Part Number: DP83867E
HI Support Team
Currently we are not able to pass the compliance tests.
Could you recommend us a platform with DP83867E where the compliance test is passing?
Thanks and best regards,
Jaski
HI Support Team
Jaski
Hi Jaski,
May I ask which spec you are failing during compliance test? Did you program Test mode 1 to Test mode 4 according to the app note shown below?
Thank you,
Hillman Lin
Hi Lin
The failing tests are described here:
Yes, we have programmed the Test mode 1 to Test mode 4.
Jaski
Hi Jaski,
I would like to double check rather you program the following register during your compliance test?
Did you use extended register method while you are programing this register?
Thank you,
Hillman Lin
Hi Lin
Yes, we used the extended register method. This is the code we used.
mdio_extd_dp838x_write(skfd, 0x1D5, 0xF508);
static void mdio_extd_dp838x_write(int skfd, int location, int value)
// write value to desired register
int reg_regcr_h=0x0D;
int reg_addar_h=0x0E;
// 1. write 0x001F (address function field = 00, DEVAD = 31) to register REGCR
mdio_write(skfd, reg_regcr_h, 0x001F);
// 2. write desired register address to register ADDAR
mdio_write(skfd, reg_addar_h, location);
// 3. write 0x401F (data, no post increment function field = 01, DEVAD = 31) to register REGCR
mdio_write(skfd, reg_regcr_h, 0x401F);
// 4. write content of the desired extended register set register to register ADDAR.
mdio_write(skfd, reg_addar_h, value);
Jaski
Hi Jaski,
Are you able to send us the schematic and layout on the MDI side of the PHY for further debut?
Thank you,
Hillman Lin
Hi Lin
I will send you the schematic but not the layout, since this is secret. Can you tell me how can I sent the schematic securely to you?
Jaski
Hi Singh,
Sure, I will add you as friend in E2E. We can talk over email you accept the friend request.
Hillman Lin
