HI TEAMS:
Near end short-circuit test fail,How to solve it
Hi Kevin,
I am unfamiliar with the test and program you are referring to. Please explain the procedure you are using and send pictures of the setup.
David
David:
The information given by the customer is a PDF with a small font. Can you give me your email? I will send you an email.
Hi Kevin,
The description of this test is very vague. I understand you are creating a short at various locations on the cable, and expecting the DUT to detect and report an error. However, the document does not describe how you are doing this.
I have never seen this "Interoperability Tests v1.02" program before. Is it a proprietary program, and what exactly is it doing? Are you reading any registers on the PHY to look for errors? Are you using the TDR feature of the PHY?
Let me know.
David
David:
The customer just confirmed that the problem was caused by an error in the upper computer. The problem has been solved.
thank you!
