• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Amplifiers » High Speed Amplifiers » High Speed Amplifiers Forum » Voltage controlled current source
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 3 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 4 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 10 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is not answered
Wasiu Popoola
Posted by Wasiu Popoola
on Jul 15 2010 13:31 PM
Prodigy90 points
I am looking to design a voltage controlled current source, operating at up to 500mA and 20MHz to drive an LED.
I managed a design but it appears to 'peak' at about 7MHz. That is the received signal amplitude is much higher at about 7MHz than at any other frequency.
Can anyone help please?
I will appreciate alternative circuit suggestions as well.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Kristoffer Flores
    Posted by Kristoffer Flores
    on Jul 16 2010 11:12 AM
    Genius9710 points
    Hi Wasiu,
    I"m curious as to what your current circuit looks like - could you post a rough schematic or description?
    There are different ways to implement current source circuits. Some current source circuits have an op amp drive a transistor base/gate in a buffer configuration so that the output current is supplied through the transistor to the load. Other circuits rely on the op amp's current drive directly.
    What is the input signal to the circuit (voltage/current, amplitude, DC level, bandwidth, etc) and what is the desired output current transfer function (bandwidth and what input corresponds to what output current)? I'm assuming unipolar output current since it's an LED.
    Must the LED load be referenced to ground or can it be floating? What LED is it? What supplies are available? Any other constraints?
    The OPA2673 is a dual op amp that can source over 500mA at each output and has a very wide bandwidth (G=1, 600MHz).
    OPA2673
    Report Abuse
    • Reply
  • Wasiu Popoola
    on Jul 16 2010 11:40 AM
    Prodigy90 points
    Hi Kristoffer,
    My circuit is the first one you described.  use LM6171 op amp to drive 2SC5707 transistor (Used bcos of its high power capability). The input signal is pure sinusoid of 1Vp-p, and up to 20MHz. I used another difference amplifier before this stage to add a DC value of about 2V to the signal and the sense resistor(At the emiiter of the transistor) is adjusted to get the required current of between 200-300mA.
    I am basically design a driver circuit for an LED and i want to drive this LED using a sinusoidal signal of up 30MHz. It is a white LED. I dont think i care a wheather it floats or not once i can modulate the light intensity.
    Any more suggestions please?
    many thanks
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
