Other Parts Discussed in Thread: TIOL111, TIDA-01335
Hello, Steffen Graf,
We can find to success to run TIDA-010016 demo from your below E2E-guide
by connecting Autosen(AO001). Thank you!
http://e2e.ti.com/support/tools/sim-hw-system-design/f/234/t/814827
Now I am investigating the TIOL111(Tx/Rx) data by connection Autosen(AO001) as IO-Link slave
from above E2E-post writer(U-SK) in the same Team for proper IO-Link Master(TIDA-010016)
behavior understanding.
The below-E2E said like below;
J11 - J14 looks good, if the IO-Link device JS-IOL-T10-EVB is not connected.
Otherwise a response should be visible.
What you see here is the wake up pulse of 80 us length followed by a sequence to
communicate with the device in COM3, COM2 and COM1.
So, our expectation is "wake-up success & then continuing COM1(4.8kbps) serial communication"
Then, we captured TIOL111(Tx/Rx) wave form to analyze (Tx2/Rx2) data on Port1.
But we cannot find expected data in Rx signals for PD,OD communication like below console message.
(Please refer the attached pdf in detail)
Questions:
- Do you have same experience?
- We observed Rx2 signal as 48kbps serial data.
- But we cannot find expected hex-data like below on Rx2.
(data: 0x61 0x75 0x74 0x6f 0x73 0x65 0x6e 0x20 0x67 0x6d 0x62 0x68)
(data: 0x41 0x4f 0x30 0x30 0x31)
We would appreciate if you tell us how to observe Rx-data(IO-Link Slave slave data) as hex for TIDA-010016.
port 0 state changed to 0 port 1 state changed to 0 port 2 state changed to 0 port 3 state changed to 0 port 4 state changed to 0 port 5 state changed to 0 port 6 state changed to 0 port 7 state changed to 0 port 1 state changed to 4 PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x0 port 1 state changed to 5 OD read request on port 1: index 16, subIndex 0, dataLen 12 data: 0x61 0x75 0x74 0x6f 0x73 0x65 0x6e 0x20 0x67 0x6d 0x62 0x68 autosen gmbh device AO001 on port 1 did not detect an object OD read request on port 1: index 18, subIndex 0, dataLen 5 data: 0x41 0x4f 0x30 0x30 0x31 autosen gmbh device AO001 connected on port 1 PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x1 autosen gmbh device AO001 on port 1 detected an object autosen gmbh device AO001 on port 1 did not detect an object autosen gmbh device AO001 on port 1 detected an object autosen gmbh device AO001 on port 1 did not detect an object autosen gmbh device AO001 on port 1 detected an object autosen gmbh device AO001 on port 1 did not detect an object autosen gmbh device AO001 on port 1 detected an object autosen gmbh device AO001 on port 1 did not detect an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x0 autosen gmbh device AO001 on port 1 detected an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x1 autosen gmbh device AO001 on port 1 did not detect an object autosen gmbh device AO001 on port 1 detected an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x0 PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x1 autosen gmbh device AO001 on port 1 did not detect an object autosen gmbh device AO001 on port 1 detected an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x0 PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x1 PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x0 PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x1 PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x0 PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x1 PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x0 autosen gmbh device AO001 on port 1 did not detect an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x1 autosen gmbh device AO001 on port 1 detected an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x0 PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x1 autosen gmbh device AO001 on port 1 did not detect an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x0 autosen gmbh device AO001 on port 1 detected an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x1 autosen gmbh device AO001 on port 1 did not detect an object autosen gmbh device AO001 on port 1 detected an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x0 autosen gmbh device AO001 on port 1 did not detect an object autosen gmbh device AO001 on port 1 detected an object autosen gmbh device AO001 on port 1 did not detect an object autosen gmbh device AO001 on port 1 detected an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x1 autosen gmbh device AO001 on port 1 did not detect an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x0 autosen gmbh device AO001 on port 1 detected an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x1 autosen gmbh device AO001 on port 1 did not detect an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x0 autosen gmbh device AO001 on port 1 detected an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x1 autosen gmbh device AO001 on port 1 did not detect an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x0 autosen gmbh device AO001 on port 1 detected an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x1 PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x0 autosen gmbh device AO001 on port 1 did not detect an object autosen gmbh device AO001 on port 1 detected an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x1 autosen gmbh device AO001 on port 1 did not detect an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x0 autosen gmbh device AO001 on port 1 detected an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x1 PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x0 autosen gmbh device AO001 on port 1 did not detect an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x1 autosen gmbh device AO001 on port 1 detected an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x0 autosen gmbh device AO001 on port 1 did not detect an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 autosen gmbh device AO001 on port 1 detected an object PD in data: 0x1 autosen gmbh device AO001 on port 1 did not detect an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x0 PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x1 autosen gmbh device AO001 on port 1 detected an object autosen gmbh device AO001 on port 1 did not detect an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x0 autosen gmbh device AO001 on port 1 detected an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x1 autosen gmbh device AO001 on port 1 did not detect an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x0 autosen gmbh device AO001 on port 1 detected an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x1 PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x0 autosen gmbh device AO001 on port 1 did not detect an object autosen gmbh device AO001 on port 1 detected an object autosen gmbh device AO001 on port 1 did not detect an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x1 autosen gmbh device AO001 on port 1 detected an object autosen gmbh device AO001 on port 1 did not detect an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x0 PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x1 autosen gmbh device AO001 on port 1 detected an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x0 autosen gmbh device AO001 on port 1 did not detect an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x1 autosen gmbh device AO001 on port 1 detected an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x0 autosen gmbh device AO001 on port 1 did not detect an object autosen gmbh device AO001 on port 1 detected an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x1 PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x0 autosen gmbh device AO001 on port 1 did not detect an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x1 autosen gmbh device AO001 on port 1 detected an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x0 autosen gmbh device AO001 on port 1 did not detect an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 autosen gmbh device AO001 on port 1 detected an object PD in data: 0x1 autosen gmbh device AO001 on port 1 did not detect an object PD indication received on port 1: invalid flag 0x0, in len 1, out len 0 PD in data: 0x0
