Operating as a Wi-Fi station using simplelink_cc32xx_sdk_3_20_00_06 we connect the device to an Access Point using EAP-TLS Authentication. The Access Point DHCP Server lease interval is configured for 10 minutes (T1: ~4 ½ minutes) along with a re-authentication interval of 3000 seconds (50 minutes).
When the Wi-Fi station DHCP renew collides with the EAP renew process it appears as if the DHCP Client on the Network Processor (NWP) fails [dies] and does not recover until the connection to the Access Point is disconnected / reconnected or new re-authentication interval occurs.
Via TCP dump on the Access Point we see no attempt from the station to perform DHCP renew, though the Wi-Fi connection to the station is still established. After the DHCP lease expires we receive event notification from the NWP, example:
[NETAPP EVENT] IPv4 Lost: IP=0.0.0.0 ,
[NETAPP EVENT] DHCP timeout
Example of what is observed on the Access Point from tcpdump, note: we are using SNTP from the station every 30 seconds to verify/monitor the connection:
DHCP Lease : 10 minutes
Re-authentication interval: 50 minutes
04:19:56.588537 IP 192.168.1.92.bootpc > 192.168.1.1.bootps: BOOTP/DHCP, Request from f0:c7:7f:xx:xx:xx (oui Unknown), length 300
04:19:56.591328 IP 192.168.1.1.bootps > 192.168.1.92.bootpc: BOOTP/DHCP, Reply, length 300
04:20:11.081798 IP 192.168.1.92.52471 > 192.168.1.1.ntp: NTPv4, Client, length 48
04:20:11.082024 IP 192.168.1.1.ntp > 192.168.1.92.52471: NTPv4, Server, length 48
04:20:41.187068 IP 192.168.1.92.51109 > 192.168.1.1.ntp: NTPv4, Client, length 48
04:20:41.187291 IP 192.168.1.1.ntp > 192.168.1.92.51109: NTPv4, Server, length 48
04:20:46.201314 ARP, Request who-has 192.168.1.92 tell 192.168.1.1, length 28
04:20:46.394892 ARP, Reply 192.168.1.92 is-at f0:c7:7f:xx:xx:xx (oui Unknown), length 28
04:21:11.292576 IP 192.168.1.92.60175 > 192.168.1.1.ntp: NTPv4, Client, length 48
04:21:11.292801 IP 192.168.1.1.ntp > 192.168.1.92.60175: NTPv4, Server, length 48
04:21:41.397962 IP 192.168.1.92.57487 > 192.168.1.1.ntp: NTPv4, Client, length 48
04:21:41.398200 IP 192.168.1.1.ntp > 192.168.1.92.57487: NTPv4, Server, length 48
04:21:46.409316 ARP, Request who-has 192.168.1.92 tell 192.168.1.1, length 28
04:21:46.605903 ARP, Reply 192.168.1.92 is-at f0:c7:7f:xx:xx:xx (oui Unknown), length 28
04:22:11.502238 IP 192.168.1.92.57178 > 192.168.1.1.ntp: NTPv4, Client, length 48
04:22:11.502477 IP 192.168.1.1.ntp > 192.168.1.92.57178: NTPv4, Server, length 48
04:22:41.607462 IP 192.168.1.92.58398 > 192.168.1.1.ntp: NTPv4, Client, length 48
04:22:41.607737 IP 192.168.1.1.ntp > 192.168.1.92.58398: NTPv4, Server, length 48
04:22:46.617313 ARP, Request who-has 192.168.1.92 tell 192.168.1.1, length 28
04:22:46.815036 ARP, Reply 192.168.1.92 is-at f0:c7:7f:xx:xx:xx (oui Unknown), length 28
04:23:11.711848 IP 192.168.1.92.61000 > 192.168.1.1.ntp: NTPv4, Client, length 48
04:23:11.712090 IP 192.168.1.1.ntp > 192.168.1.92.61000: NTPv4, Server, length 48
04:23:41.817262 IP 192.168.1.92.65495 > 192.168.1.1.ntp: NTPv4, Client, length 48
04:23:41.817635 IP 192.168.1.1.ntp > 192.168.1.92.65495: NTPv4, Server, length 48
04:23:46.825315 ARP, Request who-has 192.168.1.92 tell 192.168.1.1, length 28
04:23:47.030448 ARP, Reply 192.168.1.92 is-at f0:c7:7f:xx:xx:xx (oui Unknown), length 28
04:24:11.922500 IP 192.168.1.92.58609 > 192.168.1.1.ntp: NTPv4, Client, length 48
04:24:11.922731 IP 192.168.1.1.ntp > 192.168.1.92.58609: NTPv4, Server, length 48
