Hello.
I made a device based on C5535.
When running through the XDS-100 debugger, everything is fine.
When running with a flush, the C5535 reads the program code, but then does not work. I draw a conclusion about it by GPIO17 IP-Phone_DSP(2x_Channel)(Ver. 1.00).sch
/** * main.c */ /* ANSI C headers */ #include <stdlib.h> #include <stdio.h> #include <string.h> #include "csl_intc.h" /* System definitions and utilities */ #include <ti/mas/types/types.h> /* AER, DRC, AGC, MSS and BF header files */ #include <ti/mas/aer/aer.h> #include <ti/mas/aer/agc.h> #include <ti/mas/aer/drc.h> #include <ti/mas/aer/mss.h> #include <ti/mas/aer/bf.h> #include "device.h" /* AER simulation constants and data structures */ #include <ti/mas/aer/test/aersim/aersim.h> #include <ti/mas/aer/test/aersim/aerbuffs.h> /* SIU simulation header files */ #include <ti/mas/aer/test/siusim/siu.h> #include <ti/mas/aer/test/siusim/siuloc.h> #include <ti/mas/aer/test/siusim/siuaer.h> #include <ti/mas/aer/test/siusim/siubf.h> #include <ti/mas/aer/test/piusim/piuloc.h> #define AER_SIM_PEAK_MIPS_ERLE_THRESH 10 #define AER_SIM_DURATION_CONVERGED 3000 /* Run 30 seconds after converged */ /* Global structures for AER simulation */ siuSetup_t siuSetup; /* simulation setup/configuration structure */ siuInst_t siu_inst; /* system integration unit (SIU) instance structure */ piuInst_t piu_inst; /* PCM interface unit (PIU) instance structure */ aepSimInst_t aepSimInst; /* Acoustic echo path (AEP) simulator structure */ //aersimFileIO_t aersim_fio; /* File I/O structure */ //sgnInstBuf_t sgnTxInst[AER_SIM_NUM_MIC]; /* Signal Generator (SGN) for Tx path (Near End) */ //sgnInstBuf_t sgnRxInst; /* Signal Generator (SGN) for Rx path (Far End) */ /* Input and output buffers for AER simulation */ //linSample sim_data_rx_in [SIU_AER_MAX_FRAME_LENGTH]; linSample sim_data_rx_out [SIU_AER_MAX_FRAME_LENGTH]; linSample sim_data_dac [SIU_AER_MAX_FRAME_LENGTH]; /* signal to D/A */ linSample sim_data_rx_sync [SIU_AER_MAX_FRAME_LENGTH]; /* reference signal */ linSample sim_data_ne_speech[AER_SIM_NUM_MIC][SIU_AER_MAX_FRAME_LENGTH]; linSample sim_data_mic [AER_SIM_NUM_MIC][SIU_AER_MAX_FRAME_LENGTH]; linSample sim_data_tx_in [AER_SIM_NUM_MIC][SIU_AER_MAX_FRAME_LENGTH]; linSample sim_data_tx_out [SIU_AER_MAX_FRAME_LENGTH]; #pragma DATA_ALIGN(bf_null, 4); linSample bf_null[AER_SIM_NUM_MIC][SIU_AER_MAX_FRAME_LENGTH]; /* Buffers for loading or reading AER tail model coefficients */ #define NUM_H_VEC_GET 3 #define NUM_H_VEC_PUT 3 Fract aer_coef_mant[aer_NUM_WORDS_PER_H_VEC_16K*NUM_H_VEC_PUT]; tint aer_coef_exp[NUM_H_VEC_PUT]; aerTailModel_t aer_tail_model; /* Buffers for reading BF filter coefficients */ Fract bf_filt_coef[AER_SIM_NUM_BF_MIC][bf_MAX_SUPPORTED_FILT_LEN]; tint bf_filt_len; /* Prototypes of the funtions only referenced in this file */ //tbool aer_sim_fio_read_fe(aersimFileIO_t *fio, linSample *data_fe); //tbool aer_sim_fio_read_ne(aersimFileIO_t *fio, // linSample data_ne[][SIU_AER_MAX_FRAME_LENGTH],tint num_input); //void aer_sim_fio_write_data(aersimFileIO_t *fio); tint aer_sim_get_erle(siuInst_t *inst); void aer_sim_print_version_mips(siuInst_t *inst); void aer_sim_cfg_on_the_fly(siuInst_t *inst); /* global variables for debugging purpose - to set conditional breakpoint */ Uint32 frm_cnt = 0; int my_frm_cnt = 0; int num_frames_converged = 0; /****************************************************************************** * FUNCTION PURPOSE: Get ERLE Measurement form AER *****************************************************************************/ tint aer_sim_get_erle(siuInst_t *inst) { aerDebugStat_t aer_dbg; aerVersion_t aer_ver; /* get ERLE from the first mic */ aerGetPerformance(inst->aerHFInst[0], &aer_dbg, &aer_ver, FALSE); return(aer_dbg.max_canc_l2); } /* aer_sim_get_erle */ /****************************************************************************** * FUNCTION PURPOSE: Simulate real time on-the-fly configuration/control of AER. *****************************************************************************/ void aer_sim_cfg_on_the_fly(siuInst_t *inst) { int i; tint num_coeff_words, ret_code; /* Control AER: First, stop the program and change toggle_aer to TRUE. */ if (siuSetup.toggle_aer) { /* --> break point can be set here to stop the code */ /* Second, change aerCtl in Code Composer watch window to configure AER. */ for(i=0; i<inst->phone_sys.num_HF_mic; i++){ aerControl (inst->aerHFInst[i], (aerControl_t *)&siuSetup.aerCtl); } siuSetup.toggle_aer = FALSE; } /* Control AGC: First, stop the program and change toggle_agc to TRUE. */ if (siuSetup.toggle_agc) { /* --> break point can be set here to stop the code */ /* Second, change agcCtl in Code Composer watch window to configure AGC. */ for(i=0; i<inst->phone_sys.num_HF_mic; i++){ agcControl (inst->agcHFInst[i], (agcControl_t *)&siuSetup.agcCtl); } siuSetup.toggle_agc = FALSE; } /* Change SIU gains: follow same procedure as above */ if (siuSetup.toggle_siugain) { for(i=0; i<inst->phone_sys.num_HF_mic; i++){ siuGainControl (inst->agcHFhandles[i], (siuGainControl_t *)&siuSetup.siuGainCtl); } siuSetup.toggle_siugain = FALSE; } /* Read tail model filter from AER */ if (siuSetup.toggle_getflt) { if(siuSetup.aer_kernel_srate == AER_SIM_SRATE_16000_DIV_8K) { num_coeff_words = aer_NUM_WORDS_PER_H_VEC_16K*NUM_H_VEC_GET; } else { num_coeff_words = aer_NUM_WORDS_PER_H_VEC_8K*NUM_H_VEC_GET; } ret_code = aerGetFilter(inst->aerHFInst[0], &aer_tail_model, &aer_coef_mant[0], &aer_coef_exp[0], 0, num_coeff_words); if(ret_code != aer_NOERR) { //printf("Error when calling aerGetFilter with error code %d!