Part Number: OPA855
Other Parts Discussed in Thread: LMH32401
We are using the LMH32401 and are interested in converting the differential output to single-end and driving a 50 ohm load. At the same time we want to cancel the common mode output voltage. The circuit needs to be D.C. coupled. We ran a test with a OPA855 configured as a differential amplifier and using feedback and input resistors of 1k ohms, so the differential gain was 1. The circuit appeared to be stable. The datasheet says a gain of 7V/V for stability. Does 7V/V also apply when configured as a differential amplifier?
Thank you for the help,
David
