For DFMEA failure analysis, looking at the OPA350 op amp internal diagram below:
It seems the input voltage on the op amps + and – terminals will not likely get to the output of the op amp in case the op amps fail.
In case the op amp fails, it looks like only power supply rail voltage may propagate to the output? Is this understanding correct?
Thank you, Keith