\n", ret_code); exit(0); } for(i=0; i<siuSetup.system_cfg.num_BF_mic; i++) { ret_code = bfGetFilter(inst->bfInst, &bf_filt_coef[i][0], &bf_filt_len, bf_FG_BF, i); if(ret_code != bf_NOERR) { //printf("Error when calling bfGetFilter with error code %d!\n", ret_code); exit(0); } } siuSetup.toggle_getflt = FALSE; } /* pre-load AER tail model filter */ if (siuSetup.toggle_putflt) { if(siuSetup.aer_kernel_srate == AER_SIM_SRATE_16000_DIV_8K) { num_coeff_words = aer_NUM_WORDS_PER_H_VEC_16K*NUM_H_VEC_PUT; } else { num_coeff_words = aer_NUM_WORDS_PER_H_VEC_8K*NUM_H_VEC_PUT; } /* load valid tail model through CCS before executing code below */ ret_code = aerPutFilter(inst->aerHFInst[0], &aer_tail_model, &aer_coef_mant[0], &aer_coef_exp[0], 0, aer_NUM_WORDS_PER_H_VEC_16K, FALSE); if(ret_code != aer_NOERR) { //printf("Error when calling aerPutFilter with error code %d!\n", ret_code); exit(0); } ret_code = aerPutFilter(inst->aerHFInst[0], &aer_tail_model, &aer_coef_mant[aer_NUM_WORDS_PER_H_VEC_16K], &aer_coef_exp[0], aer_NUM_WORDS_PER_H_VEC_16K, aer_NUM_WORDS_PER_H_VEC_16K, FALSE); if(ret_code != aer_NOERR) { //printf("Error when calling aerPutFilter with error code %d!\n", ret_code); exit(0); } ret_code = aerPutFilter(inst->aerHFInst[0], &aer_tail_model, &aer_coef_mant[aer_NUM_WORDS_PER_H_VEC_16K*2], &aer_coef_exp[0], aer_NUM_WORDS_PER_H_VEC_16K*2, aer_NUM_WORDS_PER_H_VEC_16K, TRUE); if(ret_code != aer_NOERR) { //printf("Error when calling aerPutFilter with error code %d!\n", ret_code); exit(0); } siuSetup.toggle_putflt = FALSE; } /* code below can be used to test adaptive AGC if(frm_cnt == 1000) { siuSetup.agcCtl.valid_bitfield = agc_CTL_VALID_SAT_THRESHOLD; siuSetup.agcCtl.sat_threshold = 1024; agcControl (inst->agcHFInst[0], (agcControl_t *)&siuSetup.agcCtl); printf("Start filter rescaling test. Reduce AGC saturation threshold.\n"); } if(frm_cnt == 2000) { siuSetup.agcCtl.valid_bitfield = agc_CTL_VALID_SAT_THRESHOLD; siuSetup.agcCtl.sat_threshold = 32500; agcControl (inst->agcHFInst[0], (agcControl_t *)&siuSetup.agcCtl); printf("Change AGC saturation threshold back to what it was.\n"); } */ } /* aer_sim_cfg_on_the_fly */ /****************************************************************************** * FUNCTION PURPOSE: Print AER version number and measured MIPS. *****************************************************************************/ void aer_sim_print_version_mips(siuInst_t *inst) { aerDebugStat_t aer_dbg; aerVersion_t aer_ver; aerGetPerformance(inst->aerHFInst[0], &aer_dbg, &aer_ver, FALSE); //printf("AER version: %d.%d.%d.%d.%d.%d\n", aer_ver.major, aer_ver.minor, // aer_ver.patch, aer_ver.build, aer_ver.quality, aer_ver.btype); if(siuSetup.aer_mips_profile) { #ifdef ti_targets_C55_large //printf("C55x: AER Tx Max Cycles = %ld, Avg Cycles = %ld\n", // siuSetup.TxCyclesMax, siuSetup.TxCyclesAvg); //printf("C55x: AER Rx Max Cycles = %ld, Avg Cycles = %ld\n", // siuSetup.RxCyclesMax, siuSetup.RxCyclesAvg); #else #ifndef gnu_targets_arm_GCArmv7A/* c64x+ */ printf("C64x+/C674x: AER Tx Max Cycles = %d, Avg Cycles = %d\n", siuSetup.TxCyclesMax, siuSetup.TxCyclesAvg); printf("C64x+/C674x: AER Rx Max Cycles = %d, Avg Cycles = %d\n", siuSetup.RxCyclesMax, siuSetup.RxCyclesAvg); #endif #endif //printf("MIPS measurement done\n"); } } /* aer_sim_print_version_mips */ CSL_IRQ_Dispatch dispatchTable; /////////////////////////////////////////////////////////////////////////////// /* -------------------- MAIN SIMULATION FUNCTION --------------------------- */ ///////////////////////////////////////////////////////////////////////////// int main() { tint num_mic, mic_type; DeviceInit(); DeviceStart(); aer_sim_init(&siuSetup); aer_sim_get_cfg(&siuSetup); mic_type = siuSetup.system_cfg.mult_mic_type; if(mic_type == AER_SIM_MIC_TYPE_ARRAY) { num_mic = siuSetup.system_cfg.num_BF_mic; } else { num_mic = siuSetup.system_cfg.num_HF_mic; } aer_sim_apply_config(&siuSetup); aer_sim_init_siu(&siu_inst, &siuSetup); aer_sim_init_piu(&piu_inst, &siuSetup); aer_sim_instantiate_aer(&siu_inst, &siuSetup); aer_sim_open_aep(&aepSimInst, &siuSetup); aer_sim_config_aer_params(&siu_inst, &siuSetup); aer_sim_aep_config(&aepSimInst, &siuSetup.aep_params, siuSetup.aep_gain_adj_exp, siuSetup.aep_gain_adj_mant); //aerControl_t aer_ctl; //***** LOOP **** loop { if(flagUART_RX){ flagUART_RX = 0; UART_params_apply(); } aer_sim_cfg_on_the_fly(&siu_inst); frm_cnt++; if(frm_cnt ==50000) GPIO_write(hGpio17, CSL_GPIO_PIN14, 1); if(frm_cnt ==100000){ GPIO_write(hGpio17, CSL_GPIO_PIN14, 0); frm_cnt = 0; } if(F_read_block(fr_bf)) { if(TRUE)//aer_off_music == 0) { siuReceiveIn(&siu_inst, fr_bf, sim_data_rx_out, NULL, siuSetup.system_cfg.num_HF_mic); piuReceiveIn(&piu_inst, sim_data_rx_out, sim_data_dac, sim_data_rx_sync); } switch(spkr_sel) { case 0: spkr_writeL_block(bf_null[0]); //spkr_writeR_block(bf_null[0]); break; case 1: if(aer_off_music) spkr_writeL_block(fr_bf); else spkr_writeL_block(sim_data_dac); break; case 2: /*if(aer_off_music) spkr_writeL_block(fr_bf); else spkr_writeR_block(sim_data_dac);*/ break; } } switch(mic_sel) { case 0: if(mic_readL_block(sim_data_ne_speech[0])) { //��� ��������� ���������, ������ ������� ����� aer_sim_aep_add_echo(&aepSimInst, sim_data_dac, bf_null, sim_data_mic, num_mic, 1); piuSendIn(&piu_inst, sim_data_mic, sim_data_tx_in, num_mic); siuSendIn(&siu_inst, sim_data_rx_sync, sim_data_tx_in, sim_data_tx_out, NULL, num_mic, mic_type, siuSetup.aer_sout_frm_size); F_write_block(sim_data_tx_out); } break; case 1: if(mic_readR_block(sim_data_ne_speech[0])) { //�������� ��������_1 (����� ����� I2S) aer_sim_aep_add_echo(&aepSimInst, sim_data_dac, sim_data_ne_speech, sim_data_mic, num_mic, 1); piuSendIn(&piu_inst, sim_data_mic, sim_data_tx_in, num_mic); siuSendIn(&siu_inst, sim_data_rx_sync, sim_data_tx_in, sim_data_tx_out, NULL, num_mic, mic_type, siuSetup.aer_sout_frm_size); F_write_block(sim_data_tx_out); } break; case 2: if(mic_readL_block(sim_data_ne_speech[0])) { //�������� ��������_2 (������ ����� I2S) aer_sim_aep_add_echo(&aepSimInst, sim_data_dac, sim_data_ne_speech, sim_data_mic, num_mic, 1); piuSendIn(&piu_inst, sim_data_mic, sim_data_tx_in, num_mic); siuSendIn(&siu_inst, sim_data_rx_sync, sim_data_tx_in, sim_data_tx_out, NULL, num_mic, mic_type, siuSetup.aer_sout_frm_size); F_write_block(sim_data_tx_out); } break; } } return(0); } //***************************************************************************** // DeviceInit //***************************************************************************** void DeviceInit() { PLL_Obj pllObj; PLL_Config *configInfo; PLL_Handle hPll; Uint32 pllInstId; int i; Uint16 prcr; CSL_SYSCTRL_REGS->PCGCR1 = 0x0000; CSL_SYSCTRL_REGS->PCGCR2 = 0x0000; IRQ_init(&dispatchTable, 0); IRQ_globalDisable(); IRQ_disableAll(); IRQ_clearAll(); IRQ_setVecs((Uint32)&VECSTART); // Set PLL const PLL_Config pllCfg_100MHz = {0x8C31, 0x0173, 0x0806, 0x0000}; //from 12MHz pllInstId = 0; PLL_init(&pllObj,pllInstId); hPll = &pllObj; PLL_reset(hPll); configInfo = (PLL_Config *)&pllCfg_100MHz; PLL_config(hPll, configInfo); for(i=0;i<100;i++); PLL_enable(hPll); for(i=0;i<100;i++); //Set PinMap CSL_FINST(CSL_SYSCTRL_REGS->EBSR, SYS_EBSR_PPMODE, MODE1); CSL_FINST(CSL_SYSCTRL_REGS->EBSR, SYS_EBSR_SP1MODE, MODE0); CSL_FINST(CSL_SYSCTRL_REGS->EBSR, SYS_EBSR_SP0MODE, MODE1); // Enable HWA, CPU, DPORT, MPORT, XPORT, and IPORT in ICR */ *(volatile ioport Uint16 *)(0x0001) = 0x000E; /* Execute idle instruction */ asm(" idle"); //Enable peripherals CSL_SYSCTRL_REGS->PCGCR1 = 0x1c02; CSL_SYSCTRL_REGS->PCGCR2 = 0x0003; // Reset all peripherals CSL_SYSCTRL_REGS->PSRCR = 0x0020; CSL_SYSCTRL_REGS->PRCR = 0x00BB; do { prcr = CSL_SYSCTRL_REGS->PRCR; } while (prcr != 0); } //--------------------------------------------------------------- void DeviceStart() { int i, a; for(i=0; i<FRAME_LENGTH*2; i++){ bufN_WL[i] = 0; bufN_WR[i] = 0; bufN_RL[i] = 0; bufN_RR[i] = 0; bufF_W[i] = 0; bufF_R[i] = 0; } for(a=0; a<AER_SIM_NUM_MIC; a++) for(i=0; i<SIU_AER_MAX_FRAME_LENGTH; i++) bf_null[a][i] = 0x0; for(i=0; i<100; i++) bufUART[i] = 0; GPIO_init(); GPIO_write(hGpio17, CSL_GPIO_PIN17, 1);// ����� AIC Wait(100000); i2c_init(); Wait(300); UARTinit(); DmaInit(); I2sDmaF_init(); I2sDmaN_init(); i2sF_init(); i2sN_init(); aic_init(); IRQ_globalEnable(); } //**************************************************************************** // GPIO_init(); //**************************************************************************** void GPIO_init() { CSL_Status status; CSL_GpioPinConfig config; // Make Serial port 0 and 1, parallel port's 8 pin and // A15 to A20 pin as GPIO // //CSL_FINST(CSL_SYSCTRL_REGS->EBSR, SYS_EBSR_SP0MODE, MODE2); // Open GPIO module //hGpio12 = GPIO_open(&gpioObj12, &status); //hGpio13 = GPIO_open(&gpioObj13, &status); hGpio14 = GPIO_open(&gpioObj14, &status); //hGpio16 = GPIO_open(&gpioObj16, &status); hGpio17 = GPIO_open(&gpioObj17, &status); // Configure GPIO /* config.pinNum = CSL_GPIO_PIN12; config.direction = CSL_GPIO_DIR_OUTPUT; config.trigger = CSL_GPIO_TRIG_CLEAR_EDGE; GPIO_configBit(hGpio12, &config); config.pinNum = CSL_GPIO_PIN13; config.direction = CSL_GPIO_DIR_OUTPUT; config.trigger = CSL_GPIO_TRIG_CLEAR_EDGE; GPIO_configBit(hGpio13, &config); */ config.pinNum = CSL_GPIO_PIN14; config.direction = CSL_GPIO_DIR_OUTPUT; config.trigger = CSL_GPIO_TRIG_CLEAR_EDGE; GPIO_configBit(hGpio14, &config); /* config.pinNum = CSL_GPIO_PIN16; config.direction = CSL_GPIO_DIR_OUTPUT; config.trigger = CSL_GPIO_TRIG_CLEAR_EDGE; GPIO_configBit(hGpio16, &config); */ config.pinNum = CSL_GPIO_PIN17; config.direction = CSL_GPIO_DIR_OUTPUT; config.trigger = CSL_GPIO_TRIG_CLEAR_EDGE; GPIO_configBit(hGpio17, &config); int i; // Write 1 to output pin // GPIO_write(hGpio12, CSL_GPIO_PIN12, 1); // GPIO_write(hGpio13, CSL_GPIO_PIN13, 1); // GPIO_write(hGpio14, CSL_GPIO_PIN14, 1); // GPIO_write(hGpio16, CSL_GPIO_PIN16, 1);*/ GPIO_write(hGpio17, CSL_GPIO_PIN17, 1); Wait(10000); // GPIO_write(hGpio12, CSL_GPIO_PIN12, 0); // GPIO_write(hGpio13, CSL_GPIO_PIN13, 0); // GPIO_write(hGpio14, CSL_GPIO_PIN14, 0); // GPIO_write(hGpio16, CSL_GPIO_PIN16, 0);*/ GPIO_write(hGpio17, CSL_GPIO_PIN17, 0); Wait(10000); } //***************************************************************************** // DmaInit // Description: Initializes DMA, enables DMA interrupts //***************************************************************************** void DmaInit() { Uint16 ifrValue; IRQ_disable(DMA_EVENT); IRQ_clear(DMA_EVENT); CSL_SYSCTRL_REGS->DMAIER = 0x0000;// Disable DMA interrupts ifrValue = CSL_SYSCTRL_REGS->DMAIFR;// Clear pending DMA interrupts CSL_SYSCTRL_REGS->DMAIFR |= ifrValue; IRQ_plug(DMA_EVENT, &DmaIsr); IRQ_enable(DMA_EVENT); DMA_init(); } //----------------------------------------------------------------------------- //***************************************************************************** // void i2s_init() //**************************************************************************** void i2sN_init() { CSL_I2sHandle hI2sN; I2S_Config hwConfig; // Open the device with instance 2 hI2sN = I2S_open(I2S_INSTANCE2, DMA_INTERRUPT, I2S_CHAN_STEREO); // Set the value for the configure structure hwConfig.dataType = I2S_STEREO_ENABLE; hwConfig.loopBackMode = I2S_LOOPBACK_DISABLE; hwConfig.fsPol = I2S_FSPOL_LOW; hwConfig.clkPol = I2S_RISING_EDGE; hwConfig.datadelay = I2S_DATADELAY_ONEBIT; hwConfig.datapack = I2S_DATAPACK_ENABLE; hwConfig.signext = I2S_SIGNEXT_DISABLE; hwConfig.wordLen = I2S_WORDLEN_16; hwConfig.i2sMode = I2S_SLAVE; hwConfig.FError = I2S_FSERROR_DISABLE; hwConfig.OuError = I2S_OUERROR_DISABLE; hwConfig.clkDiv = I2S_CLKDIV128; hwConfig.dataFormat = I2S_DATAFORMAT_DSP; hwConfig.fsDiv = I2S_FSDIV32; // Configure hardware registers I2S_setup(hI2sN, &hwConfig); I2S_transEnable(hI2sN, TRUE); hI2sN->firstRead = FALSE; } //----------------------------------------------------------------------------- void i2sF_init() { CSL_I2sHandle hI2sF; I2S_Config hwConfig; /* Open the device with instance 2 */ hI2sF = I2S_open(I2S_INSTANCE0, DMA_INTERRUPT, I2S_CHAN_STEREO); /* Set the value for the configure structure */ hwConfig.dataType = I2S_STEREO_ENABLE; hwConfig.loopBackMode = I2S_LOOPBACK_DISABLE; hwConfig.fsPol = I2S_FSPOL_LOW; hwConfig.clkPol = I2S_RISING_EDGE; hwConfig.datadelay = I2S_DATADELAY_ONEBIT; hwConfig.datapack = I2S_DATAPACK_ENABLE; hwConfig.signext = I2S_SIGNEXT_DISABLE; hwConfig.wordLen = I2S_WORDLEN_16; hwConfig.i2sMode = I2S_SLAVE; hwConfig.FError = I2S_FSERROR_ENABLE; hwConfig.OuError = I2S_OUERROR_ENABLE; hwConfig.clkDiv = I2S_CLKDIV16; hwConfig.dataFormat = I2S_DATAFORMAT_DSP; hwConfig.fsDiv = I2S_FSDIV16; /* Configure hardware registers */ I2S_setup(hI2sF, &hwConfig); I2S_transEnable(hI2sF, TRUE); hI2sF->firstRead = FALSE; } //***************************************************************************** // I2sDmaInit // Configures and starts I2S with DMA //***************************************************************************** void I2sDmaN_init() { CSL_DMA_Config dmaConfig; CSL_Status status; // Configure DMA ch4 for I2S write left dmaConfig.pingPongMode = CSL_DMA_PING_PONG_ENABLE; dmaConfig.autoMode = CSL_DMA_AUTORELOAD_ENABLE; dmaConfig.burstLen = CSL_DMA_TXBURST_1WORD; dmaConfig.trigger = CSL_DMA_EVENT_TRIGGER; dmaConfig.dmaEvt = CSL_DMA_EVT_I2S2_TX; dmaConfig.dmaInt = CSL_DMA_INTERRUPT_ENABLE; dmaConfig.chanDir = CSL_DMA_WRITE; dmaConfig.trfType = CSL_DMA_TRANSFER_IO_MEMORY; dmaConfig.dataLen = FRAME_LENGTH*4; // two frames dmaConfig.srcAddr = (Uint32)bufN_WLPi; dmaConfig.destAddr = (Uint32)&CSL_I2S2_REGS->I2STXLT0; dmaNLTxHandle = DMA_open(DMA_NL_CHAN_TX, &dmaObj0,&status); status = DMA_config(dmaNLTxHandle, &dmaConfig); DMA_start (dmaNLTxHandle); /* // Configure DMA ch5 for I2S write right dmaConfig.pingPongMode = CSL_DMA_PING_PONG_ENABLE; dmaConfig.autoMode = CSL_DMA_AUTORELOAD_ENABLE; dmaConfig.burstLen = CSL_DMA_TXBURST_1WORD; dmaConfig.trigger = CSL_DMA_EVENT_TRIGGER; dmaConfig.dmaEvt = CSL_DMA_EVT_I2S2_TX; dmaConfig.dmaInt = CSL_DMA_INTERRUPT_ENABLE; dmaConfig.chanDir = CSL_DMA_WRITE; dmaConfig.trfType = CSL_DMA_TRANSFER_IO_MEMORY; dmaConfig.dataLen = FRAME_LENGTH*4; // two frames dmaConfig.srcAddr = (Uint32)bufN_WRPi; dmaConfig.destAddr = (Uint32)&CSL_I2S2_REGS->I2STXRT0; dmaNRTxHandle = DMA_open(DMA_NR_CHAN_TX, &dmaObj4,&status); status = DMA_config(dmaNRTxHandle, &dmaConfig); DMA_start (dmaNRTxHandle); */ // Configure DMA ch6 for I2S left read dmaConfig.pingPongMode = CSL_DMA_PING_PONG_ENABLE; dmaConfig.autoMode = CSL_DMA_AUTORELOAD_ENABLE; dmaConfig.burstLen = CSL_DMA_TXBURST_1WORD; dmaConfig.trigger = CSL_DMA_EVENT_TRIGGER; dmaConfig.dmaEvt = CSL_DMA_EVT_I2S2_RX; dmaConfig.dmaInt = CSL_DMA_INTERRUPT_ENABLE; dmaConfig.chanDir = CSL_DMA_READ; dmaConfig.trfType = CSL_DMA_TRANSFER_IO_MEMORY; dmaConfig.dataLen = FRAME_LENGTH*4; // two frames dmaConfig.srcAddr = (Uint32)&CSL_I2S2_REGS->I2SRXLT0; dmaConfig.destAddr = (Uint32)bufN_RLPi; dmaNLRxHandle = DMA_open(DMA_NL_CHAN_RX, &dmaObj1,&status); DMA_config(dmaNLRxHandle, &dmaConfig); DMA_start (dmaNLRxHandle); // Configure DMA ch7 for I2S right read dmaConfig.pingPongMode = CSL_DMA_PING_PONG_ENABLE; dmaConfig.autoMode = CSL_DMA_AUTORELOAD_ENABLE; dmaConfig.burstLen = CSL_DMA_TXBURST_1WORD; dmaConfig.trigger = CSL_DMA_EVENT_TRIGGER; dmaConfig.dmaEvt = CSL_DMA_EVT_I2S2_RX; dmaConfig.dmaInt = CSL_DMA_INTERRUPT_ENABLE; dmaConfig.chanDir = CSL_DMA_READ; dmaConfig.trfType = CSL_DMA_TRANSFER_IO_MEMORY; dmaConfig.dataLen = FRAME_LENGTH*4; // two frames dmaConfig.srcAddr = (Uint32)&CSL_I2S2_REGS->I2SRXRT0; dmaConfig.destAddr = (Uint32)bufN_RRPi; dmaNRRxHandle = DMA_open(DMA_NR_CHAN_RX, &dmaObj5,&status); DMA_config(dmaNRRxHandle, &dmaConfig); DMA_start (dmaNRRxHandle); flagN_RLI = 0; flagN_RRI = 0; flagN_WLI = 0; flagN_WRI = 0; } //------------------------------------------------------------------ void I2sDmaF_init() { CSL_DMA_Config dmaConfig; CSL_Status status; // Configure DMA ch0 for I2S write dmaConfig.pingPongMode = CSL_DMA_PING_PONG_ENABLE; dmaConfig.autoMode = CSL_DMA_AUTORELOAD_ENABLE; dmaConfig.burstLen = CSL_DMA_TXBURST_1WORD; dmaConfig.trigger = CSL_DMA_EVENT_TRIGGER; dmaConfig.dmaEvt = CSL_DMA_EVT_I2S0_TX; dmaConfig.dmaInt = CSL_DMA_INTERRUPT_ENABLE; dmaConfig.chanDir = CSL_DMA_WRITE; dmaConfig.trfType = CSL_DMA_TRANSFER_IO_MEMORY; dmaConfig.dataLen = FRAME_LENGTH*4; // two frames dmaConfig.srcAddr = (Uint32)bufF_WPi; dmaConfig.destAddr = (Uint32)&CSL_I2S0_REGS->I2STXLT0; dmaFTxHandle = DMA_open(DMA_F_CHAN_TX, &dmaObj2,&status); status = DMA_config(dmaFTxHandle, &dmaConfig); DMA_start (dmaFTxHandle); // Configure DMA ch2 for I2S read dmaConfig.pingPongMode = CSL_DMA_PING_PONG_ENABLE; dmaConfig.autoMode = CSL_DMA_AUTORELOAD_ENABLE; dmaConfig.burstLen = CSL_DMA_TXBURST_1WORD; dmaConfig.trigger = CSL_DMA_EVENT_TRIGGER; dmaConfig.dmaEvt = CSL_DMA_EVT_I2S0_RX; dmaConfig.dmaInt = CSL_DMA_INTERRUPT_ENABLE; dmaConfig.chanDir = CSL_DMA_READ; dmaConfig.trfType = CSL_DMA_TRANSFER_IO_MEMORY; dmaConfig.dataLen = FRAME_LENGTH*4; // two frames dmaConfig.srcAddr = (Uint32)&CSL_I2S0_REGS->I2SRXLT0; dmaConfig.destAddr = (Uint32)bufF_RPi; dmaFRxHandle = DMA_open(DMA_F_CHAN_RX, &dmaObj3,&status); DMA_config(dmaFRxHandle, &dmaConfig); DMA_start (dmaFRxHandle); flagF_RI = 0; flagF_WI = 0; } //------------------------------------------------------------------ //***************************************************************** // Iterupt DMA //***************************************************************** interrupt void DmaIsr(void) { CSL_Status status; volatile Uint16 ifrValue; Uint16 gp; // Clear the DMA interrupt ifrValue = CSL_SYSCTRL_REGS->DMAIFR; CSL_SYSCTRL_REGS->DMAIFR |= ifrValue; //Ch 0 Write to ������� ����� if (ifrValue & (1<<0)){ flagF_WI = 1; if(DMA_getLastTransferType (dmaFTxHandle, &status)){ flagF_WPP = 0; } else{ flagF_WPP = 1; } } //Ch 2 Read from ������� ����� if (ifrValue & (1<<2)){ flagF_RI = 1; if(DMA_getLastTransferType (dmaFRxHandle, &status)){ flagF_RPP = 0; } else{ flagF_RPP = 1; } } //Ch 4 Write to left SPKR if (ifrValue & (1<<4)){ flagN_WLI = 1; if(DMA_getLastTransferType (dmaNLTxHandle, &status)){ flagN_WLPP = 0; } else{ flagN_WLPP = 1; } } /* //Ch 5 Write to right SPKR if (ifrValue & (1<<5)){ flagN_WRI = 1; if(DMA_getLastTransferType (dmaNRTxHandle, &status)){ flagN_WRPP = 0; } else{ flagN_WRPP = 1; } } */ //Ch 6 Read from left MIC if (ifrValue & (1<<6)){ flagN_RLI = 1; if(DMA_getLastTransferType (dmaNLRxHandle, &status)){ flagN_RLPP = 0; } else{ flagN_RLPP = 1; } } //Ch 7 Read from right MIC if (ifrValue & (1<<6)){ flagN_RRI = 1; if(DMA_getLastTransferType (dmaNRRxHandle, &status)){ flagN_RRPP = 0; } else{ flagN_RRPP = 1; } } } //------------------------------------------------------------------------------- Bool mic_readL_block(int* buffer) { int i; Uint32* bL = (Uint32*)buffer; Uint32* dma; if(flagN_RLI) flagN_RLI = 0; else return FALSE; if(flagN_RLPP == 1){ dma = (Uint32*)(&bufN_RL[0]); for (i = 0; i < FRAME_LENGTH/2; i++) *bL++ = *dma++; } else{ dma = (Uint32*)(&bufN_RL[FRAME_LENGTH]); for (i = 0; i < FRAME_LENGTH/2; i++) *bL++ = *dma++; } return TRUE; } //------------------------------------------------------------------ Bool mic_readR_block(int* buffer) { int i; Uint32* bL = (Uint32*)buffer; Uint32* dma; if(flagN_RRI) flagN_RRI = 0; else return FALSE; if(flagN_RRPP == 1){ dma = (Uint32*)(&bufN_RR[0]); for (i = 0; i < FRAME_LENGTH/2; i++) *bL++ = *dma++; } else{ dma = (Uint32*)(&bufN_RR[FRAME_LENGTH]); for (i = 0; i < FRAME_LENGTH/2; i++) *bL++ = *dma++; } return TRUE; } //------------------------------------------------------------------ Bool spkr_writeL_block(int* buffer) { int i; Uint32* bL = (Uint32*)buffer; Uint32* dma; //while(flagN_WI == 0); //flagN_WI = 0; if(flagN_WLI) flagN_WLI = 0; else return FALSE; if(flagN_WLPP == 1){ dma = (Uint32*)(&bufN_WL[0]); for (i = 0; i < FRAME_LENGTH/2; i++) *dma++ = *bL++; } else { dma = (Uint32*)(&bufN_WL[FRAME_LENGTH]); for (i = 0; i < FRAME_LENGTH/2; i++) *dma++ = *bL++; } return TRUE; } //------------------------------------------------------------------------- Bool spkr_writeR_block(int* buffer) { int i; Uint32* bL = (Uint32*)buffer; Uint32* dma; //while(flagN_WI == 0); //flagN_WI = 0; if(flagN_WRI) flagN_WRI = 0; else return FALSE; if(flagN_WRPP == 1){ dma = (Uint32*)(&bufN_WR[0]); for (i = 0; i < FRAME_LENGTH/2; i++) *dma++ = *bL++; } else { dma = (Uint32*)(&bufN_WR[FRAME_LENGTH]); for (i = 0; i < FRAME_LENGTH/2; i++) *dma++ = *bL++; } return TRUE; } //------------------------------------------------------------------------- Bool F_read_block(int* buffer) { int i; Uint32* bL = (Uint32*)buffer; Uint32* dma; //while(flagF_RI == 0); //flagF_RI = 0; if(flagF_RI) flagF_RI = 0; else return FALSE; if(flagF_RPP == 1){ dma = (Uint32*)(&bufF_R[0]); for (i = 0; i < FRAME_LENGTH/2; i++) *bL++ = *dma++; } else{ dma = (Uint32*)(&bufF_R[FRAME_LENGTH]); for (i = 0; i < FRAME_LENGTH/2; i++) *bL++ = *dma++; } return TRUE; } //------------------------------------------------------------------ Bool F_write_block(int* buffer) { int i; Uint32* bL = (Uint32*)buffer; Uint32* dma; //while(flagF_WI == 0); //flagF_WI = 0; if(flagF_WI) flagF_WI = 0; else return FALSE; if(flagF_WPP == 1){ dma = (Uint32*)(&bufF_W[0]); for (i = 0; i < FRAME_LENGTH/2; i++) *dma++ = *bL++; } else { dma = (Uint32*)(&bufF_W[FRAME_LENGTH]); for (i = 0; i < FRAME_LENGTH/2; i++) *dma++ = *bL++; } return TRUE; } //------------------------------------------------------------------------- //************************************************************************* //I2C Init //************************************************************************* void i2c_init() { volatile Uint16 looper; volatile Uint32 csl_i2c_sys_clk; // Initialize I2C module I2C_init(CSL_I2C0); csl_i2c_sys_clk = GetSysClk()/1000; // Setup I2C module i2cSetup.addrMode = CSL_I2C_ADDR_7BIT; i2cSetup.bitCount = CSL_I2C_BC_8BITS; i2cSetup.loopBack = CSL_I2C_LOOPBACK_DISABLE; i2cSetup.freeMode = CSL_I2C_FREEMODE_DISABLE; i2cSetup.repeatMode = CSL_I2C_REPEATMODE_DISABLE; i2cSetup.ownAddr = CSL_I2C_OWN_ADDR; //sysclk to i2c, before pre-scaling i2cSetup.sysInputClk = csl_i2c_sys_clk/1000u; //actual i2c serial clk i2cSetup.i2cBusFreq = CSL_I2C_BUS_FREQ; startStop = ((CSL_I2C_START) | (CSL_I2C_STOP)); I2C_setup(&i2cSetup); } //----------------------------------------------------------------- Uint32 GetSysClk() { Bool pllRDBypass; Bool pllOutDiv; Uint32 sysClk; Uint16 pllM; Uint16 pllRD; Uint16 pllOD; pllM = CSL_FEXT(CSL_SYSCTRL_REGS->CGCR1, SYS_CGCR1_M); pllRD = CSL_FEXT(CSL_SYSCTRL_REGS->CGCR2, SYS_CGCR2_RDRATIO); pllOD = CSL_FEXT(CSL_SYSCTRL_REGS->CGCR4, SYS_CGCR4_ODRATIO); pllRDBypass = CSL_FEXT(CSL_SYSCTRL_REGS->CGCR2, SYS_CGCR2_RDBYPASS); pllOutDiv = CSL_FEXT(CSL_SYSCTRL_REGS->CGCR4, SYS_CGCR4_OUTDIVEN); sysClk = 12000000u;//12MHz if (0 == pllRDBypass) { sysClk = sysClk/(pllRD + 4); } sysClk = (sysClk * (pllM + 4)); if (1 == pllOutDiv) { sysClk = sysClk/(pllOD + 1); } // Return the value of system clock in KHz return(sysClk); } //------------------------------------------------------------------------- //************************************************************************* // AIC Init //************************************************************************ Int16 AIC3204_rget( Uint16 regnum, Uint16* regval ) { Uint16 val[1]; regnum = (regnum & 0x00FF); Uint16 startStop = ((CSL_I2C_START) | (CSL_I2C_STOP)); I2C_read(val, 1, AIC3204_I2C_ADDR, ®num, 1, TRUE, startStop, CSL_I2C_MAX_TIMEOUT, FALSE); Wait(1000); *regval = val[0]; return val[0]; } //-------------------------------------------------------------------------- void AIC3204_rset( Uint16 regnum, Uint16 regval ) { Uint16 cmd[2]; cmd[0] = (regnum & 0x00FF); // 7-bit Device Register cmd[1] = (regval & 0x00FF); // 8-bit Register Data Uint16 startStop = ((CSL_I2C_START) | (CSL_I2C_STOP)); I2C_write(cmd, 2, AIC3204_I2C_ADDR, TRUE, startStop, CSL_I2C_MAX_TIMEOUT); Wait(1000); } //**************************************************************************** //AIC init //**************************************************************************** void aic_init() { Uint16 regval = 0; // Configure AIC3204 AIC3204_rset( 0, 0x00 ); // Select page 0 AIC3204_rset( 1, 0x01 ); // Reset codec Wait(1000); // Wait 1ms after reset AIC3204_rset( 0, 0x01 ); // Select page 1 AIC3204_rset( 1, 0x08 ); // Disable crude AVDD generation from DVDD AIC3204_rset( 2, 0x01 ); // Enable Analog Blocks, use LDO power AIC3204_rset( 123,0x05 ); // Force reference to power up in 40ms Wait(50000); // Wait at least 40ms AIC3204_rset( 0, 0x00 ); // Select page 0 // PLL and Clocks config