Debug Port Unlock on Uniflash 3.1 (and error message)
Other Parts Discussed in Thread: UNIFLASH, LMFLASHPROGRAMMER
Hello all.
We have one doubt regarding this feature on the latest Uniflash release.
Is it possible to Unlock a 129X Tiva device with a XDS100 v2? We can erase the flash with this JTAG device, program the chip and read and write the registers (so the connections are OK), but after a Debug Unlock port, the chip stays the same.
We have tried connecting the TRST port of the JTAG to  the RST pint of the 129 microcontroller as well with the same results.
We can unlock it in uniflash with a ICDI stellaris board.
On the other hand, I also receive this message many times:
Everytime I get the message, we need to exit Uniflash and reset the JTAG board to get it working again.
Why is that? Is it a know bug?
  • Similar experience here. Our biggest issue has been when a third party has added an ICDI-like solution on their board (which we use) and did not properly disable it. This prevented access to the debug port.
    Robert
  • Amit Ashara said:
    Hello PAk,
    I have not used this cable so far. But can you check Device Manager is able to interpret it as a Stellaris ICDI. If not then remove the drivers and instead try to point it to the Stellaris ICDI drivers
    Amit
    Hello Amit, which FTDI device or IC did you use to unlock Tiva devices? We would like to know so we could check the functionality.
    On the other hand Robert,  we would like to provide our tool to our clients to unlock our boards. We don't want to just say that they have to unlock their XXX$$ boards, using a custom made cable to one stellaris. Pretty sad, isn't it
  • Hello PAk,
    I have used the FT2232H which has dual channel (besides the launchpad ICDI). One is used for COM port and another for JTAG
    Amit
  • Amit Ashara said:
    Hello PAk,
    Amit
    Thank you Amit.
    That cable features a FT232H which is basically the same but with just one port. I think the issue is with the configuration on the FT_prog app.
    Could you provide your template file for JTAG?
  • My sadness is in observing the amount of effort expended to avoid standard tools. A side effect of which is to constrain the end user.
    If it's worth this effort, it's probably worth exploring private labelled standard tools, which gains you all the benefits of those tools.
    Robert
    Robert
    Just tell me a "standard tool" that allows you to unlock a Tiva chip, which is not a custom wired launchpad....and I am sold!!
  • J-Link comes to mind. There are others out there I'm sure, but this one has a good reputation and works well for me. We haven't found it necessary to unlock a micro ( cb1 may have) so I can't testify from experience how well that works but the manual mentions it (as quoted earlier).
    Robert
    Your wish - my command, Sir.     Indeed we have - and sadly - that occurred with "vendor assistance/guidance" in our office.   (a past LM3S part)
    Other ARM devices (seem) "from my read of other forums" to be more resistant to such, "lock out."    In some cases the dedication of MCU pins to special, known, "Boot methods/mechanisms" frees one from the agony of "lock-out."   I note that our group has (yet) to experience "lock out" - across 4 ARM vendors' devices - beyond that long past, "vendor assisted" incident.
    Language IS important - I wonder what is really - and completely - intended by, "Lock-Out?"    What is PAk really saying/meaning - via that term?
    Again - the idea of having a client perform such activity - chills this reporter's spine!     (I'd love to read the "exhaustive Risk-Reward analysis/justification.")
    Right tool for the Job - but "lock-out" should be avoided...
    I think we are in general agreement. One case I can think of where this might occur is a general purpose programming board, all the more reason to use standard tools.
    Robert
  • Amit Ashara said:
    Amit Ashara
    Hello PAk,
    Amit
    Thank you Amit.
  • Hello PAk,
    Could you share the xml file for programming?
    Amit
  • Amit Ashara said:
    Hello PAk,
    Amit
    Hello Amit.
    Which xml file are you refering to?
    regards
  • Hello PAk,
    The settings done in the FTprog can be saved as a xml file
    Amit
  • Amit Ashara said:
    Hello PAk,
    Amit
    Hello Amit. That is what I would like you to provide me. Could you send me your xml file setup?
    Thank you
  • Hello PAk,
    I cannot send any programming file on the forum or via PM. You would have to share yours so that I can cross verify and let you know what needs to be changed.
    Amit
