OPA4344 / Minimum VCM at the over temperature range
Other Parts Discussed in Thread: OPA4344
Hi All,
Please let me ask about the minimum Common-Mode Voltage Range (VCM) at over temperature.
In the datasheet, the the minimum VCM is specified as -0.3V at only Ta=25degC, not at the over temperature range because it's not in boldface type. (See circled red)
On the other hand, the minimum VCM is -0.3V both Ta=25degC and over temperature range in the condition of CMRR. (See circled blue)
It means that the minimum VCM at the over temperature range is also -0.3V. Is my understanding correct?
Sonoki / Japan Disty
  • Sonoki,
    You are correct that the Input Common-mode Range for OPA4344 should have been shown in bold letter since it is clearly applying across the entire specified temperature range from -40C to 85C - see below:
    Having said that, you must be aware that the input bias current, IB, doubles every 10 deg C (see below a typical graph) so the maximum IB at 85 deg C might be as high as 640pA (10pA*2^6) for Vcm=Vs/2 and twice that with Vcm=(V-) - see the graph of IB vs Vcm below.  This may be important in case of using high magnitude resistor in gain network.
  • Hi Marek,
    Thank you for your response.
    It's OK if the minimum VCMR is still -0.3V at over temperature range. The reason why our customer has cared it is they are using OPA4344 with 5V single supply operation and +IIN is below to 0V, so they concern phase reversal issue will be happened.
    Sonoki
