Hi support team,
TLC272 is used in PMP10081 and PMP30104.
www.ti.com/.../PMP10081
www.ti.com/.../PMP30104
Is it possible to use TLV9102 instead of TLC272?
Dice-K
because of this really weird C14 you would need to carry out a phase stability analysis first:
Kai
Hi Dice-K,
Kai is correct. After determining from the datasheet if the device meets all of your important specifications, you should build it in either TINA-TI or Pspice and run a stability analysis on it. I recommend taking a look at this video in learning how to run op-amp stability analysis: TI Precision Labs - Op Amps: Stability - Spice simulation | TI.com Video.
Let me know if you have any other questions.
Robert Clifton
