Part Number: TAS5614LA
Dear Sirs,
My customer asked us about characteristics of Output Power vs Supply Voltage for TAS5614LA as follows condition.
1.R load:16Ω
2.PBTL
Please let me know above question.
Y.Hasebe
Dear Sirs,
1.R load:16Ω
2.PBTL
Y.Hasebe
Hi Hasebe-san,
I'll see if I can get this data to you.
Robert Clifton
Hello Robert-san,
Thank you for your reply.
I will waiting for your reply.
Y.Hasebe
hello:
I would suggest you can use this formula to run some estimation:
Hello Linda-san,
I have some questions.
1.I think that Rds (on) is the Max value of the TAS5614LA data sheet.
Is this correct?
2.I did not find DCR from the datasheets and other documents.
What is this value?
Y.Hasebe
Hello Hasebe-san,
1. The Rds(on) in the excel file is the max but it would be more accurate to use the typical value to see how much power you can get out of the device.
2. The DCR varies quite a bit depending on the inductor and connector you are using. You can usually find what the DCR of the inductor is from it's datasheet. Same can go for the connector.
Robert Clifton
Hello Robert-san,
I understand your comments.
I will explain them to my customer.
Y.Hasebe
