LMK04906 Output Jitter
Guru 16770 points
Other Parts Discussed in Thread: LMK04906, CLOCKDESIGNTOOL
Hi
We have a question about LMK04906 jitter cleaner.
1. According to the datasheet, LMK04906 offers 115-fs RMS jitter (BW=12KHz- 20Mz).
  How to get peak to peak jitter?
2. The 115-fs RMS jitter could be brought in the following condition.
Is there any requirement for input clock to obtain the output realizing 115-fs RMS jitter?
For example, does the jitter on the input clock have the impact with the output as the output jitter?
We want to confirm the input clock codition to satisfy the 115-fs RMS jitter.
BestRegards
    To convert from rms to p2p jitter,  Take a loot at, Choosing Loop Bandwidth for PLLs
    On slide eight I discuss using a multiplication factor to calculate p2p jitter given a specified bit error rate (BER).
    As for input clock jitter, we don't have spec for this, it is application dependent upon loop bandwidth, number of filters, VCXO, etc.  However you can use the clockdesigntool or clock architect to sim.  Here I've...
    • setup clockdesigntool with LMK04906,
    • loaded the 122.88 MHz VCXO profile (CVHD-950-122.880) (also attached for your reference),
    • set a 10 Hz LBW and 50 degree  phase margin filter on PLL1.
    • Entered the loop filter values for PLL2.
    • Entered -20 dBc/Hz flat noise for CLKin.
    • Here you can see the integrated jitter from 12 kHz to 20 MHz is still close to the 115 fs rms spec.  So I don't expect you to have any issues.  If you have the phase noise profile for your input, you could load it.
    • You can see based on the -20 dBc input, at 12 kHz we're attenuating about 100 dB and increasing at about 40 dB/decade.
    cvhd-950-122.88.txt
    10	-76.63970365
    10.18009751	-77.1035666
    10.36343854	-78.99618542
    10.55008148	-79.45995636
    10.74008583	-81.18194675
    10.9335121	-81.64561897
    11.13042193	-80.08189573
    11.33087806	-80.54546206
    11.53494436	-79.28829227
    11.74268583	-79.75174502
    11.95416868	-79.54707269
    12.16946029	-80.01040363
    12.38862924	-80.87629512
    12.61174537	-80.74474401
    12.83887977	-81.20787551
    13.0701048	-81.7978228
    13.30549413	-81.50828992
    13.54512277	-81.97119999
    13.78906706	-81.9697936
    14.03740473	-82.31354592
    14.29021489	-82.77621022
    14.54757811	-83.49889466
    14.80957637	-83.73386291
    15.07629316	-84.19625451
    15.34781344	-84.55539225
    15.62422375	-83.96340479
    15.90561213	-84.41977624
    16.19206824	-84.88175738
    16.48368336	-84.33438408
    16.7805504	-84.02194103
    17.08276394	-84.48699423
    17.39042027	-84.47912816
    17.70361741	-84.94051019
    18.02245515	-84.61532698
    18.34703509	-84.70103502
    18.67746062	-84.6593731
    19.01383704	-85.39165441
    19.35627151	-86.37986356
    19.70487315	-86.34701097
    20.05975301	-87.44612643
    20.42102417	-88.0653141
    20.78880174	-88.95856904
    21.16320288	-88.48030399
    21.5443469	-88.75328205
    21.93235523	-86.76858959
    22.32735149	-86.90325648
    22.72946153	-89.47003826
    23.13881348	-90.4497079
    23.55553775	-90.10064696
    23.97976713	-89.53873743
    24.41163677	-89.62570896
    24.85128427	-90.66021142
    25.29884972	-90.79786567
    25.7544757	-91.49861704