and Power Up if(AIC_SAMPLE_SIZE == 32) AIC3204_rset( 27, 0x3d ); // BCLK and WCLK are set as o/p; AIC3204(Master); 32-bit sample else AIC3204_rset( 27, 0x0d ); // BCLK and WCLK are set as o/p; AIC3204(Master); 16-bit sample AIC3204_rget(27, ®val); AIC3204_rset( 28, 0x00 ); // Data ofset = 0 //Reg.4 �������� 3 - clock ������ ������� (MCLK=12���), �� ���� �������� PLLCLK ���������� �� PLL. For MASTER AIC3204_rset( 4, 0x03 ); // PLL setting: PLLCLK <- MCLK, CODEC_CLKIN <-PLL CLK. AIC3204_rget(4, ®val); //Reg.4 �������� 7 - clock ������� �� I2S (BCLK=32���), �� ���� �������� PLLCLK ��������� �� PLL. For SLAVE //AIC3204_rset( 4, 0x07 ); // PLL setting: PLLCLK <- BCLK, CODEC_CLKIN <-PLL CLK. //������������� PLL = 7,168. ����� ������� ������� CODEC_CLK = BCLK*PLL = 1,024��� * 48 * 2 = 98.304.000 For SLAVE /*AIC3204_rset( 5, 0x92 ); // PLL setting: Power up PLL, P=1 and R=2 AIC3204_rset( 6, 0x30 ); // PLL setting: J=48 AIC3204_rset( 7, 0x00 ); // PLL setting: HI_BYTE(D=0) AIC3204_rset( 8, 0x00 ); // PLL setting: LO_BYTE(D=0)*/ AIC3204_rset( 30, 0x88 ); // For 32 bit clocks per frame in Master mode ONLY // BCLK=DAC_CLK/N =(12288000/8) = 1.536MHz = 32*fs Wait(10000); // Wait for PLL to come up /* // For MASTER // 32��� (16bit) //������������� PLL = 7,168. ����� ������� ������� CODEC_CLK = MCLK*PLL = 12��� * 7,168 = 86.016.000 For MASTER AIC3204_rset( 5, 0x91 ); // PLL setting: Power up PLL, P=1 and R=1 AIC3204_rset( 6, 0x07 ); // PLL setting: J=7 AIC3204_rset( 7, 0x06 ); // PLL setting: HI_BYTE(D=1680) AIC3204_rset( 8, 0x90 ); // PLL setting: LO_BYTE(D=1680) //��������� DOSR, NDAC, MADC ��� ����� FS(32���) ��������� �� CODEC_CLK (FS*DOSR*MDAC*NDAC = CODEC_CLK) For MASTER //CODEC_CLK = MCLK*PLL = 12��� * 7,168 = 86.016.000 = 32��� * 192 * 7 * 2 //��������� ������ � �������� NDAC � NADC ������ �� ����������� ������� ������ (���. 76) AIC3204_rset( 13, 0x00 ); // Hi_Byte(DOSR) for DOSR = 192 decimal or 0x00�0 DAC oversamppling AIC3204_rset( 14, 0xC0 ); // Lo_Byte(DOSR) for DOSR = 192 decimal or 0x00�0 AIC3204_rset( 20, 0x80 ); // AOSR for AOSR = 128 decimal or 0x0080 for decimation filters 1 to 6 AIC3204_rset( 11, 0x82 ); // Power up NDAC and set NDAC value to 2 (32���) AIC3204_rset( 12, 0x87 ); // Power up MDAC and set MDAC value to 7 AIC3204_rset( 18, 0x87 ); // Power up NADC and set NADC value to 7 AIC3204_rset( 19, 0x82 ); // Power up MADC and set MADC value to 2 (32���) // 24��� (16bit) //CODEC_CLK = MCLK*PLL = 12��� * 7,168 = 86.016.000 = 24��� * 128 * 7 * 4 AIC3204_rset( 13, 0x00 ); // Hi_Byte(DOSR) for DOSR = 128 decimal or 0x00�0 DAC oversamppling AIC3204_rset( 14, 0x80 ); // Lo_Byte(DOSR) for DOSR = 128 decimal or 0x00�0 AIC3204_rset( 20, 0x80 ); // AOSR for AOSR = 128 decimal or 0x0080 for decimation filters 1 to 6 AIC3204_rset( 11, 0x84 ); // Power up NDAC and set NDAC value to 4 (24���,16bit) AIC3204_rset( 12, 0x87 ); // Power up MDAC and set MDAC value to 7 AIC3204_rset( 18, 0x87 ); // Power up NADC and set NADC value to 7 AIC3204_rset( 19, 0x84 ); // Power up MADC and set MADC value to 4 (24���,16bit) */ // 22��� (16bit) //������������� PLL = 7,168. ����� ������� ������� CODEC_CLK = MCLK*PLL = 12��� * 7,168 = 86.016.000 For MASTER AIC3204_rset( 5, 0x91 ); // PLL setting: Power up PLL, P=1 and R=1 AIC3204_rset( 6, 0x07 ); // PLL setting: J=7 AIC3204_rset( 7, 0x02 ); // PLL setting: HI_BYTE(D=0560) AIC3204_rset( 8, 0x30 ); // PLL setting: LO_BYTE(D=0560) //CODEC_CLK = MCLK*PLL = 12��� * 7,056 = 86.016.000 = 22,05��� * 192 * 5 * 4 AIC3204_rset( 13, 0x00 ); // Hi_Byte(DOSR) for DOSR = 192 decimal or 0x00�0 DAC oversamppling AIC3204_rset( 14, 0xC0 ); // Lo_Byte(DOSR) for DOSR = 192 decimal or 0x00�0 AIC3204_rset( 20, 0x80 ); // AOSR for AOSR = 128 decimal or 0x0080 for decimation filters 1 to 6 AIC3204_rset( 11, 0x84 ); // Power up NDAC and set NDAC value to 4 (24���,16bit) AIC3204_rset( 12, 0x85 ); // Power up MDAC and set MDAC value to 7 AIC3204_rset( 18, 0x85 ); // Power up NADC and set NADC value to 7 AIC3204_rset( 19, 0x84 ); // Power up MADC and set MADC value to 4 (24���,16bit) // For SLAVE // 32��� (16bit) //���������� DOSR, NDAC, MADC ��� ����� FS(32���) ��������� �� CODEC_CLK (FS*DOSR*MDAC*NDAC = CODEC_CLK) //CODEC_CLK = BCLK*PLL = (32���*32) * (48,0 * 2) = 98.304.000 = 32��� * 128 * 8 * 3 //��������� ������ � �������� NDAC � NADC ������ �� ����������� ������� ������ (���. 