Hi
My KMM customer use TAS5713 and meet the audio output is not stable. sometime is no output.
so they found the register 0x02(ERROR STATUS REGISTER),value is 0x40 (PLL autolock error).
any comment for this issue?
Below is the schematic and I2S waveform.
Hi Eric,
Just re-check the schematic. In order to make sure the signal integration of MCLK, could you remove parallel resistance 10k (PR3), which might produce unbalanced rise and fall times. We recommend adding 50ohm impedance matching resistance, and even RC (50ohm + 10pF).
The requirements of MCLK rise/fall time can be found at https://e2e.ti.com/support/audio/f/6/t/485790?tisearch=e2e-quicksearch&keymatch=TAS57*
Regarding the 0x1A register changing, could you help to provide the PWM waveform based on 0x15?
Rdgs,
Matthew
