Part Number: TUSB216I
Hello Expert,
I have questions for TUS216I's typical application circuit on datasheet.
First, datasheet use 1% accuracy resistor for BOOST pin.(table8-1)
But, when I confirmed required resistance accuracy on datasheet, 5% accuracy resistor is able to cover this requirement.
Then, is there any particular reason of 1% accuracy resistor in typical application circuit?
Second, datasheet use pull-down resistor for RXSEN to pull low.
But, on electrical characteristics, it only specified regarding voltage rating so we can directly connect this pin to GND to pull low.
Then, is there any particular reason of using pull down resistor for RXSEN to pull low?
I'm looking forward to hearing back from you.
Thank you and best regards,
Kazuki Kuramochi
