Other Parts Discussed in Thread: DAC5682Z
I want to generate a high DC voltage of 10 volt with power supply of 24 volt.
i want to use this DAC to generate the voltage . can you suggest amplifier which can be used after the DAC904 to generate the 10 volt DC.
As per data-sheet dac904 can generate the 20mA current, if i use the 50 ohms termination then transfered voltage will be 1 volt. so i want to amplify my signal 10 times.
shall i use voltage amplifier or current amplifier for it ?
do you suggest any TI part number ?