    26.2183074	-91.05489441
    26.6904926	-89.51536251
    27.17118173	-90.19166449
    27.66052795	-90.5115762
    28.15868718	-91.04719161
    28.66581812	-91.64488203
    29.18208238	-91.57911889
    29.70764442	-91.6799143
    30.2426717	-91.44550894
    30.7873347	-91.77205379
    31.34180693	-91.26395455
    31.90626508	-91.66059392
    32.48088897	-94.23211956
    33.0658617	-94.59866183
    33.66136964	-93.91225929
    34.26760253	-94.02315545
    34.88475353	-94.15166802
    35.51301926	-94.63577076
    36.1525999	-94.21517188
    36.80369923	-94.50443337
    37.4665247	-94.99366077
    38.14128748	-95.35002351
    38.82820258	-94.13084728
    39.52748885	-95.19554068
    40.23936909	-95.03772482
    40.96407011	-96.79893545
    41.70182282	-96.90074542
    42.45286227	-96.84290198
    43.21742776	-97.39195224
    43.99576288	-97.062058
    44.78811562	-97.96469749
    45.59473844	-98.74757202
    46.41588834	-100.2094148
    47.25182694	-99.38405151
    48.10282058	-100.1680129
    48.96914041	-99.56306394
    49.85106245	-97.75899112
    50.74886768	-98.78176703
    51.66284216	-100.1037788
    52.59327709	-99.85080624
    53.54046892	-98.95373172
    54.50471945	-101.4214398
    55.48633588	-102.0658049
    56.48563098	-101.6556454
    57.50292314	-101.3016138
    58.53853648	-100.0264737
    59.59280096	-101.6426408
    60.66605248	-101.9537745
    61.75863299	-101.8178371
    62.8708906	-103.4030737
    64.0031797	-103.6288094
    65.15586104	-103.2076613
    66.32930188	-103.7747222
    67.5238761	-103.0697871
    68.73996431	-102.6248446
    69.97795397	-103.4911042
    71.2382395	-103.9611502
    72.52122247	-104.2927976
    73.82731164	-103.6859581
    75.15692316	-103.5961847
    76.51048064	-105.059733
    77.88841536	-105.3858516
    79.29116634	-105.5445756
    80.71918052	-104.6908028
    82.17291288	-106.158339
    83.65282659	-104.8752433
    85.15939318	-107.1925133
    86.69309266	-107.3522392
    88.25441369	-108.4491937
    89.84385372	-108.3245399
    91.46191917	-108.2858663
    93.10912558	-107.6918982
    94.78599777	-108.9644062
    96.49307	-108.1225866
    98.23088618	-108.6458288
    100	-108.8753862
    101.8009751	-109.0750976
    103.6343854	-109.8868235
    105.5008148	-109.6189015
    107.4008583	-111.0123564
    109.335121	-108.9944084
    111.3042193	-109.5276111
    113.3087806	-110.4394415
    115.3494436	-110.0585032
    117.4268583	-110.0145845
    119.5416868	-110.9807198
    121.6946029	-111.1912471
    123.8862924	-110.0922781
    126.1174537	-111.4109111
    128.3887977	-112.5487425
    130.701048	-113.0638209
    133.0549413	-111.5880426
    135.4512277	-111.7350049
    137.8906706	-112.8711608
    140.3740473	-114.2230803
    142.9021489	-113.3914676
    145.4757811	-113.2944961
    148.0957637	-113.7874369
    150.7629316	-114.1374329
    153.4781344	-113.7328946
    156.2422375	-114.2283613
    159.0561213	-113.7857251
    161.9206824	-114.3621877
    164.8368336	-114.7709016
    167.805504	-114.3778328
    170.8276394	-114.4785521
    173.9042027	-115.3411735
    177.0361741	-115.5874785
    180.2245515	-115.8141176
    183.4703509	-116.0345283
    186.7746062	-116.2999632
    190.1383704	-115.0473674
    193.5627151	-116.8387468
    197.0487315	-117.2017466
