Other Parts Discussed in Thread: TPL5110, TPL5010
Hello there,
I am looking for an IC, that would act as I2C slave. The master MCU would write to its registers for how long he should hold some pin low/ high. After the time expires, the pin would toggle. In practice, this IC would have to hold the master MCU low for programmed amount of time. I find TPL5100 almost what I was looking for. The problem is that the timing programming is not precise enough. Also, If programmed using I/O, the I/O levels would change after the MCU goes reset by the TPL5100.
I would appreciate all help in finding the proper device.
