Hi all,
I am currently using this ic in my mini project, but i encounter problem in its output.
I connect the ic as shown in figure below. Then the connection of V+ = 3V from battery, V- = ground from battery, Ref = ground from battery. I left the Vin- and Vin+ open. When i change the Rg value from 1k to 100 ohm, the output Vo doesn't change. Vo maintains at about 1.6 V even though Rg has been changed. Suppose the Vo will change when Rg change. I wonder where the problem occurs.
Thanks.
