Part Number: CC2652P
We use rcp project for our gateway to provide Matter service. In our test, the rcp doesn't restore network information after power off/on. How to solve this problem?
SDK : 6_40_00_13
SDK : 6_40_00_13
Hi Kimi,
When you say "power off/on", do you mean power to the RCP itself? Or the entire gateway?
The network info is set by the host, so in case the storage of this info is non-persistent on the host, then a new network info could be set by the host (effectively causing your observation of "doesn't restore network information after power off/on").
For example, on chip-tool, by default it will point to /tmp for network info. But this can be changed to point to a persistent location, such as /usr.
This can be changed in matter/examples/chip-tool/config/PersistentStorage.cpp to point towards /usr instead of /tmp in the GetFilename function.
The respective file names you'd eventually see there are chip_tool_config.alpha.ini and chip_tool_config.ini.
Toby
By "power off/on", we mean power cycle the gateway which includes power cycle RCP. We also see the same behavior when testing Matter/OTBR on Raspberry Pi. We will check and test again if this is related to /tmp folder in GetFilename function.
