Hello, 3204EVM,USB connected to PC, EVM cannot be connected. What is the reason? Can you help analyze and answer it? Thank you!
Hi Luo,
This problem has been seen before with many different resolutions. First, check the device manager to confirm the USB is recognizing the TI device. If the problem still persists, flashing the EEPROM may resolve the problem as well.
Let me know if this helps,
Thank you for your advice. The problem has been solved. It's the computer's USB drive.
I would like to ask you again whether the chip of TLV320AIC3204, pin 26-LDOin, needs external power supply of 1.9-3.9V to TLV320AIC3204 or external output voltage from TLV320AIC3204.
The board we designed, TLV320AIC3204 pin 26 -LDOIN is not connected to anything (TLV320AIC3204 function normally, microphone and speaker are used normally), will there be any impact?
EVM board, TLV320AIC3204 pin 26 -LDOIN is also not connected to anything (here has been disconnected TLV320AIC3204 pin 26 related power supply), (TLV320AIC3204 function normally, microphone and speaker are in normal use).
Hi Luo,
Yes, LDOIN/HPVDD requires external power supply, this is the supply voltage for the headphone output
