Other Parts Discussed in Thread: CCSTUDIO, UNIFLASH
We want to connect the CC3235SF to a WPA-Enterprise EAP-TLS Wi-Fi. We have set up a FreeRadius server and can connect successfully from different systems (e.g. from Linux machines) so we believe the FreeRadius setup is correct. But when we try to connect the CC3235SF, it sends a "Bad Certificate" alert after it has received the "Server Hello" with the server certificate(s). On the CC3235SF, we get a "SL_WLAN_EVENT_DISCONNECT" with a ReasonCode of "SL_WLAN_DISCONNECT_UNSPECIFIED" which is not helpful at all.
So, why is there a "Bad Certicate" alert, what is wrong with which certificate? What are the exact requirements that the certificates and keys for a successful EAP-TLS connection need to fulfill?
For further investigation, I append the three certificate/key files that we deploy on the CC3235SF as well as the Wireshark capture of the communication.