    200.5975301	-117.2064545
    204.2102417	-117.844455
    207.8880174	-118.0104812
    211.6320288	-118.4669015
    215.443469	-118.546858
    219.3235523	-118.7660581
    223.2735149	-119.3070269
    227.2946153	-119.7187725
    231.3881348	-119.8064038
    235.5553775	-119.9464964
    239.7976713	-120.217782
    244.1163677	-120.4517194
    248.5128427	-120.333514
    252.9884972	-121.6897772
    257.544757	-121.9544289
    262.183074	-121.5917894
    266.904926	-121.5071455
    271.7118173	-121.7559427
    276.6052795	-122.4289656
    281.5868718	-122.1239042
    286.6581812	-122.8987448
    291.8208238	-122.1191395
    297.0764442	-123.0158853
    302.426717	-123.2467713
    307.873347	-123.4102888
    313.4180693	-122.8365114
    319.0626508	-124.5545994
    324.8088897	-124.2346056
    330.658617	-124.3065865
    336.6136964	-124.7331972
    342.6760253	-125.0510853
    348.8475353	-125.0021605
    355.1301926	-125.1095037
    361.525999	-125.3251293
    368.0369923	-125.1236443
    374.665247	-126.1130888
    381.4128748	-126.0456453
    388.2820258	-125.9665117
    395.2748885	-126.670879
    402.3936909	-126.8369682
    409.6407011	-126.545241
    417.0182282	-127.0396344
    424.5286227	-127.2559594
    432.1742776	-127.4016137
    439.9576288	-126.9783726
    447.8811562	-127.8168801
    455.9473844	-128.4612584
    464.1588834	-128.6731919
    472.5182694	-129.0487448
    481.0282058	-128.8553435
    489.6914041	-129.3703533
    498.5106245	-129.1216084
    507.4886768	-129.544986
    516.6284216	-130.5966318
    525.9327709	-130.8634358
    535.4046892	-130.0312698
    545.0471945	-130.2285628
    554.8633588	-130.6566679
    564.8563098	-130.6414489
    575.0292314	-131.1304202
    585.3853648	-131.3291189
    595.9280096	-131.0143556
    606.6605248	-131.1971742
    617.5863299	-131.9888298
    628.708906	-132.2082093
    640.031797	-132.4319928
    651.5586104	-131.960033
    663.2930188	-132.2062477
    675.238761	-132.8387546
    687.3996431	-133.3230506
    699.7795397	-133.5321695
    712.382395	-133.0196294
    725.2122247	-133.2647493
    738.2731164	-134.3456075
    751.5692316	-133.9988004
    765.1048064	-134.6302381
    778.8841536	-134.0696157
    792.9116634	-135.2219793
    807.1918052	-134.8966009
    821.7291288	-135.705863
    836.5282659	-135.0477709
    851.5939318	-135.4939997
    866.9309266	-135.8612611
    882.5441369	-136.0157787
    898.4385372	-132.5013579
    914.6191917	-136.2643313
    931.0912558	-136.4197522
    947.8599777	-136.5161197
    964.9307	-136.3170325
    982.3088618	-136.9548696
    1000	-137.4369178
    1018.009751	-134.6565358
    1036.343854	-137.0507783
    1055.008148	-137.9420455
    1074.008583	-137.0847644
    1093.35121	-137.7523248
    1113.042193	-138.5164382
    1133.087806	-136.9053464
    1153.494436	-138.4342616
    1174.268583	-138.3117258
    1195.416868	-137.495434
    1216.946029	-139.079725
    1238.862924	-138.4356508
    1261.174537	-138.2627948
    1283.887977	-137.7823574
    1307.01048	-138.0619936
    1330.549413	-135.165451
    1354.512277	-138.951229
    1378.906706	-139.4678181
    1403.740473	-139.3229274
    1429.021489	-136.1638687
    1454.757811	-136.9721189
    1480.957637	-140.1880739
    1507.629316	-140.2191884
