Other Parts Discussed in Thread: TINA-TI,
I want to use TI's THS3491 current feedback opamp IC in my own circuit. Normally, I work with LTspice, but I couldn't get the spice model of this IC to work stably in LTspice. Therefore, I'm trying to run the simulation in TINA-TI. I downloaded the TINA-TI reference design for the THS3491 (THS3491RGT TINA-TI Reference Design, SBOMAN3.TSC) from TI's website. If I run it as shown in Figure 1, I can get an output. In my own circuit, there will not be a dual supply, I will power it with only +15V. Therefore, when I remove VEE and connect GND instead, I don't get any output. Could you help me with this? Additionally, when I connect the op-amp's pins to GND instead of VMID, assuming that the VMID voltage is already 0V, I also don't get any output. Why is VMID used? I would appreciate your help with this as well.