76) /* AIC3204_rset( 13, 0x00 ); // Hi_Byte(DOSR) for DOSR = 128 decimal or 0x0080 DAC oversamppling AIC3204_rset( 14, 0x80 ); // Lo_Byte(DOSR) for DOSR = 128 decimal or 0x0080 AIC3204_rset( 20, 0x80 ); // AOSR for AOSR = 128 decimal or 0x0080 for decimation filters 1 to 6 AIC3204_rset( 11, 0x83 ); // Power up NDAC and set NDAC value to 3 AIC3204_rset( 12, 0x88 ); // Power up MDAC and set MDAC value to 8 AIC3204_rset( 18, 0x88 ); // Power up NADC and set NADC value to 8 AIC3204_rset( 19, 0x83 ); // Power up MADC and set MADC value to 3 */ // DAC ROUTING and Power Up AIC3204_rset( 0, 0x01 ); // Select page 1 AIC3204_rset( 12, 0x08 ); // LDAC AFIR routed to HPL AIC3204_rset( 13, 0x08 ); // RDAC AFIR routed to HPR AIC3204_rset( 0, 0x00 ); // Select page 0 AIC3204_rset( 64, 0x02 ); // Left vol=right vol AIC3204_rset( 65, 0x00 ); // Left DAC gain to 0dB VOL; Right tracks Left AIC3204_rset( 63, 0xd4 ); // Power up left,right data paths and set channel AIC3204_rset( 0, 0x01 ); // Select page 1 AIC3204_rset( 16, 0x00 ); // Unmute HPL , 0dB gain AIC3204_rset( 17, 0x00 ); // Unmute HPR , 0dB gain AIC3204_rset( 9 , 0x30 ); // Power up HPL,HPR Wait(100 ); // Wait // ADC ROUTING and Power Up AIC3204_rset( 0, 0x01 ); // Select page 1 AIC3204_rset( 51, 0x48); // power up MICBIAS with AVDD (0x40)or LDOIN 3.3V (0x78) or 1.2V (0x48)//MM - added micbias AIC3204_rset( 52, 0x0C); //IN3L -> Left Positive, 40k AIC3204_rset( 54, 0x0C); //IN3R -> Left Negative, 40k AIC3204_rset( 55, 0xC0); //IN1R -> Right Positive, 40k AIC3204_rset( 57, 0x30); //IN1L -> Right Negative, 40k /* AIC3204_rset( 52, 0x30 ); // IN2L is routed to Left Positive MICPGA with 40k resistance AIC3204_rset( 54, 0x03 ); // CM is routed to Left Negative MICPGA via CM2L with 40k resistance AIC3204_rset( 55, 0x30 ); // IN2R is routed to Right Positive MICPGA with 40k resistance AIC3204_rset( 57, 0xc0 ); // CM is routed to Right Negative MICPGA via CM1R with 40k resistance */ AIC3204_rset( 59, 48 ); // MIC_PGA_L gaine 24dB AIC3204_rset( 60, 48 ); // MIC_PGA_R gaine 24dB AIC3204_rset( 0, 0x00 ); // Select page 0 AIC3204_rset( 81, 0xc0 ); // Powerup Left and Right ADC AIC3204_rset( 82, 0x00 ); // Unmute Left and Right ADC Wait(100 ); AIC3204_rset( 0, 0x00 ); // Select page 0 AIC3204_rset( 87, 82 ); // Left Noise ����� AIC3204_rset( 95, 82 ); // Right Noise ����� Wait(100 ); // Wait } ///////////////////////////////////////////////////////////////////////// // UART functions ///////////////////////////////////////////////////////////////////////// void UARTinit() { //CSL_UartIsrAddr isrAddr; mySetup.clkInput = GetSysClk(); IRQ_disable(UART_EVENT); IRQ_clear(UART_EVENT); UART_init(&uartObj,CSL_UART_INST_0,UART_INTERRUPT); //SYS_setEBSR(CSL_EBSR_FIELD_PPMODE, CSL_EBSR_PPMODE_1); hUart = (CSL_UartHandle)(&uartObj); UART_setup(hUart,&mySetup); // Configure and Register the UART interrupts //isrAddr.rbiAddr = uart_rxIsr; IRQ_plug (UART_EVENT, &UART_intrDispatch); IRQ_enable(UART_EVENT); //UART_setCallback(hUart,&isrAddr); UART_eventEnable(hUart, CSL_UART_RECVOR_LINE_STATUS_INTERRUPT); UART_eventEnable(hUart, CSL_UART_RECVOR_REG_DATA_INTERRUPT); flagUART_RX = 0; } //-------------------------------------------------------------- tint cmd_count = 0; interrupt void UART_intrDispatch(void) { Uint16 ev = 0; ev = UART_getEventId(hUart); if(ev == 2 || ev == 6) // read and timeout { while(CSL_FEXT(hUart->uartRegs->LSR,UART_LSR_DR)) { bufUART[cmd_count] = CSL_FEXT(hUart->uartRegs->RBR,UART_RBR_DATA); if(cmd_count == 3){ UART_parse(); cmd_count = 0; } else cmd_count++; } } else cmd_count = 0; } //---------------------------------------------------------------------------------- void UART_parse() { Uint16 cmd = bufUART[1]*256+bufUART[0]; switch(cmd) { case beg_spkr_sel: SPKR_SEL = bufUART[3]*256+bufUART[2]; cmd_name = cmdSPKR_SEL; break; case beg_mic_sel: MIC_SEL = bufUART[3]*256+bufUART[2]; cmd_name = cmdMIC_SEL; break; case beg_mic_short: MIC_SHORT = bufUART[3]*256+bufUART[2]; cmd_name = cmdMIC_SHORT; break; case beg_aer_off_music: AER_OFF_MUSIC = bufUART[3]*256+bufUART[2]; cmd_name = cmdAER_OFF_MUSIC; break; } flagUART_RX = 1; } //---------------------------------------------------------------------------------- void UART_params_apply() { switch(cmd_name){ /*case beg_full_pack: aer_sim_config_aer_params(&siu_inst, &siuSetup); aer_sim_aep_config(&aepSimInst, &siuSetup.aep_params, siuSetup.aep_gain_adj_exp, siuSetup.aep_gain_adj_mant); break;*/ case cmdEMPTY: break; case cmdSPKR_SEL: spkr_sel = SPKR_SEL; break; case cmdMIC_SEL: mic_sel = MIC_SEL; switch(MIC_SEL){ case 0: siuSetup.aer_ctl_bitfield_1 = 471; //siuSetup.aer_ctl_bitfield_1 | aer_CTL1_MUTE_ON; break; case 1: siuSetup.aer_ctl_bitfield_1 = 455; //siuSetup.aer_ctl_bitfield_1 & (~aer_CTL1_MUTE_ON); break; case 2: siuSetup.aer_ctl_bitfield_1 = 455; //siuSetup.aer_ctl_bitfield_1 & !aer_CTL1_MUTE_ON; case 3: siuSetup.aer_ctl_bitfield_1 = 455; //siuSetup.aer_ctl_bitfield_1 & !aer_CTL1_MUTE_ON; break; } aer_sim_config_aer_params(&siu_inst, &siuSetup); aer_sim_aep_config(&aepSimInst, &siuSetup.aep_params, siuSetup.aep_gain_adj_exp, siuSetup.aep_gain_adj_mant); break; case cmdMIC_SHORT: flagUART_RX = 0; AIC3204_rset( 0, 0x00 ); // Select page 0 if(MIC_SHORT) { AIC3204_rset( 87, 82 ); // Left Noise ����� -30dB AIC3204_rset( 95, 82 ); // Right Noise ����� -30dB } else { AIC3204_rset( 87, 0 ); // Left Noise ����� OFF AIC3204_rset( 95, 0 ); // Right Noise ����� OFF } break; case cmdAER_OFF_MUSIC: aer_off_music = AER_OFF_MUSIC; /*AIC3204_rset( 0, 0x00 ); // Select page 0 if(aer_off_music == 1){ AIC3204_rset( 14, 0xC0 ); AIC3204_rset( 11, 0x82 ); } else{ AIC3204_rset( 14, 0x80 ); AIC3204_rset( 11, 0x84 ); }*/ Wait(200); break; } }