    1534.781344	-140.2111472
    1562.422375	-137.9470495
    1590.561213	-140.9013367
    1619.206824	-140.8359771
    1648.368336	-140.9050265
    1678.05504	-138.8188179
    1708.276394	-141.2827998
    1739.042027	-141.3848919
    1770.361741	-141.7484992
    1802.245515	-139.3721557
    1834.703509	-141.9869903
    1867.746062	-142.1067039
    1901.383704	-140.4085954
    1935.627151	-140.4456844
    1970.487315	-142.8547907
    2005.975301	-142.9743603
    2042.102417	-141.7568679
    2078.880174	-143.0744409
    2116.320288	-143.2970663
    2154.43469	-142.4933804
    2193.235523	-143.5719166
    2232.735149	-143.8061561
    2272.946153	-142.4926894
    2313.881348	-143.878304
    2355.553775	-144.0141007
    2397.976713	-142.98956
    2441.163677	-144.3491207
    2485.128427	-143.9231188
    2529.884972	-143.7171755
    2575.44757	-145.3291474
    2621.83074	-144.2086245
    2669.04926	-143.6742996
    2717.118173	-145.0990043
    2766.052795	-143.8839587
    2815.868718	-145.3293746
    2866.581812	-143.3604192
    2918.208238	-145.3132106
    2970.764442	-144.8775914
    3024.26717	-144.3122823
    3078.73347	-145.9114636
    3134.180693	-145.158465
    3190.626508	-146.0187601
    3248.088897	-145.3876428
    3306.58617	-146.7652653
    3366.136964	-145.6348747
    3426.760253	-146.2082441
    3488.475353	-145.6377239
    3551.301926	-146.7414688
    3615.25999	-145.9702785
    3680.369923	-147.0198287
    3746.65247	-146.44553
    3814.128748	-146.5063862
    3882.820258	-146.9966336
    3952.748885	-146.9918252
    4023.936909	-147.4420426
    4096.407011	-147.3169818
    4170.182282	-147.3774222
    4245.286227	-147.5057755
    4321.742776	-148.2932069
    4399.576288	-148.0648115
    4478.811562	-148.4891638
    4559.473844	-148.2031664
    4641.588834	-148.3510277
    4725.182694	-148.4527178
    4810.282058	-148.427985
    4896.914041	-148.4439712
    4985.106245	-148.8469819
    5074.886768	-149.0042404
    5166.284216	-148.7052059
    5259.327709	-148.8465082
    5354.046892	-149.5040707
    5450.471945	-149.3800294
    5548.633588	-149.7005598
    5648.563098	-149.2610714
    5750.292314	-149.2921474
    5853.853648	-149.5364546
    5959.280096	-149.5004021
    6066.605248	-148.9236479
    6175.863299	-149.6319401
    6287.08906	-150.283296
    6400.31797	-149.8926681
    6515.586104	-150.1257465
    6632.930188	-150.1449886
    6752.38761	-150.4547192
    6873.996431	-150.4556089
    6997.795397	-150.5915278
    7123.82395	-150.9123273
    7252.122247	-150.9449361
    7382.731164	-150.7403812
    7515.692316	-151.0737967
    7651.048064	-151.4039514
    7788.841536	-151.4371354
    7929.116634	-151.5551057
    8071.918052	-152.2403584
    8217.291288	-152.0397131
    8365.282659	-152.1202887
    8515.939318	-152.314344
    8669.309266	-152.5622289
    8825.441369	-152.3387856
    8984.385372	-152.4361235
    9146.191917	-152.9775468
    9310.912558	-153.7235238
    9478.599777	-153.2584539
    9649.307	-153.4555387
    9823.088618	-151.5100184
    10000	-153.2609095
    10180.09751	-153.3695493
    10363.43854	-152.6470731
    10550.08148	-153.7220494
    10740.08583	-153.90708
    10933.5121	-153.9387996
    11130.42193	-153.8426166
    11330.87806	-153.9495873
    11534.94436	-154.3131946
    11742.68583	-154.3642968
