Hi team,
How much output voltage swing with negative input and VREF1=VREF2=GND is?
Is it stick to GND? For example, IN+ = GND and IN-= 0.2V with VREF1=VREF2=GND, then Vout = GND which is stick to GND, is it correct?
Ochi
Hi team,
Ochi
Yoshiki-san,
Kai's simulations show what you can expect if a negative voltage is applied under these conditions. One thing to note here is that our models are built to exhibit typical behavior. The worst case behavior is also specified in the datasheet for this condition, showing that this voltage present may actually be up to 10mV, but typically is around 1mV as is shown in Kai's simulation.
