Other Parts Discussed in Thread: TVP5158, , ADS7846
Tool/software: Linux
TI, I test the tvp5158 on the am5728. And I found that I can not capture every channel independently.
I first start capture channel 1,then I start capture channel 2.After I start capture channel 2,the channel 1 is not ok.The vip can not get data from channel 1.
channel 1:
gst-launch-1.0 v4l2src device=/dev/video1 num-buffers=-1 io-mode=4 ! 'video/x-raw,format=(string)YUY2, width=(int)720, height=(int)240' ! vpe num-input-buffers=8 ! queue ! waylandsink
channel 2:
gst-launch-1.0 v4l2src device=/dev/video2 num-buffers=-1 io-mode=4 ! 'video/x-raw,format=(string)YUY2, width=(int)720, height=(int)240' ! vpe num-input-buffers=8 ! queue ! waylandsink
I debug it by open debug option of vip driver,there are not irq from vip.
echo 8 > /sys/module/ti_vip/parameters/debug
if I use dmabuftest,it is ok if capture four channel.
dmabuftest --multi 4 -d /dev/video1 -c 720x288@YUYV -d /dev/video2 -c 720x288@YUYV -d /dev/video3 -c 720x288@YUYV -d /dev/video4 -c 720x288@YUYV -s 32:1920x1080
are there any problem of vip driver?
any suggestion?
BR,
vefone
