I need to find the loop gain of the composite amplifier with the THS6022. Since the THS6022 datasheet no figure for open loop gain, I can not know for sure - whether this method of measuring the loop gain. Therefore, to check the I use LMH6629. This is figure open loop gain for the LMH6629:
http://i.imgur.com/3tRugWV.jpg - from datasheet
http://i.imgur.com/K7U8qax.jpg - from e2e.ti.com
http://i.imgur.com/f7q5DHG.png - This way I've found to e2e.ti.com
http://i.imgur.com/iFajpk6.png - Results of this method.
The results are similar to reality, but not equal to the figure from the datasheet.
Could you tell me where the mistake. Maybe there's another way to measure the loop gain for the CFA amplifiers ?
Thanks for answers.
I cannot access any of the document links you have provided.
Please see if you can simply attach it to your E2E post.
Hooman
Here is one way to simulate the stability of the THS6022 (Current Feedback Amplifier) using TINA-TI.
I've "opened the loop" for AC using the large L and the large C. I am looking at the frequency where loop gain (Vout) is 0dB (77MHz) and reading the phase angle (86.3 degrees) to make sure there is enough phase margin (which there is according to these RF and RG values):
Here is the TINA-TI file for the simulation above:
THS6022 CFA (current feedback) Open loop Stabilty E2E Hooman 10_28_15.TSC
BTW, I have not done any verifications of the THS6022 TINA-TI model to make sure it adequately models the inverting input resistance (ri) and inverting input capacitance (Ci) which would surely affect the simulation results.
Hooman
The THS6022 simulated open loop response is Vout / I_inverting, as shown below in the plot labelled "Open_loop":
Here is the new simulation file including open loop gain / phase response of the THS6022:
THS6022 CFA (current feedback) Open loop Gain E2E Hooman 12_28_15.TSC
As you noted, in my previous post I had plotted "loop gain" to check for phase margin. I had shown the phase angle when loop gain is 0dB to be the phase margin.
I'm not sure what you mean by your comment about LT Spice. Please reiterate.
Hooman