    11954.16868	-154.4670904
    12169.46029	-154.4017251
    12388.62924	-154.6204934
    12611.74537	-154.8002726
    12838.87977	-155.0157223
    13070.1048	-155.0870996
    13305.49413	-155.1383726
    13545.12277	-155.3264262
    13789.06706	-155.9375084
    14037.40473	-155.7537994
    14290.21489	-155.6700015
    14547.57811	-155.8843578
    14809.57637	-155.6478906
    15076.29316	-155.8673974
    15347.81344	-156.0240373
    15624.22375	-156.1779576
    15905.61213	-156.4455198
    16192.06824	-156.6861757
    16483.68336	-156.3236276
    16780.5504	-156.6978004
    17082.76394	-156.5125251
    17390.42027	-156.5687304
    17703.61741	-156.5430839
    18022.45515	-156.6961443
    18347.03509	-157.2752275
    18677.46062	-157.0205817
    19013.83704	-156.6508639
    19356.27151	-157.2102385
    19704.87315	-156.5210844
    20059.75301	-156.8032006
    20421.02417	-157.2879903
    20788.80174	-157.1516644
    21163.20288	-157.3286224
    21544.3469	-157.7029113
    21932.35523	-158.0069461
    22327.35149	-157.96948
    22729.46153	-157.7449918
    23138.81348	-157.8438053
    23555.53775	-157.6712935
    23979.76713	-157.8211479
    24411.63677	-157.9347422
    24851.28427	-158.1921283
    25298.84972	-157.8068491
    25754.4757	-158.3965356
    26218.3074	-158.3918425
    26690.4926	-158.403616
    27171.18173	-158.4244414
    27660.52795	-158.9315647
    28158.68718	-158.7112274
    28665.81812	-158.9367163
    29182.08238	-158.3851672
    29707.64442	-156.8614593
    30242.6717	-157.8722048
    30787.3347	-158.5651214
    31341.80693	-159.0869539
    31906.26508	-158.872029
    32480.88897	-158.5988118
    33065.8617	-158.5918708
    33661.36964	-158.6185082
    34267.60253	-159.2485651
    34884.75353	-159.2659151
    35513.01926	-159.1674551
    36152.5999	-159.4062746
    36803.69923	-160.8398396
    37466.5247	-160.3449069
    38141.28748	-159.6784631
    38828.20258	-160.1138788
    39527.48885	-159.9127335
    40239.36909	-159.8599564
    40964.07011	-160.471244
    41701.82282	-159.9941872
    42452.86227	-160.6227005
    43217.42776	-160.4019006
    43995.76288	-160.2152131
    44788.11562	-160.0673602
    45594.73844	-160.6082409
    46415.88834	-160.5169472
    47251.82694	-161.013602
    48102.82058	-160.9871552
    48969.14041	-161.1621195
    49851.06245	-161.3804381
    50748.86768	-161.0641148
    51662.84216	-160.7616107
    52593.27709	-160.5411966
    53540.46892	-161.2156502
    54504.71945	-161.1777658
    55486.33588	-160.7247927
    56485.63098	-160.8253078
    57502.92314	-160.016793
    58538.53648	-161.0092762
    59592.80096	-161.017366
    60666.05248	-160.6057966
    61758.63299	-161.3500685
    62870.8906	-161.6294239
    64003.1797	-161.4848491
    65155.86104	-162.0798001
    66329.30188	-161.5523474
    67523.8761	-161.0610186
    68739.96431	-160.9776955
    69977.95397	-159.5573726
    71238.2395	-161.3320089
    72521.22247	-161.3935394
    73827.31164	-161.4726916
    75156.92316	-161.5125433
    76510.48064	-160.8069409
    77888.41536	-160.6783905
    79291.16634	-161.3921726
    80719.18052	-162.0780845
    82172.91288	-162.0169126
    83652.82659	-161.9070448
    85159.39318	-162.0661428
    86693.09266	-162.3095042
    88254.41369	-162.2679922
