We use WL1271L on 3730 platform with version TI_P6_15.52 bts file.
Android 2.3.4 is used.
Sometimes, there would be problem when we want to turn on Bluetooth. Error log is as follows,
01-01 04:13:01.667 I/bluedroid( 1190): Starting hciattach daemon
01-01 04:13:01.784 E/uim-sysfs: ( 1038): uim: Inside st_uart_config
01-01 04:13:01.784 E/uim-sysfs: ( 1038): uim:install set to 1
01-01 04:13:01.784 E/uim-sysfs: ( 1038): uim: Inside set_baud_rate
01-01 04:13:01.784 E/uim-sysfs: ( 1038): uim: set_baud_rate() done
01-01 04:13:01.784 E/uim-sysfs: ( 1038): uim: Setting speed to 3000000
01-01 04:13:01.784 E/uim-sysfs: ( 1038): uim: Inside read_command_complete
01-01 04:13:01.784 E/uim-sysfs: ( 1038): uim: Command complete started
01-01 04:13:01.784 E/uim-sysfs: ( 1038): uim: Inside read_hci_event
01-01 04:13:01.784 E/uim-sysfs: ( 1038): uim: read_hci_event
ti_st_open: st_register failed -22
(stc): st_register(2)
(stc): chnl_id list empty :2
(stk) : st_kim_start
(stk) :ldisc_install = 1
(stk) :line disc installation timed out
(stk) :ldisc_install = 0
Would you please give us any suggestion to check it out, because this issue has bothered me for a long time.
Thank you.
