Part Number: DS90UB949-Q1EVM
We would like to configure our DS90UB949-Q1EVM with a different EDID than the pre-programmed. To do this, we currently manually write the desired EDID every time we power-on the DS90UB949-Q1EVM, but we would instead like to use an EEPROM to store our desired EDID to be loaded always. We have attempted to use a Microchip 24AA512-I/P, but have been unsuccessful to get it to work. We have some suspicions that it may not be functional due to the larger size of the memory (at 512KB).
We were hoping that you could help us determine whether the EEPROM we have selected is compatible, and if so, how we can properly set it up to use it. If it is not compatible, could you indicate why not, and recommend an EEPROM we should use instead? We've take a look at the the following document, but it is not specific enough as to the requirements of the EEPROM: /cfs-file/__key/communityserver-discussions-components-files/138/8267.Using-EDID-in-FPD_2D00_Link-Devices.pdf
Thanks!