    89843.85372	-162.186954
    91461.91917	-162.0946005
    93109.12558	-162.2031953
    94785.99777	-162.2782285
    96493.07	-161.9009222
    98230.88618	-161.7470633
    100000	-161.9853451
    101800.9751	-162.1404618
    103634.3854	-162.4645102
    105500.8148	-162.8503941
    107400.8583	-162.3349192
    109335.121	-162.4212396
    111304.2193	-162.6255157
    113308.7806	-162.4947405
    115349.4436	-162.6210276
    117426.8583	-162.7467195
    119541.6868	-162.5454136
    121694.6029	-162.855138
    123886.2924	-162.7981438
    126117.4537	-162.5455692
    128388.7977	-162.4187699
    130701.048	-162.7015388
    133054.9413	-162.8345679
    135451.2277	-162.8788934
    137890.6706	-162.9956376
    140374.0473	-162.7020742
    142902.1489	-162.7605475
    145475.7811	-162.9114758
    148095.7637	-163.3050094
    150762.9316	-163.0030065
    153478.1344	-162.9615527
    156242.2375	-162.7341566
    159056.1213	-162.6108082
    161920.6824	-162.8456679
    164836.8336	-163.2107628
    167805.504	-163.3487315
    170827.6394	-163.3286981
    173904.2027	-163.4631713
    177036.1741	-163.2616599
    180224.5515	-162.3754573
    183470.3509	-162.9125747
    186774.6062	-163.4299786
    190138.3704	-163.5474765
    193562.7151	-163.5681349
    197048.7315	-163.3434921
    200597.5301	-163.7756335
    204210.2417	-163.7073627
    207888.0174	-163.3242004
    211632.0288	-163.1812857
    215443.469	-163.4577217
    219323.5523	-163.7103207
    223273.5149	-163.6490033
    227294.6153	-163.7853917
    231388.1348	-163.761199
    235555.3775	-163.5328639
    239797.6713	-163.7786669
    244116.3677	-163.3697806
    248512.8427	-163.9538986
    252988.4972	-163.8456531
    257544.757	-163.6151591
    262183.074	-163.8810996
    266904.926	-163.6134708
    271711.8173	-163.7553294
    276605.2795	-163.9114334
    281586.8718	-164.0351672
    286658.1812	-163.8725973
    291820.8238	-163.9904251
    297076.4442	-163.8232005
    302426.717	-163.6635704
    307873.347	-163.715787
    313418.0693	-163.8963814
    319062.6508	-163.9421715
    324808.8897	-163.8421251
    330658.617	-163.8454868
    336613.6964	-163.9140757
    342676.0253	-163.6391419
    348847.5353	-163.7000098
    355130.1926	-163.793087
    361525.999	-164.1871169
    368036.9923	-164.3420649
    374665.247	-164.2943826
    381412.8748	-164.4306642
    388282.0258	-164.6126775
    395274.8885	-164.4279498
    402393.6909	-164.537407
    409640.7011	-164.7891518
    417018.2282	-164.1492764
    424528.6227	-164.4889135
    432174.2776	-164.3356134
    439957.6288	-164.2428835
    447881.1562	-164.3000555
    455947.3844	-164.7267034
    464158.8834	-164.6343497
    472518.2694	-164.3803888
    481028.2058	-164.616508
    489691.4041	-165.4515957
    498510.6245	-164.4717985
    507488.6768	-164.1512546
    516628.4216	-164.6883639
    525932.7709	-164.5116458
    535404.6892	-164.5609353
    545047.1945	-164.9037055
    554863.3588	-164.639469
    564856.3098	-164.6428794
    575029.2314	-164.8364129
    585385.3648	-164.7301878
    595928.0096	-165.0070694
    606660.5248	-164.7734789
    617586.3299	-164.6425228
    628708.906	-164.9780773
    640031.797	-164.9797209
    651558.6104	-165.1455811
    663293.0188	-165.2602544
    675238.761	-165.2003751
