Hello all,
Would you mind if we ask LM319?
<Question1>
In case of V+=5V, V-=0V, the data sheet shows that Input Votage Range is Min=1V, Max=3V.
If input volage will be less than 1V or over than 3V, will the device be damaged or not?
When we use input voltage range 0~5V, how much of voltage for V+=5V, V-=0V should we suply?
<Question2>
In case of V+=5V, V-=0V, how much of Input Votage Range will be?
If you have the characteristic table which indicates "supply voltage(V+, V-) - Input Voltage Range",
could you let know us?
Kind regards,
Hirotaka Matsumoto
