I see some disscution for value of the coupling capacitors in page 7 of TI technical application report SCAA056.
If possible to replace legacy AC-coulping from 10nf to 4.7nf FOR LVPECL output to CML 156.25MHz application ?
yes, it is possible to lower the AC coupling cap to 4.7nF.
regards,
Julian
the AC coupling cap and the load forms a high pass filter. With this formula you can calculate/estimate the cut off frequency of that filter. A simple view is that frequencies lower than that cut off frequency will not pass.
f=1/(2πRC)
The estimated cut off frequency should be at least 1/10th of the clock frequency. But I would recommend to use at least 1/100th.
regards,
Julian
