TI ClockPro
Other Parts Discussed in Thread: CLOCKPRO, TUSB3410
I am trying to install TI ClockPro (SCAC119d).  It stops when trying to install the driver for the TUSB3410 with the message, "unable to Launch usbinst. "
Please help,
The PC is XP, SP3
I looked for usbinst.exe in Windows\System32 but did not find it.
Please point me to a copy of usbinst.exe that I can downlowd.  archieb@voxtel-9inc.com
I had a working copy of TIClockPro working with a CDCE Programming EVM V1.1
When I came back to use it again the sw was unable to find the board.
an entry for the TD CDCE(L)9xx Programming Evaluation Module (Com11) was present in
Device Manager\Ports (Com & LPT).
I downloaded a new copy of ClockPro and installed it as indicated at the top of this message.
archieb@voxtel-inc.com
  • Hi Archie,
    Not sure if this will work, I attached my TIClockPro/Driver folder here.6825.Driver.zip
  • I clicked on the Setup.exe after extracting the files.  This fails with a message window
    'unable to Launce usbinst"
    this file is found within the TIclockPro files on c: drive
    I have had this failure before.
    So I uninstalled ClockPro and reinstalled from SCAC119d and got the same unable to Launch usbinst message
    I again uninstalled ClockPro and am going to power down and reinstall from SCAC119d
    I am still listening.
    archieb
  • Hello Archie,
    if the solution from my other post does not work, you could try to install this:
    http://e2e.ti.com/cfs-file.ashx/__key/communityserver-discussions-components-files/48/1780.ClockPro-1.2.1.exe
    Julian
  • the file 1780.ClockPro-1.2.1.exe created a new directory in Texas Instruments Inc\ClockPro.1.21 The Sw is copyright 2005
    I uninstalled the driver as found in device manager and reinstalled from the newly loaded files.
    The EVM Programmer window cannot find the Programmer bd.
    I got out a new, not used by me before, Programmer bd and tried that.  the TI ClockPro Programmer could not find the progrmammer EVM V1.1 Digikey Part Number 296-30836-ND
    archieb
