Other Parts Discussed in Thread: LMX2581, LMX2571, , LMX2582
I am trying to use the LMX2594RHAT to make a frequency that will stay phase coherent when changing frequency. This frequency change needs to be accurately timed. Reading section 7.5 of the datasheet "When CSB goes high, data is transferred from the data field into the selected register bank." which lead me to believe that the CSB line could be used to control when the frequency will be changed. Upon testing this is not the case the registers are loaded on the rising edge of the last CLK signal. Is there a part that TI can recommend that has the capability to use the SPI chip select not line to load the registers?
Thank you,
Matt