04:24:19.705329 IP 192.168.1.92.bootpc > 192.168.1.1.bootps: BOOTP/DHCP, Request from f0:c7:7f:xx:xx:xx (oui Unknown), length 300
04:24:19.707560 IP 192.168.1.1.bootps > 192.168.1.92.bootpc: BOOTP/DHCP, Reply, length 300
04:24:42.027891 IP 192.168.1.92.59979 > 192.168.1.1.ntp: NTPv4, Client, length 48
04:24:42.028126 IP 192.168.1.1.ntp > 192.168.1.92.59979: NTPv4, Server, length 48
04:24:47.033315 ARP, Request who-has 192.168.1.92 tell 192.168.1.1, length 28
04:24:47.235709 ARP, Reply 192.168.1.92 is-at f0:c7:7f:xx:xx:xx (oui Unknown), length 28
04:25:12.133281 IP 192.168.1.92.52044 > 192.168.1.1.ntp: NTPv4, Client, length 48
04:25:12.133521 IP 192.168.1.1.ntp > 192.168.1.92.52044: NTPv4, Server, length 48
04:25:42.237536 IP 192.168.1.92.52870 > 192.168.1.1.ntp: NTPv4, Client, length 48
04:25:42.237787 IP 192.168.1.1.ntp > 192.168.1.92.52870: NTPv4, Server, length 48
04:25:47.241309 ARP, Request who-has 192.168.1.92 tell 192.168.1.1, length 28
04:25:47.445335 ARP, Reply 192.168.1.92 is-at f0:c7:7f:xx:xx:xx (oui Unknown), length 28
04:26:12.342910 IP 192.168.1.92.49940 > 192.168.1.1.ntp: NTPv4, Client, length 48
04:26:12.343145 IP 192.168.1.1.ntp > 192.168.1.92.49940: NTPv4, Server, length 48
04:26:42.447288 IP 192.168.1.92.52503 > 192.168.1.1.ntp: NTPv4, Client, length 48
04:26:42.447527 IP 192.168.1.1.ntp > 192.168.1.92.52503: NTPv4, Server, length 48
04:26:47.449317 ARP, Request who-has 192.168.1.92 tell 192.168.1.1, length 28
04:26:47.655346 ARP, Reply 192.168.1.92 is-at f0:c7:7f:xx:xx:xx (oui Unknown), length 28
04:27:12.552540 IP 192.168.1.92.64037 > 192.168.1.1.ntp: NTPv4, Client, length 48
04:27:12.552765 IP 192.168.1.1.ntp > 192.168.1.92.64037: NTPv4, Server, length 48
04:27:42.659930 IP 192.168.1.92.63903 > 192.168.1.1.ntp: NTPv4, Client, length 48
04:27:42.660163 IP 192.168.1.1.ntp > 192.168.1.92.63903: NTPv4, Server, length 48
04:27:47.673320 ARP, Request who-has 192.168.1.92 tell 192.168.1.1, length 28
04:27:47.865748 ARP, Reply 192.168.1.92 is-at f0:c7:7f:xx:xx:xx (oui Unknown), length 28
04:28:12.766171 IP 192.168.1.92.60655 > 192.168.1.1.ntp: NTPv4, Client, length 48
04:28:12.766381 IP 192.168.1.1.ntp > 192.168.1.92.60655: NTPv4, Server, length 48
04:28:25.139027 EAP packet (0) v1, len 26
04:28:25.344070 EAP packet (0) v1, len 62
04:28:25.550334 EAP packet (0) v1, len 6
04:28:25.866772 EAP packet (0) v1, len 1408
04:28:25.958236 EAP packet (0) v1, len 117
04:28:26.166771 EAP packet (0) v1, len 6
04:28:26.370639 EAPOL key (3) v1, len 117
04:28:26.371556 EAPOL key (3) v1, len 117
04:28:26.374278 EAPOL key (3) v1, len 95
05:19:48.278223 f0:c7:7f:xx:xx:xx (oui Unknown) > Broadcast Null Unnumbered, xid, Flags [Response], length 6: 01 00
05:19:48.286639 EAP packet (0) v1, len 26
05:19:48.301515 EAP packet (0) v1, len 62
05:19:48.306900 EAP packet (0) v1, len 6
05:19:48.427706 EAP packet (0) v1, len 1408
05:19:48.431681 EAP packet (0) v1, len 117
05:19:48.466608 EAP packet (0) v1, len 6
05:19:48.476376 EAPOL key (3) v1, len 117
05:19:48.479889 EAPOL key (3) v1, len 95
05:19:48.490658 IP 0.0.0.0.bootpc > 255.255.255.255.bootps: BOOTP/DHCP, Request from f0:c7:7f:xx:xx:xx (oui Unknown), length 300
05:19:48.491203 ARP, Request who-has 192.168.1.92 tell 192.168.1.1, length 28
When this issue is detected is there a graceful way that we can "restart" the Client DHCP process on the NWP rather than having to reestablish (toggle) the Wi-Fi connection to the Access Point?
