Other Parts Discussed in Thread: LMX2582,
According to the datasheet, under the condition of fVCO = 6.0 GHz, 100 kHz, the PNVCO should be 110.3 dBc/Hz, but the actual measured value is about 120 dBc/Hz; At fVCO = 10.2 GHz, 100 kHz, the PNVCO should be 105 dBc/Hz, but the actual measured value is around 106-110 dBc/Hz.
Could you help suggest is that within the tolerance?
Thanks a lot,
Suri