    687399.6431	-165.1223717
    699779.5397	-165.2350609
    712382.395	-165.3891329
    725212.2247	-165.3224791
    738273.1164	-165.3002867
    751569.2316	-165.28298
    765104.8064	-165.4092006
    778884.1536	-165.3081893
    792911.6634	-165.4358895
    807191.8052	-165.3504289
    821729.1288	-165.2632098
    836528.2659	-165.4548442
    851593.9318	-165.5527046
    866930.9266	-165.4557545
    882544.1369	-165.2183534
    898438.5372	-165.4246799
    914619.1917	-165.531338
    931091.2558	-165.4984623
    947859.9777	-165.6089492
    964930.7	-165.8765703
    982308.8618	-165.6944335
    1000000	-165.6936942
    1018009.751	-165.7776223
    1036343.854	-165.8346018
    1055008.148	-165.7798013
    1074008.583	-165.5823271
    1093351.21	-165.4938297
    1113042.193	-165.3877813
    1133087.806	-165.5605267
    1153494.436	-165.4991464
    1174268.583	-165.4403741
    1195416.868	-165.6800102
    1216946.029	-165.767935
    1238862.924	-165.7985029
    1261174.537	-165.6878311
    1283887.977	-165.5853123
    1307010.48	-165.9565289
    1330549.413	-165.8318062
    1354512.277	-165.6699766
    1378906.706	-165.8228466
    1403740.473	-165.9186188
    1429021.489	-165.7589442
    1454757.811	-165.7872554
    1480957.637	-165.6921655
    1507629.316	-165.9516827
    1534781.344	-165.9770271
    1562422.375	-165.8887297
    1590561.213	-165.6775193
    1619206.824	-165.6718163
    1648368.336	-165.809406
    1678055.04	-165.7658772
    1708276.394	-165.8249449
    1739042.027	-165.7068472
    1770361.741	-165.987248
    1802245.515	-165.958989
    1834703.509	-166.0244756
    1867746.062	-166.0412561
    1901383.704	-165.9451383
    1935627.151	-166.2331806
    1970487.315	-165.7885451
    2005975.301	-165.917954
    2042102.417	-165.8515256
    2078880.174	-165.9851721
    2116320.288	-166.3127864
    2154434.69	-166.3991563
    2193235.523	-166.310964
    2232735.149	-166.2699164
    2272946.153	-166.0492097
    2313881.348	-166.2815993
    2355553.775	-166.164723
    2397976.713	-166.4940034
    2441163.677	-166.4449547
    2485128.427	-166.1960779
    2529884.972	-166.4240639
    2575447.57	-166.6613376
    2621830.74	-166.5327157
    2669049.26	-166.5226403
    2717118.173	-166.478346
    2766052.795	-166.8279648
    2815868.718	-167.0172343
    2866581.812	-166.6226191
    2918208.238	-166.9201618
    2970764.442	-166.4278445
    3024267.17	-166.5098413
    3078733.47	-166.8679799
    3134180.693	-166.6895307
    3190626.508	-166.643503
    3248088.897	-166.9472262
    3306586.17	-167.1924103
    3366136.964	-166.6884439
    3426760.253	-166.9031768
    3488475.353	-166.8236663
    3551301.926	-167.2697617
    3615259.99	-167.0733431
    3680369.923	-167.0041524
    3746652.47	-167.5150799
    3814128.748	-167.1757765
    3882820.258	-167.1023194
    3952748.885	-167.5327573
    4023936.909	-167.2089564
    4096407.011	-167.0228271
    4170182.282	-167.1530912
    4245286.227	-167.1931914
    4321742.776	-167.3821115
    4399576.288	-167.3309099
    4478811.562	-167.3075927
    4559473.844	-167.639718
    4641588.834	-166.8303114
    4725182.694	-167.591226
    4810282.058	-167.4864482
    4896914.041	-167.5984041
    4985106.245	-167.3192976
    5074886.768	-167.5948034
    5166284.216	-167.556776
    5259327.709	-167.3306841
