Tool/software: Linux
I have an issue that is similar to this issue that has been raised with no solution.
I've done some of my own research and it appears to be related to this patch which was added to the kernel
So if I revoke this patch the command will then function with triple-sampling. My question is the suggestion in the commit of the patch suggests that the triple-sampling option of the driver has been removed as it never did anything, is this correct? Is triple sampling something that is supported by the chip In which case should we be using a different driver?
Many thanks in advance for your help.
Ben Taylor
