Other Parts Discussed in Thread: TLV3501
Does TI voltage to duty cycle modulator as LTC6992MPS6-1#TRMPBF?
I only can find VFC32, but it voltage to frequency not duty.
LTC6992_1_6992_2_6992_3_6992_4-1270033.pdf
Thanks!
Jeff
Thanks!
Jeff
Hi Jeff,
I assumed that you are looking for voltage to PWM modulator. As you pointed out, VFC32 is Voltage-to-Frequency and Frequency-to-Voltage Converter.
Below is an example and application note in discrete circuit. If you provided us some design requirements, I can direct your inquiry to a proper supporting team. For instance, the following PWM sinewave example is generated via a high speed comparator (TLV3501), which the IC product is not supported by PRAMPS team.
Raymond
