG_TIMER_0"; Timer1.timerType = "32 Bits"; Timer1.timer.$assign = "Timer0"; Timer2.$name = "CONFIG_TIMER_1"; Timer2.timer.$assign = "Timer1"; Timer3.$name = "CONFIG_TIMER_2"; Timer3.timer.$assign = "Timer1"; Watchdog1.$name = "CONFIG_WATCHDOG_0"; Watchdog1.watchdog.$assign = "WATCHDOG0"; atcmd1.$name = "CONFIG_ATCMD_0"; net_utils1.$name = "CONFIG_NET_UTILS_0"; HTTPClient1.$name = "CONFIG_HTTPCLIENT_0"; MQTT1.$name = "CONFIG_MQTT_0"; SlNet1.$name = "CONFIG_SLNET"; SlNet1.ifName = "CC32xx"; BIOS.assertsEnabled = false; BIOS.heapBaseAddr = "__primary_heap_start__"; BIOS.heapEndAddr = "__primary_heap_end__"; const Hwi = scripting.addModule("/ti/sysbios/family/arm/m3/Hwi", {}, false); Hwi.enableException = false; Idle2.$name = "powerIdle"; Idle2.idleFxn = "Power_idleFunc"; const Semaphore = scripting.addModule("/ti/sysbios/knl/Semaphore", {}, false); Semaphore.supportsPriority = false; const Task = scripting.addModule("/ti/sysbios/knl/Task", {}, false); Task.checkStackFlag = false; Task.defaultStackSize = 512; Task.idleTaskStackSize = 512; Error.policy = "Error_SPIN"; Error.printDetails = false; const System = scripting.addModule("/ti/sysbios/runtime/System", {}, false); System.abortFxn = "System_abortSpin"; System.exitFxn = "System_exitSpin"; System.extendedFormats = "%f"; System.supportModule = "SysCallback"; /** * Pinmux solution for unlocked pins/peripherals. This ensures that minor changes to the automatic solver in a future * version of the tool will not impact the pinmux you originally saw. These lines can be completely deleted in order to * re-solve from scratch. */ ADC1.adc.$suggestSolution = "ADC0"; ADC1.adc.adcPin.$suggestSolution = "<error>"; GPIO3.gpioPin.$suggestSolution = "boosterpack.29"; I2C1.i2c.$suggestSolution = "I2C0"; I2C1.i2c.sdaPin.$suggestSolution = "boosterpack.10"; I2C1.i2c.sclPin.$suggestSolution = "boosterpack.9"; I2S1.i2s.$suggestSolution = "McASP0"; I2S1.i2s.SD0Pin.$suggestSolution = "boosterpack.17"; I2S1.i2s.SD1Pin.$suggestSolution = "boosterpack.30"; I2S1.i2s.SCKPin.$suggestSolution = "boosterpack.4"; I2S1.i2s.WSPin.$suggestSolution = "boosterpack.27"; I2S1.i2s.dmaRxChannel.$suggestSolution = "UDMA_CH18"; I2S1.i2s.dmaTxChannel.$suggestSolution = "UDMA_CH19";
