Hi !
We have done a set of tests of the evalboard, especially to see the spurious levels. We noted the presence of spurs around the main signal which are located at Fout%Fosc. Using the register R1 to control the Cal_clk_div parameter, we have seen that if we divided the state machine clock by 2 or 4, the level of those signals can be reduced.
As we are using the Full Assist mode only, we would like to know if there is a way to disable the state machine clock, as we do not use the VCO calibration ? Or maybe you know a way to further reduce the Fout%Fosc spurs ?
Thanks by advance
Stephane
