Tool/software: Linux
Hi
what is the programming procedure for the CDCI6214?
when i follow the section 9.5.1 as per the data sheet(SNAS734 – JULY 2017), not able to observe any clock at he output Channels.
the register are configured with the default values as specified in Table 14 (even tried with EEPROM 0) of the datasheet.
A reference clock to the PLL is fed to pins 1 (XIN) and 2 (XOUT) 25MHz. Pin OE and RST are set to HIGH.
please suggest what are the registers need to check for enabling the output frequency at CDCI6214.
thanks
mahesh muni