    5354046.892	-167.3695745
    5450471.945	-167.418802
    5548633.588	-167.5575991
    5648563.098	-167.6870382
    5750292.314	-167.59575
    5853853.648	-167.5235496
    5959280.096	-167.7727444
    6066605.248	-167.899936
    6175863.299	-167.9477215
    6287089.06	-167.9935112
    6400317.97	-167.7966218
    6515586.104	-167.6594832
    6632930.188	-167.7378792
    6752387.61	-167.9614455
    6873996.431	-167.9270708
    6997795.397	-167.8925819
    7123823.95	-167.7658642
    7252122.247	-167.7439357
    7382731.164	-167.8855375
    7515692.316	-167.8931976
    7651048.064	-167.9087496
    7788841.536	-167.9819642
    7929116.634	-167.9278014
    8071918.052	-167.8917016
    8217291.288	-167.9349359
    8365282.659	-167.8037077
    8515939.318	-167.8933736
    8669309.266	-168.0846346
    8825441.369	-167.9645688
    8984385.372	-168.1085833
    9146191.917	-168.1298486
    9310912.558	-167.9040401
    9478599.777	-167.9623208
    9649307	-168.1004953
    9823088.618	-168.004841
    10000000	-168.0645565
    10180097.51	-168.0223299
    10363438.54	-167.8962246
    10550081.48	-167.9305113
    10740085.83	-168.0710366
    10933512.1	-168.0674822
    11130421.93	-168.1772374
    11330878.06	-168.1966693
    11534944.36	-167.906736
    11742685.83	-168.0784172
    11954168.68	-168.0763255
    12169460.29	-168.1725075
    12388629.24	-168.3431395
    12611745.37	-168.0773348
    12838879.77	-167.9283938
    13070104.8	-167.8670266
    13305494.13	-167.8639834
    13545122.77	-168.0806913
    13789067.06	-167.98192
    14037404.73	-168.0935468
    14290214.89	-168.2304218
    14547578.11	-168.0741248
    14809576.37	-167.1503099
    15076293.16	-167.2155149
    15347813.44	-168.1358912
    15624223.75	-168.2107385
    15905612.13	-168.0205418
    16192068.24	-171.8461043
    16483683.36	-170.1212315
    16780550.4	-168.2731514
    17082763.94	-168.3731435
    17390420.27	-168.2166724
    17703617.41	-168.1575177
    18022455.15	-168.1604578
    18347035.09	-167.9242769
    18677460.62	-168.1009083
    19013837.04	-168.1305491
    19356271.51	-168.156707
    19704873.15	-167.8955727
    20059753.01	-168.1483589
    20421024.17	-168.3150358
    20788801.74	-168.2248394
    21163202.88	-168.1478478
    21544346.9	-167.9814466
    21932355.23	-168.0103901
    22327351.49	-168.0272102
    22729461.53	-167.8825908
    23138813.48	-168.1407679
    23555537.75	-167.7334032
    23979767.13	-167.4702158
    24411636.77	-168.0355
    24851284.27	-168.0188213
    25298849.72	-167.8778361
    25754475.7	-167.9470764
    26218307.4	-167.7831342
    26690492.6	-167.8970254
    27171181.73	-167.9764634
    27660527.95	-167.9119015
    28158687.18	-167.7930461
    28665818.12	-167.7867073
    29182082.38	-167.9676176
    29707644.42	-167.9104732
    30242671.7	-167.208359
    30787334.7	-168.0346811
    31341806.93	-167.5959227
    31906265.08	-167.915283
    32480888.97	-167.7382046
    33065861.7	-167.6434765
    33661369.64	-167.4088187
    34267602.53	-166.2171239
    34884753.53	-167.3329154
    35513019.26	-167.2410114
    36152599.9	-167.2390086
    36803699.23	-167.3754634
    37466524.7	-167.5377405
    38141287.48	-167.5408376
    38828202.58	-167.4384775
    39527488.85	-167.5252156
    40000000	-168.1417671
