Other Parts Discussed in Thread: HDC2080, TMP116,
Dear experts,
i have tried to read the temperature and humidity value from HDC2080 using i2ctmp example but i am getting 0 only. i have shared my code with syscfg file for your reference please check and point out the mistakes i made.
/* * Copyright (c) 2018-2022, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ /* * ======== i2ctmp.c ======== */ #include <stdint.h> #include <stddef.h> #include <unistd.h> /* Driver Header files */ #include <ti/drivers/GPIO.h> #include <ti/drivers/I2C.h> #include <ti/display/Display.h> /* Driver configuration */ #include "ti_drivers_config.h" //#include <ti/sail/hdc2010/hdc2010.h> #define TASKSTACKSIZE 640 /* Temperature result registers */ #define TMP11X_RESULT_REG 0x0000 /* I2C slave addresses */ #define TMP11X_BASSENSORS_ADDR 0x40 #define TMP116_LAUNCHPAD_ADDR 0x41 /* Number of supported sensor iterations */ #define TMP_COUNT 2 /* * Data structure containing currently supported I2C TMP sensors. * Sensors are ordered by descending preference. */ static const struct { uint8_t address; uint8_t resultReg; char *id; } sensors[TMP_COUNT] = {{TMP11X_BASSENSORS_ADDR, TMP11X_RESULT_REG, "11X"}, {TMP116_LAUNCHPAD_ADDR, TMP11X_RESULT_REG, "116"}}; static uint8_t slaveAddress; static Display_Handle display; static void i2cErrorHandler(I2C_Transaction *transaction, Display_Handle display); /* * ======== mainThread ======== */ void *mainThread(void *arg0) { uint16_t sample; int16_t temperature; uint8_t txBuffer[1]; uint8_t rxBuffer[2]; int8_t i; I2C_Handle i2c; I2C_Params i2cParams; I2C_Transaction i2cTransaction; /* Call driver init functions */ Display_init(); GPIO_init(); I2C_init(); /* Configure the LED and if applicable, the TMP_EN pin */ GPIO_setConfig(CONFIG_GPIO_LED_0, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_LOW); #ifdef CONFIG_GPIO_TMP_EN GPIO_setConfig(CONFIG_GPIO_TMP_EN, GPIO_CFG_OUT_STD | GPIO_CFG_OUT_HIGH); /* Allow the sensor to power on */ sleep(1); #endif /* Open the UART display for output */ display = Display_open(Display_Type_UART, NULL); if (display == NULL) { while (1) {} } /* Turn on user LED */ GPIO_write(CONFIG_GPIO_LED_0, CONFIG_GPIO_LED_ON); Display_printf(display, 0, 0, "Starting the i2ctmp example\n"); /* Create I2C for usage */ I2C_Params_init(&i2cParams); i2cParams.bitRate = I2C_100kHz; i2c = I2C_open(CONFIG_I2C_TMP, &i2cParams); if (i2c == NULL) { Display_printf(display, 0, 0, "Error Initializing I2C\n"); while (1) {} } else { Display_printf(display, 0, 0, "I2C Initialized!\n"); } /* Common I2C transaction setup */ i2cTransaction.writeBuf = txBuffer; i2cTransaction.writeCount = 1; i2cTransaction.readBuf = rxBuffer; i2cTransaction.readCount = 0; /* * Determine which I2C sensors are present by querying known I2C * slave addresses. */ for (i = TMP_COUNT - 1; i >= 0; i--) { i2cTransaction.slaveAddress = sensors[i].address; txBuffer[0] = sensors[i].resultReg; if (I2C_transfer(i2c, &i2cTransaction)) { slaveAddress = sensors[i].address; Display_printf(display, 0, 0, "Detected TMP%s sensor with slave" " address 0x%x", sensors[i].id, sensors[i].address); } else { i2cErrorHandler(&i2cTransaction, display); } } /* If we never assigned a slave address */ if (slaveAddress == 0) { Display_printf(display, 0, 0, "Failed to detect a sensor!"); I2C_close(i2c); while (1) {} } Display_printf(display, 0, 0, "\nUsing last known sensor for samples."); i2cTransaction.slaveAddress = slaveAddress; /* Take 20 samples and print them out onto the console */ i2cTransaction.readCount = 4; for (sample = 0; sample < 20; sample++) { if (I2C_transfer(i2c, &i2cTransaction)) { /* * Extract degrees C from the received data; * see TMP sensor datasheet */ temperature = rxBuffer[0] ; Display_printf(display, 0, 0, "Sample %d ",temperature); temperature = (temperature << 8) | (rxBuffer[1]); //temperature *= 0.0078125; float f =temperature; f = ((f * 165.0f) / 65536.0f) - 40.0f; int16_t humidity = rxBuffer[2]; humidity = (humidity << 8) | rxBuffer[3]; float H = humidity; H = (H/65536.0) * 100.0; Display_printf(display, 0, 0, "Sample %u: %0.2f (C), %0.2f ", sample, f,H); } else { i2cErrorHandler(&i2cTransaction, display); } /* Sleep for 1 second */ sleep(1); } I2C_close(i2c); Display_printf(display, 0, 0, "I2C closed!"); return (NULL); } /* * ======== i2cErrorHandler ======== */ static void i2cErrorHandler(I2C_Transaction *transaction, Display_Handle display) { switch (transaction->status) { case I2C_STATUS_TIMEOUT: Display_printf(display, 0, 0, "I2C transaction timed out!"); break; case I2C_STATUS_CLOCK_TIMEOUT: Display_printf(display, 0, 0, "I2C serial clock line timed out!"); break; case I2C_STATUS_ADDR_NACK: Display_printf(display, 0, 0, "I2C slave address 0x%x not" " acknowledged!", transaction->slaveAddress); break; case I2C_STATUS_DATA_NACK: Display_printf(display, 0, 0, "I2C data byte not acknowledged!"); break; case I2C_STATUS_ARB_LOST: Display_printf(display, 0, 0, "I2C arbitration to another master!"); break; case I2C_STATUS_INCOMPLETE: Display_printf(display, 0, 0, "I2C transaction returned before completion!"); break; case I2C_STATUS_BUS_BUSY: Display_printf(display, 0, 0, "I2C bus is already in use!"); break; case I2C_STATUS_CANCEL: Display_printf(display, 0, 0, "I2C transaction cancelled!"); break; case I2C_STATUS_INVALID_TRANS: Display_printf(display, 0, 0, "I2C transaction invalid!"); break; case I2C_STATUS_ERROR: Display_printf(display, 0, 0, "I2C generic error!"); break; default: Display_printf(display, 0, 0, "I2C undefined error case!"); break; } }
regards
Surya
