Part Number: INA121
Hello:
I have a +15V/-15V power supply. I have read several threads indicating that an OpAmp would only see the supply voltage as delta 30V across the Supply+ and Supply-. It would not be aware of a negative supply per se. However my signal voltage will indeed go negative.
Do I have to connect the Power Supply's (third) common wire in someway to the OpAmp in my circuit? I guessed maybe to the Ref pin of the OpAmp but I need to put a bias voltage on the Ref pin to get the Voutput of the Amp to be positive for the ADC I plan to use.
I am clearly confused on how to wire this all up.
